Aerodynamics/characteristic's
Old Nov 27, 2004 | 06:01 AM
DOMINION's Avatar
I don't buy Kool-Aid
I think this is part of the "Tech and Performance" thread. But I was looking at the first picture of the RX-8 under body. It looks very flat as the 8 sits low close to the ground. This should helps with the air current(s).
Attached Thumbnails Aerodynamics/characteristic's-new-image.jpg
Old Nov 27, 2004 | 06:07 AM
DOMINION's Avatar
In these next 2 pictures they have close the upper under carriage of the RX-8. I think this is to help with the aerodynamics of air flow under the vehicle.
I have seen this to in the Nissan Skyline. But it was used towards the back near the exhaust/gas tank.
Attached Thumbnails Aerodynamics/characteristic's-dscn3524.jpg   Aerodynamics/characteristic's-dscn3525.jpg
Old Nov 27, 2004 | 06:53 AM
RXE16T's Avatar
'RX-EIGHT'
When I hit 200+kph, I'll let you know how effective the underbody is in generating downforce........
Old Nov 27, 2004 | 07:00 AM
DOMINION's Avatar
This is the only other car that I know of that has this feature. Saleen S7R
Attached Thumbnails Aerodynamics/characteristic's-saleen-s7r-01.jpg
Old Nov 27, 2004 | 07:23 AM
hfalex's Avatar
101% Italian
We did it also 'cause the car is so low that it needs a sumpguard for rally use...
Ciao.
Old Nov 27, 2004 | 07:52 AM
DOMINION's Avatar
OK I do apologize for the lack of clarity after all its very early, but what I ment to say is the Saleen S7R has a complete close under carriage/case. Would this benefit the RX-8 in any way? is what I was trying to figure out.
Old Nov 27, 2004 | 08:39 AM
Reaper Man's Avatar
I'm a bad person
Ciao.
that's actually what I thought it was:D
I had a skidplate and diff protector for my subie for those kind of situations, wouldn't believe how much it was "used"
Old Nov 27, 2004 | 08:55 AM
DOMINION's Avatar
OK I found one of a Skyline.
Attached Thumbnails Aerodynamics/characteristic's-gtr34.jpg
Old Nov 27, 2004 | 09:09 AM
DOMINION's Avatar
Looks good but would can we mount something like this on our cars?...
Attached Thumbnails Aerodynamics/characteristic's-r34_19.jpg
Old Nov 27, 2004 | 09:19 AM
Straight8's Avatar
The 91 MR2 had a sealed, flat underbody right up to the back wheels.
Old Nov 27, 2004 | 09:32 AM
DOMINION's Avatar
Cool
The R34 GT-R V-spec
s (and only the V-Spec's) aerodynamics are dominated by a front diffuser and a carbonfiber rear diffuser. These regulate the airflow along the car's underbody, thus creating downforce which pulls the car down on the road. This leads to improved handling and stability especially at speeds in excess of 50mph, but also enhances stability during cornering and braking.
More.
Attached Thumbnails Aerodynamics/characteristic's-r34%2520gt-r%2520aerodynamics.gif
Old Nov 27, 2004 | 10:18 AM
wakeech's Avatar
mostly harmless
yeah, this was what i was suggesting for the first body kits years ago. the first problem is that engineering a good diffuser is difficult without knowing how the rest of the underbody is shaped (different folks with different exhaust systems or having mudguards or not, or side skirts, etc). then modifying the one design of the diffuser then ruins what you were trying to do in the first place, so no one would really bother using one (other'n exclusively in a rice application, just like an APC wing or some such).
another issue is simple practicality: getting a peice to fit as tight as a body panel, really work, and clear the ground enough that it makes the car no less streetable is nearly impossible to do. the vanes on a diffuser are quite thin, and would get busted up even with a little bit of gravel.
the biggest issue, really, is cost. making a quality peice out of aluminum (for durability, functionality, and weight) would be a little tricky, and pretty darn expensive. a composite piece (like carbon fibre and plastic resins) would be too flexible and rather weak unless manufactured with extrodinarily high tech processes (which builders in F1 and supercar manufacturers use, but your average aftermarket rice shop wouldn't) using an autoclave and super high tempurature and hardness resins.
but back to the question, there's no reason you can't. underbody aero is something that most cars deal with to some extent these days (Vipers, Z's, even Lexuses). it's more effective than a wing, and is just one of those little things you can do to mildly enhance the look of your car while helping on track performance a lot.
Old Nov 27, 2004 | 03:12 PM
RX Renesis's Avatar
alot of cars have their under covered completely... suh as the ENZO, Carrera GT1, F1 cars.... anything that goes fast usually have the whole under body covered
Old Nov 28, 2004 | 04:43 AM
DOMINION's Avatar
I like the sound of that a lot. Thanks.
Old Nov 28, 2004 | 04:54 AM
RXE16T's Avatar
'RX-EIGHT'
Further to what wakeech posted and you quoted, just look at the Enzo, you don't see any huge GT wings or the like, do you?
The whole design of the car is based on the intakes working in conjunction with the underbody diffusers to generate the necessary downforce to keep it glued to the floor.
Old Nov 28, 2004 | 06:04 AM
DOMINION's Avatar
Well I dont wont to get too out of hand (IE:F1) after all this is no F1 car. But I wonder if I can get the front and rear closed in like the Skyline if that would help.
Old Nov 28, 2004 | 09:25 AM
wakeech's Avatar
mostly harmless
you bet it would, it's tricky to get the design right (not impossible, almost common sense really when you're familiar with the theory), and then to actually make it or have it made for cheap is really tough.
i'll resuggest you go for aluminum sheet or if you're feeling rich stainless (of varying thicknesses, check around in scrap yards 'cause buying new is rediculous these days... thanks china :P).
taking a second look at that picture you posted of the R34 dominion, i think you could do a whole lot better than those peices on the bottom of the skyline (in terms of potential to make grip). that saleen race car picture you posted i think has just a plain, flat bottom, which isn't going to be beneficial and horrendously expensive, messy, and annoying to try and reproduce yourself (but the road car probably has some pretty good undercar aero).
Old Nov 29, 2004 | 08:30 AM
DOMINION's Avatar
Thanks, I'm looking into it.
Old Nov 30, 2004 | 03:35 PM
Murray16's Avatar
Wannabe Guru
Most modern ferraris have completely covered underbodies. Starting with the 348 I believe.
Old Dec 1, 2004 | 11:10 AM
DOMINION's Avatar
Yea see I never knew that till now. I would like to have that done on the 8.
Old Dec 1, 2004 | 02:53 PM
RXE16T's Avatar
'RX-EIGHT'
It's interesting that Ferrari are the only manufacturer who adapts a lot of their Formula One technology into their roadcars.
Everything they release has tricky aerodynamics built into the bodywork.
Old Dec 1, 2004 | 04:12 PM
NomisR's Avatar
And those cars are all MR or RR instead of FR like with the Rx8. I think it may be difficult to have the Rx8 undercarriage fully covered, at least the exhaust would need to be exposed due to the heat although I may be wrong on this.
Old Dec 1, 2004 | 11:53 PM
wakeech's Avatar
mostly harmless
there are plenty of front engined race cars with flat bottoms or contoured bottoms, you can always ventilate things and one would hope that you'd have enough sense to construct your undertray of something resiliatn enough that it could take the very mild radiant heat of a street motor exhaust.
the tricky bits are around the suspension and areas that need a lot of space for bumpin' around, while leaving yourself some ground clearance without raising the car.
Old Dec 3, 2004 | 11:00 PM
DOMINION's Avatar
Good ones. Thanks.
