Where is the intake temp sensor module
Old Nov 16, 2004 | 11:46 AM
MDRX8's Avatar
Where is the intake temp sensor module located at?
Old Nov 16, 2004 | 12:08 PM
Soundave's Avatar
Decepticon
Awww...don't tell me you bought one of those chips off eBay for $5 that modifies your fuel/air ratio.
Old Nov 17, 2004 | 10:36 AM
MDRX8's Avatar
Anybody please respond
Old Nov 17, 2004 | 10:45 AM
RXE16T's Avatar
'RX-EIGHT'
I believe it's part of the MAF sensor.
Old Nov 17, 2004 | 11:02 AM
G8rboy's Avatar
Mmmmm... Rotary Donut
Correct-it's the brown tear-drop shaped sensor on the right in this pic:
https://www.rx8club.com/attachment.p...chmentid=20451
Old Nov 17, 2004 | 11:04 AM
RXE16T's Avatar
'RX-EIGHT'
Thought so..... wasn't 100% certain though.
Thanks for clarifying.
Old Nov 17, 2004 | 11:29 AM
conmeng's Avatar
how do you hook up that cheap chip from ebay to your maf????
Old Nov 17, 2004 | 11:35 AM
RXE16T's Avatar
'RX-EIGHT'
What cheap eBay chip?
Old Nov 17, 2004 | 11:54 AM
G8rboy's Avatar
Not sure which wires you would tap into, but it's irrelevant- the 8's ECU can't be tricked by falsifying the MAF or IAT input signals.
Old Nov 17, 2004 | 12:42 PM
zevans's Avatar
Indeed it can't, which is why I made a complaint to eBay. My eBay favourite search no longer shows all those +++++20hp cheap mod annoying items. :D
Anybody got a CANScan or similar can tell us what the intake temps run at, just out of interest?
Old Nov 17, 2004 | 01:24 PM
G8rboy's Avatar
I can log some readings... I'm planning on doing some intake mods this weekend and want to baseline some data with it stock first (intake temp, airflow, and speed/RPM with acceleration over time) today or tomorrow.
Old Nov 17, 2004 | 01:26 PM
demonfire's Avatar
intake temperature should be fairly close to ambient at speed unless you have a turbo / supercharger in the car.
Old Nov 21, 2004 | 05:43 AM
sco's Avatar
sco
Last time I did a good run, IAT was about 6 degrees C higher than ambient as reported by the ambient air sensor in the '8... however this was only one run, but it was a decent one (around 100km/h for 20 minutes)
RXFEVER
Aug 29, 2018 10:14 AM
WranglerFan
Nov 5, 2017 09:35 AM
RXFEVER
Sep 11, 2016 02:51 PM
yapakanichi
20
Sep 10, 2015 07:17 AM
stickmantijuana
Sep 4, 2015 10:31 PM
