Replacement Clutches?
Old Jan 15, 2005 | 06:10 PM
Omicron's Avatar
I've read most (if not all) of the other "Clutch" threads like this one and have yet to see this specific question answered, so here goes:
I will soon be adding a Unorthodox Racing aluminum flywheel, and know it's a good idea to replace my stock clutch while the tranny is dropped to replace the flywheel. While I hate to replace a perfectly good factory clutch, I know I'd be better off doing it now as I'm apt to fry the old one when I soon add FI. :D
Problem is, I don't want to mess up the clutch pedal feel from what it is now stock. I've had high performance clutches before, and found them to be considerably stiffer. Not only do they make it hard to drive the car smoothly, but they can be generally unplesant to drive and live with.
So, can anyone suggest some good units that are stronger than the factory unit but are not much stiffer than the stock clutch? Thanks...
Old Jan 15, 2005 | 06:38 PM
Jason's Avatar
RX7store.net
I have used Spec clutches in my RX-7 and the pressure was the same as stock. The ACT clutches tend to have a stiffer pedal.
Jason
www.rx8store.com
Old Jan 15, 2005 | 06:53 PM
Omicron's Avatar
Jason
www.rx8store.com
That's helpful Jason, thanks. We may be talking soon.
Any other suggestions folks?
Old Jan 15, 2005 | 06:57 PM
Landon_Starr's Avatar
Still lovin' it...
I was having the same concern, Omicron. I even looked at Jason's Rx8 store Spec level clutches. All the same, I haven't been able to find an aftermarket clutch for less than $500, so I figured I'd just stick with the factory. <shrug> $800 in a year is about the same as $500 now, if you look at it from the "future value" of the 500 bucks you'd save sticking with the factory clutch.
Plus, you may never have to replace it. Worth the gamble for me.
--Landon
Old Jan 15, 2005 | 07:04 PM
Omicron's Avatar
--Landon
Yeah Landon, I may just do that. Probably will, but wanted to explore my options.
Old Jan 15, 2005 | 09:00 PM
Cost of the clutch isn't all the cost though. At least with a RWD car the labour isn't as bad as a FWD................
Old Jan 15, 2005 | 09:25 PM
Jason's Avatar
RX7store.net
I would say wait if you are thinking of a new clutch. There should be a bunch of choices out by this summer.
Jason
Old Jan 15, 2005 | 09:36 PM
Still lovin' it...
Originally Posted by dannobre
Cost of the clutch isn't all the cost though.................
That's why I said $800 a year from now, versus $500 a year from now. (assuming an ~ $300 R&R)
As Jason has noted, there may be choices that are even cheaper than we have now come summer, so it may be even MORE beneficial to wait. Labor for r&r of a clutch isn't soooo expensive to warrant jumping into a $500 purchase without many options.....for ME, anyway. Plus, I'm in the same boat as Omicron, I don't want my left leg to be 3x the size of my right.
--Landon
Old Jan 16, 2005 | 12:11 AM
Omicron's Avatar
Cool, thanks for the help everyone. :D
Old Jan 16, 2005 | 12:20 AM
Fanman's Avatar
Omicron,
Have you thought about the Mazda Speed units that they have here :
https://www.rx8garage.net/?page=shop...6fbd929754b1d8
I;m thinking that eventually I will have to get a beefed up tranny too.
Old Jan 16, 2005 | 09:16 AM
bureau13's Avatar
For what its worth, the ACT Street/Strip clutch I had on my RX-7 was only slightly stiffer in feel than the stock clutch. Now, I think the stock RX-7 clutch may have been a bit stiffer than the one in the RX-8 but it was in now way difficult.
jds
Old Jan 16, 2005 | 11:40 AM
Omicron's Avatar
jds
Yeah, as I recall that's what Charles Hill said about the ACT clutch in his RX-8.
Old Jan 16, 2005 | 11:42 AM
Omicron's Avatar
Originally Posted by Fanman
Omicron,
Yep, I've thought about them. Only thing is that I haven't heard anyone discuss them and how much stiffer they are than stock. But thanks! :D
Old Jan 16, 2005 | 07:39 PM
Charles R. Hill's Avatar
Owner of BHR
The ACT Extreme clutch did take a bit of getting used to but a few days later I didn't even notice it anymore. The thing that has started to happen, though, is the throwout bearing is making some noises after hard runs. I thought I saw a heavy duty version but I have yet to do a search for it. Before long I may switch to a six puck sprung disc so I'll replace the factory bearing that came in the clutch kit from SR. Since Exedy is the OEM supplier for the RX-8 I would be confident in any replacement clutch they might offer if I decide to try something different. Plus their office is not far from my home in the event I have any problems.
