No heater/no radio controls/no amp temp/no mode a/c heater controls, WTF?
Old Dec 17, 2004 | 07:56 AM
subduedracer's Avatar
Realtor1
I get out to my car this morning. I started her up as normally I do. I then notice that the radio buttons don't work. The a/c heater control doesn't work, the amp temp display doesn't work. However, the radio buttons on the steering wheel work. I checked the fuses and nothing blown. WTF?
Old Dec 17, 2004 | 08:27 AM
Spyder_doo's Avatar
Turbo'd 5
I know I got in my 8 the other morning when it hit below freezing and the lcd display kinda of hesitated. The changing from one letter or number was very slow. I dont know what was wrong, but it cleared up and was normal as soon as it became warm in the car.
Jamie
Old Dec 17, 2004 | 08:49 AM
bigblockbeater's Avatar
black RX-8 6 speed
oh no! not you too! first question i have to ask, did you alter the stereo in any way? install any aftermarket parts to it? i put a line rca adapter on mine and now only the fan and hazards work. mazda told me i broke it so i am screwed. mine is the basic stereo. if you didn't touch the stereo then take it to your dealer and have them replace it. there are no fuses burned. the unit itself is the problem. good luck
Old Dec 17, 2004 | 09:34 AM
czr's Avatar
czr
RX8 RX8!
It's probably a loose connection in the rear that controls both radio/ac etc. If you didn't change anything, you can take it to the dealer or try to check the connections yourself as it doesn't take more than 45 mins but that gold screw is a pain.
Old Dec 17, 2004 | 10:45 AM
buzzardsluck's Avatar
i dont know if this is right but the same problem happened on my truck. on my truck the problem was the modules that the ***** are attached to. i had this problem after i had replaced a cd player. if this is the problem they are an ez fix. if this sounds dumb just ignore me lol
Old Dec 17, 2004 | 04:18 PM
Realtor1
I went out to my car later today, and its working. I think this is going to be an intermentant problem.
Old Feb 28, 2010 | 02:51 AM
04-Rx8's Avatar
My radio won't come on, aswell as the heater controls, just the fan and temp will work. How do I fix the problem.
Old Mar 15, 2013 | 08:23 PM
Strata-R's Avatar
Real Racing 3 fan
mine started intermittent but a few months later totally failed.
1. half of my lcd display is gone
2. heat is stuck on on mode therefore no A/C
3. the center air selector button cluster, (the one that lets you pick air direction and defrosters) don't work.
4. audio system and fan speed selector work
Old Mar 16, 2013 | 09:14 AM
olddragger's Avatar
do a search--i believe the answer in the in the interior section? Something to do with the console soldering?
Some poeple jusy bang the heck out of the center console and it starts working correctly.....IDKb
Old Mar 18, 2013 | 07:21 PM
Mr.Mango's Avatar
Do you have interior lights? If not I would recheck the bottom fuse in your interior fuse box. (steering wheel controls, heated seats & glove box light run off a different fuse)
Old Mar 22, 2013 | 05:23 PM
Strata-R's Avatar
Real Racing 3 fan
I have lights everywhere, even on the air mode cluster of which the buttons don't work. I'm pretty sure it's a bad Heater Control Module/ECU.
Old May 6, 2013 | 03:17 PM
Strata-R's Avatar
Real Racing 3 fan
I finally took the car in to get the issue fixed. It turns out there were multiple parts that failed: A/C Amplifier, Heater Control, Display Panel, and another part that the Display Panel is connected to.
cliffkemp
Dec 24, 2024 10:48 AM
tjohnmeyer
Sep 28, 2017 05:03 PM
RX8mzda
Oct 1, 2015 10:17 PM
pjwermuth
Sep 28, 2015 11:36 PM
Learners_Permit
Sep 27, 2015 07:38 PM
