How do u switch out the small light bulbs in the front.
Old Nov 4, 2004 | 10:12 AM
Dlin23's Avatar
I want to switch the bulbs in the front of the 8 but i dunno how to take them out. Has anyone done it before and can give me some input? thanks
Old Nov 4, 2004 | 11:58 AM
Mr. Ed's rx-8's Avatar
no more 8
check the search option...
here try this...https://www.rx8club.com/showthread.p...t=change+bulbs
Old Jun 24, 2005 | 05:08 PM
Ktreece777's Avatar
we tried the search button and your help was no good...
Old Jun 24, 2005 | 08:39 PM
StealthTL's Avatar
Bulbous....
I take it you mean the ones closest to the centre of the car....
The drivers side is easiest, start there. The bulb doesn't go in from the back (good, since that would be worse to change), they go in from the engine side of the housing, at an angle.
Take off the fusebox lid, then look into the area behind the headlight, you can see the bulb holder, if you have nimble fingers it will twist out o.k. (lefty loosey!)
The pass side is a little more difficult, and you might have to take off the lid of the computer, depends on your hand size. By the time you do the drivers, you will know! Careful to pull them straight back, they are a push-in type and if you are rough they will fall into the housing....don't ask :D .
If you have huge hands, or want to make it an all day task, you can take the wheel lining out, and go in from the back, but since they are on the inside, it's not much easier.
S
Old Jun 24, 2005 | 09:03 PM
to get to the passenger side i went through the inner plastic fender...just took off the bolts so it would be easier to open up the ecu box cover...
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
stickmantijuana
Rotary Swaps
11
Sep 24, 2015 12:47 AM
stickmantijuana
Non-Rotary Swaps
Sep 19, 2015 03:15 PM
