Shifting concerns.........
Old Dec 21, 2004 | 08:34 AM
Hyper-Monkey's Avatar
Hello everyone. I have noticed, unfortunately more than once, that if I shift too quickly (at higher rpm's) from third to fourth gear, I am rewarded with a horrible grind. Has anyone else experienced such a grind under similar circumstances? If this has been covered before, allow me to apologize in advance for rehashing it.
If I hesitate, just a bit, before shifting into 4ht gear, the shift is very smooth. How concerned should I be about the grinds that have already occurred? There have been about five or six. Is that enough to cause significant damage to my transmission? I am worried because when they have occurred, the vehicle has been at high speeds. I don't know if that makes a difference or not regarding the extent of any damage that may be caused by the grind. The grind sounds horrible when it happens. Whenever it occurs, I immediately back off from trying to engage 4th, so it last but a couple of seconds.
Any advice or information about this would be greatly appreciated. Maybe the problem is not with the car but rather with the dumba$$ driver. HOLD ON A MINUTE...........that would be me.....................
Old Dec 21, 2004 | 08:44 AM
dmp's Avatar
dmp
RX8 and a Truk....
My doesn't grind - but I do get a clunk of sorts, coming from the rear end.
Old Dec 21, 2004 | 06:07 PM
downshift's Avatar
<p><
You might want to check out guy321's posts in this thread. His comment on post #18 suggest that you might be seeing the same problem as his:
https://www.rx8club.com/showthread.p...ght=shift+fork
theblinkof
Oct 4, 2023 05:24 PM
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
XianUnix
Sep 29, 2015 03:48 PM
