How to access the low beam headlight housing?
Old Nov 29, 2004 | 02:45 PM
ZoomZoomH's Avatar
Mulligan User
I have the base model, and want to replace the stock halogens with Osram Silverstar bulbs, but the headlight assembly is integrated INTO out crazy looking front fenders, that access from the engine bay is almost impossible.
what is the correct way to gain access to the low beam headlight bulbs???
Old Nov 29, 2004 | 03:01 PM
hamsta's Avatar
first you have to take out your 2 front wheels.
jack up your car
take out the undergaurds once you taken out your wheels.once you got it open you can see your low beam bulbs
good luck
Old Nov 29, 2004 | 06:33 PM
RotaryNoob's Avatar
Hi
You don't need to remove the wheels. Turn the wheels all the way one way and go through the wheel well.
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
Irvinb16
Sep 11, 2015 10:27 PM
yankeepicker
Sep 11, 2015 05:42 PM
jackslao
Sep 8, 2015 01:50 PM
