Water pump replaced at 11,000 miles
Old Dec 7, 2004 | 09:40 PM
Glen220's Avatar
Cool Water pump replaced at 11,000 miles
Anyone else having water pump problems? I have mine in the shop now waiting for a new water pump, it should be ready tomorrow.
It started as a typical water pump going bad, slight coolant leaks found on the garage floor, disappeared for a few day, then returned.
Other than routine maintenance and the TSB's the only other problem I have had was frayed engine accessory belts at about 2,000 miles. Makes me wonder if they overtightened the new belts when the installed them and stressed the shaft.
Hopefully this is not going to be a problem area for the 8's and I do not recall any water pump issues with the RX-7's.
Old Dec 7, 2004 | 09:46 PM
Sociopath's Avatar
SocioPath
Correct me if I'm wrong, but I remember there were people having the same problem with coolant leak, but had the whole engine replaced.
Old Dec 7, 2004 | 09:57 PM
snap-on's Avatar
True..but the coolant was coming from between the housings
Not from the water pump.
Old Dec 7, 2004 | 10:02 PM
G8rboy's Avatar
Mmmmm... Rotary Donut
I would bet anything that the two issues are related...
Old Dec 8, 2004 | 12:10 AM
epitrochoid's Avatar
Riot Controller
czech the link in my sig...
what's your build date?
Old Dec 8, 2004 | 07:47 PM
Glen220's Avatar
Well my 8 was returned to me with a new water pump. They said that there was a stain at the shaft which indicated that it was definately the water pump leaking and not another (worse) problem.
The dealership has also said they only knew of one other water pump going bad and did not know of a "problem" with them in general. They additionally said that the RX-8's seem to be extremely trouble free, especially since it is a new model.
Mine was built in August of 2003 and I appreciate the link to the other thread.
Thanks I'll post if there are any further problems.
Old Dec 10, 2004 | 03:18 PM
Riot Controller
11/03 is mine...we should keep an eye on this. things fail for a reason.
Old Dec 10, 2004 | 03:55 PM
TownDrunk's Avatar
I am a meat popcicle
I had my water pump replaced a couple months ago. I think I was at around 13000 miles or so when it happened.
EDIT: Here's the thread I started:
https://www.rx8club.com/showthread.p...t=coolant+leak
Jesus Martinez
44
May 6, 2025 08:09 AM
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
Sakebomb Garage
Vendor Classifieds
Jul 31, 2015 07:36 PM
kaboshe
Jul 17, 2015 03:14 PM