Charles
Old Jan 16, 2005 | 08:31 PM
Omicron's Avatar
Well, it looks like the OEM throwout bearing is only about $32 bucks at RX8Garage (here), so I wouldn't imaging a heavy duty one would be that much more.
Old Jan 16, 2005 | 10:05 PM
Jason's Avatar
RX7store.net
Hate to say it but Mazdaspeed product is so overrated. They use to be the big thing when the RX-7 came out, but now I cant give that stuff away. Mazdaspeed makes some quailty stuff, but when your looking for performance gains its not going to happen. Plus their stuff is so overpriced.
Old Jan 17, 2005 | 01:25 PM
Fanman's Avatar
Omicron,
Have you seen where RB has stated that they are almost completing their pressure plate & clutch disc setup. I would love to see what they come up with.
Jason,
Since you are probably one of their big vendors what have you heard (that we may have not on this) ? Will you be selling it ?
Old Jan 18, 2005 | 07:14 PM
Omicron's Avatar
Does this mean I can have anything you've got that's Mazdaspeed for free??!!?? WOO HOO!!!! :D
Seriously Jason, I know what you mean. But I wouldn't discard MS stuff either, especially since it doesn't void the warranty.
Now, shall I PM you my address for all the free Mazdaspeed stuff you can't give away?
Old Jan 18, 2005 | 07:15 PM
Omicron's Avatar
Omicron,
Yep, RB would be a viable option... and I did see they are working on one. But what I was after in this thread is how stiff the clutch pedal effort is for existing replacement clutches. I suspect the RB one will not be any worse than stock, but I'd still like to know what current ones are like.
Old Jan 18, 2005 | 10:40 PM
RotorManiac's Avatar
Absolute Rotary Madness
The MS clutch has to be better than the stock one. Otherwise, why would the company produce it? I really wonder if its worth the money...
Old Jan 18, 2005 | 10:58 PM
bigblockbeater's Avatar
black RX-8 6 speed
--Landon
http://rx7.com/store/rx8/rx8drivetrain_clutch.html 399.99 for a Bonez
Old Feb 11, 2005 | 05:47 PM
adrian-1's Avatar
Ex- member.
I received my Bonez clutch disk/plate today from the site mentioned above. I'm not sure why it's called Bonez, the pressure plate is made by ACT and the disc is made by EXEDY.
I'm having a shop put these in along with the RB flywheel. Greddy turbo kit will be a couple weeks after that.
Also, Racing Beat has posted 3 clutch disks that work with the 8. They're the same as the ones for a 87-95 RX7 turbo. I believe only 1 can be used for street driving, other 2 are recommended for racing only.
Attached Thumbnails Replacement Clutches?-1.jpg   Replacement Clutches?-2.jpg   Replacement Clutches?-3.jpg   Replacement Clutches?-4.jpg
Old Apr 13, 2005 | 03:06 AM
Lock & Load's Avatar
Having read all the treads on clutches , i still dont know whats the best aftermarket clutch for our cars.
cheers
michael
Old Apr 13, 2005 | 03:24 AM
Silverarrow's Avatar
OldeSpeede, Inc.
Add to that the fact that most of these kits mix companies..."bonez" and "rb" both do. Phewww
Old Apr 13, 2005 | 07:25 AM
Owner of BHR
I couldn't remember where I posted my comment about the throwout bearing but I finally found it on this thread. Check this out;
In the past I had made comments about how it seemed my t.o. bearing wasn't handling the higher plate load of the ACT Xtreme Duty plate. I was wrong. The entire system is working fine. I also put up a post, somewhere, listing several ACT applications and, more importantly, the cross-referencing of the factory RX-8 plate and disc combo. There are several other Mazda models which use the very same plate/disc as the RX-8.
With regard to specific application(s) my opinions are these:
1) The factory clutch is probably good for 300 fly h.p. but not much more than that. I base this on numbers provided by ACT.
2) If you are not going to achieve serious power levels or race your car, the street duty clutches are going to be fine.
3) Any reputable company, such as ACT, Clutchmasters, Exedy, or similar will be fine for your 8.
4) Be realistic about your power levels and clutch needs. Just about nobody on this board has a need for a 4-puck, 6-puck, ceramic/metallic, sintered iron, or other exotic material disc. Anyone who is making enough power to need these ain't posting up here because they are too busy running a racing team and schedule.
BTW, the noise I heard that I thought was my throwout bearing? That was the second-rate quality belt provided in the SR pulley kit. I matched the belt up with a higher-quality one from NAPA and made it about 3/8-1/2 shorter while I was at it. Not a hint of noise even after several 9,500 rpm passes and two days of 6,000-9,000 rpm beatings on the engine.
CRH
