engine light on??? help!!
Old Oct 21, 2004 | 10:41 AM
jhchowchow's Avatar
I just bought a brand new rx-8 grand touring auto this past monday. After putting 160 miles on it, the engine light turns on! Anyone here experience this before?? Should I be worried?? Please reply. Thanks.
Old Oct 21, 2004 | 11:04 AM
G8rboy's Avatar
Mmmmm... Rotary Donut
More than likely it's not a big deal, but it could be many things, so unless you have a scan tool that can pull the code and let you know what the CEL is for, head to you dealer (and have them make sure your car is updated with the latest software flash... which they should have done already). About the only easy to check thing I can think of is to check if your gas cap is on tight... the evap system can trigger a CEL if it's not properly pressurized. (nice little trick to do if you /need/ a CEL : )
Old Oct 21, 2004 | 11:07 AM
nosubstitutec4s's Avatar
9000 RPM Viagera
unless you have a can-scan tool, you should bring it into the dealer and see which code is being brought up. it could be nothing, but it might be something.
my guess, based on very limited info, is that you might have a bad cat or o2 sensor. what else could go wrong on a car with 160 miles on it?
Old Oct 21, 2004 | 12:15 PM
Reeko's Avatar
Remeber that the CEL comes on if the gas cap is loose.
But, unless he recently added gas, that probably isn't it.
If it was the gas cap, the CEL doen't reset until several restarts after it has been tightened.
Old Oct 21, 2004 | 12:53 PM
jhchowchow's Avatar
I guess I wont have a choice but to schedule an appointment with the dealer. I'm still breaking the car in so I havent driven her hard at all. I'm just worried that it can be something serious. If anyone has any other ideas please reply. Thank you all.
Old Oct 21, 2004 | 01:12 PM
G8rboy's Avatar
Did you check your gas cap as we suggested? Just a little loose is all it takes to throw a CEL...
Old Oct 21, 2004 | 01:20 PM
snap-on's Avatar
The problem will be very difficult to troubleshoot online.
Get the car on back to the dealer and please let us know what the code was..
(so I can sleep)
Old Oct 21, 2004 | 01:35 PM
Tayninh's Avatar
"Take it back Jack"
Old Oct 21, 2004 | 06:47 PM
alnielsen's Avatar
Same thing happened to me when I picked up mine. One week after picking up the car, the check engine light comes on. The only thing the dealer did was to reset the ecu and give it the M flash.
Old Oct 21, 2004 | 06:52 PM
if it was something really serious then you would get a FLASHING cel. then you would have to get it to a service center immediately-just like the manual says. please tell us the code they found when you get it checked.
Old Oct 21, 2004 | 08:01 PM
G8rboy's Avatar
They didn't tell you what code they pulled?
This is one of the reasons I bought a CanScan tool- as well as to check for pending codes before they throw a CEL.
Old Oct 21, 2004 | 09:31 PM
jhchowchow's Avatar
i'm going to bring the car in first thing tomorrow morning. the light was not flashing. i didnt even know it was able to flash. i'll let you guyz know what happened. btw, love this forum. i've used it to research this car for over 6 months now. thanks again.
Old Oct 22, 2004 | 04:52 AM
DOMINION's Avatar
I don't buy Kool-Aid
Sounds like your RX-8 needs to be FLASHED.
Old Oct 22, 2004 | 12:09 PM
READ YOUR MANUAL. it has much information that you need to know.
Old Oct 22, 2004 | 02:45 PM
jhchowchow's Avatar
just got back from the dealer. nothing serious. just found out that my car never got the M flash?? shouldn't all cars be flashed before being sold to customers? service tech said that this car was not flashed with any ECU updates. weird. oh well, i'm happy it wasnt anything serious. my mpg might even increase. thanks for the help.
Old Oct 22, 2004 | 03:28 PM
Tayninh's Avatar
Great!!! enjoy that RX-8 Let it shine let it shine!
Old Oct 22, 2004 | 04:54 PM
snap-on's Avatar
If there is any way possible I'd STILL like to know what the code was.
As far as I know the basic function of the "M" was to prevent floods.
Unless you car was WAY BACK on the "J" and never even had the P0128 flash
Old Oct 22, 2004 | 07:30 PM
snap-on's Avatar
Originally Posted by scott_the_sock
Mine wasn't either. I don't think they really do "updates" to dealer stock unless there's a recall or you request it.
This is for reference:
http://www.finishlineperformance.com/rx8/docs/
I'm taking mine in for brake pad squeal.
In the case of a simple update..I agree
When the TSB became a MSP dealers were told to update all the stock units.
Old Oct 28, 2004 | 11:30 AM
salituro64's Avatar
Mine is at the dealer today - CEL after 60 miles. I did the gas cap trick , but still NG. I'll let you know the outcome
Old Oct 28, 2004 | 11:32 AM
it often takes several on-off cycles to clear a cel.
Old Oct 28, 2004 | 11:39 AM
LTABA's Avatar
Mine was Cat
Same deal when mine was new last spring. A couple hundred miles on it--dealer replaced catalytic convertor. Build date: June 03.
Old Oct 28, 2004 | 08:24 PM
salituro64's Avatar
Well my resolution was a faulty catalytic converter and it needed the flash upgarded
xAgyex
Jun 3, 2026 03:47 PM
ladnarf1
Apr 29, 2021 11:53 PM
akagc
Aug 11, 2015 07:07 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
