How to turn OFF the TPMS
Old Nov 19, 2004 | 12:39 PM
slllygrl10's Avatar
EX-Member
Did anyone find out how to turn off the TPMS? or maybe cut off the wire??
Old Nov 19, 2004 | 05:30 PM
Mark_D's Avatar
There were a few posts out there about disabling the TPMS system, but last I saw there was no simple solution. I took a quick look at the TPMS myself. If you unplug the TPMS module (in the center console above the radio), the TPMS dashboard warning light will flash continuously.
Cutting the wire will not work, and could mess up the CAN network the car uses to communicate between the different systems. You would be better off unplugging the TPMS module.
One person suggested cutting the connection to the TPMS indicator light in the dashboard gauge, but it still may beep at you anyway.
My guess is there may be a way to reprogram the dashboard to not flash the warning light and beep, but I don't know if even the dealer can do that.
The only other option would be to create a replacement TPMS module that sends out the "I'm OK" message every few seconds so that the dashboard does not light the TPMS error indicator or beep. (I was able to simulate this solution with my laptop and a OBD2 CAN interface, but that is not a viable, or cheap solution.)
Regards.
Old Nov 19, 2004 | 05:41 PM
slllygrl10's Avatar
EX-Member
As of now it blinks continuously when I hit a bump, it wont stop til I shut the car off. I think cutting the indicator light would work hmmm I just hope I cut the right one grrr
Old Nov 19, 2004 | 05:47 PM
mysql101's Avatar
i don't have my tpms installed, the light is on, but it's a solid light, it doesn't bother me anymore than the light from having my headlights on.
Old Nov 19, 2004 | 05:52 PM
slllygrl10's Avatar
EX-Member
I dont have my tpms installed either but when I hit a bump thats when it comes on. It doesnt really bother me but I would want it off.
Old Nov 19, 2004 | 05:57 PM
mysql101's Avatar
weird. mine doesn't do anything besides light up, and stay lit up. it doesn't flash or do anything else.
Old Nov 23, 2004 | 06:47 PM
TooBIG's Avatar
Mine flashes after I drive x amount of miles.
I don't even notice it anymore.
Old Nov 23, 2004 | 10:16 PM
snap-on's Avatar
I'm thinking this is possible..The dealer would need to inhale the info from the PCM and re-enter the as built as TPMS disabled..
There is a MRI addressing the issue that the TPMS is a forced entry to the PCM.
I gotta find a cool dealer..
:o
Old Nov 23, 2004 | 10:29 PM
rx8cited's Avatar
Originally Posted by snap-on
......I gotta find a cool dealer..
:o
Find one that won't be phased by the NHTSA enforcement and tire failure related lawsuit WARNING at the top of page 6: http://www.finishlineperformance.com...02-004-04.html
Old Nov 23, 2004 | 10:34 PM
snap-on's Avatar
I know..I know
It was a sad attempt at being sarcastic..
I'm just telling you it is possible to fool the car..
Old Nov 23, 2004 | 11:35 PM
Mugatu's Avatar
Even My Dog Searches
there is an easy fix.
black tape.
Old Nov 24, 2004 | 08:58 AM
rx8cited's Avatar
black tape.
Some may consider that to be a tacky fix .
Old Nov 24, 2004 | 10:48 AM
Mugatu's Avatar
i agree - i would never do that myself - I had heard someone on this board doing that though.
Old Nov 24, 2004 | 11:44 AM
guitarjunkie28's Avatar
port hacker
can someone get a schematic of the sensor?
Old Nov 25, 2004 | 02:42 PM
snap-on's Avatar
Mazda Repair Information
TPMS MODULES REQUIRE FORCED AS-BUILT ENTRY ON PMI
Applicable Models
Model Starting S/N Ending S/N
2004 MAZDA3 00000000 ZZZZZZZZ
2004 RX8 00000000 ZZZZZZZZ
WDS will not perform normal PMI (inhale/exhale) of configuration data on TPMS modules. When performing PMI during replacement of a TPMS moduleyou will be forced to enter as-built data into the new module. Model Module Forced As-built? (as of WDS B31) __________________________________________________ ______________________Mazda 6 IC/HEC NO ABS NO RX-8 IC/HEC NO TPMS YES RKE NO DSC/ABS NO RCM NO Mazda 3 IC/HEC NO TPMS YES EHPAS NO RCM NO (Vin Entry Screen also with As-built) ABS NO (Vin Entry Screen also with As-built) PJB NO (Vin Entry Screen also with As-built) __________________________________________________ ______________________
The way I read this..if the dealer inhales the data from the PCM then forgets to re-enter the TPMS data the light should stay off, and the system will not see it as missing.
Old Nov 25, 2004 | 03:41 PM
mysql101's Avatar
anyone want to bet the dealerships don't want the liability of disabling safety equipment?
Old Nov 26, 2004 | 07:26 PM
Omicron's Avatar
Now THAT is interesting! I wonder if there is any dealership with a WDS that'd be willing to try this. Also wonder if the headlight on indicator could be turned off in a similar way....?
Old Nov 28, 2004 | 05:21 PM
port hacker
so can anyone get a schematic of the sensor?
Old Nov 28, 2004 | 06:53 PM
snap-on's Avatar
All I have access to is a functional schematic of the system..not the internals of the transmitter itself.
Old Nov 28, 2004 | 08:05 PM
port hacker
ahh... if anyone wants to throw one away, give it to me and i'll see if i can figure it out.
Old Nov 28, 2004 | 08:18 PM
SantozRx8's Avatar
Raccoons SUCK!
why would you want to disable the tpms??
Old Nov 28, 2004 | 08:39 PM
snap-on's Avatar
Some members have wheel and tire packages that will not accept the TPMS sensors.
This results in a constant TPMS light on the dash.
Old Nov 28, 2004 | 09:18 PM
Omicron's Avatar
Not to mention the fact that the damn things are too sensitive to temperature fluctuations.
Old Nov 28, 2004 | 09:27 PM
krangorx8's Avatar
I've put my TPMS in my new chrome rims and have them in the garage now for the winter. I have my winter rims on now without TPMS and the light doesn't come on. Kinda wierd but im wondering if it senses the other rims on start up since they are close and since they never give a "hey im bad signal" it stays off. Just an observation I've had.
Old Nov 28, 2004 | 09:41 PM
snap-on's Avatar
Whoa..have you ever had you car in the shop for a PCM issue?
The sensors are supposed to send a constant RF signal to the module.
