hard shutdown
Old Oct 18, 2004 | 11:41 PM
cgrx's Avatar
DRIVEN
hard shutdown
Anyone else notice when they shut off the car a loud clank comes from the engine ?
Maybe clank isn't a good word to describe it, but there is a very noticeable noise..
Old Oct 18, 2004 | 11:54 PM
newcastle's Avatar
Carbon Fiber Roof
Not familiar with this clank fortunatly. However I do have a spring like noise during my inital take off. I brought it to the dealer and they said that it was a common problem and that Mazda had issued "Bulleting #4" to correct this issue but it never corrected it. So now they are telling me that it is common and that once my breaks wear in it should go away. Well 2500 miles later and I still have that damn spring noise!!
Old Oct 19, 2004 | 02:56 AM
RXE16T's Avatar
'RX-EIGHT'
I think I know the sound you're referring to.
Does the engine make an immediate clank after shut off and then a funny metallic "whirring" sound?
If this is the noise, then mine's been doing it from day one and I have always thought it was normal.
Old Oct 19, 2004 | 04:46 AM
hotpot's Avatar
Nope.
Old Oct 19, 2004 | 10:41 AM
G8rboy's Avatar
Mmmmm... Rotary Donut
Not here... that would have me worried... mine just whirrs down quietly. Has yours always done that, or just started?
Old Oct 19, 2004 | 11:12 AM
it's one of the s-dais "doors" checking it's position. it wants to be closed the next time you start the car. it cycles to make sure it is. i have a more technical description somewhere that i will post when i get a chance.
bottom line- normal noise. just one of those things the car tests after you shut it off.
Old Oct 19, 2004 | 11:26 AM
epitrochoid's Avatar
Riot Controller
yep, turn the key to ON and listen when you turn it off...makes the same noise.
Old Oct 19, 2004 | 12:02 PM
snap-on's Avatar
Are you sure you are not hearing the throttle plate doing a self test?
It pops open then closed.
Old Oct 19, 2004 | 12:11 PM
G8rboy's Avatar
Interesting... I'll listen for that on my next shutdown. I've finally gotten used to all the various noises on ignition/startup... this car has a lot of solenoids and switches!
Old Oct 19, 2004 | 02:05 PM
ahh sorry that's what it is. i had put "some kind of plate" before editing it to the sdais wording. bad memory here. replace my original statement with what snap-on just said and pretend i said that all along
Old Oct 20, 2004 | 08:32 AM
RXE16T's Avatar
'RX-EIGHT'
I suspected that it was normal since mine does it pretty much all the time, just wasn't sure what it was.
Now I am enlightened!
92trbolzr
May 18, 2025 09:04 AM
Jst4fun
Apr 17, 2021 07:43 AM
kody59
Sep 28, 2015 03:43 PM
Stubbs
Sep 27, 2015 04:06 PM
DVerdeyen
Sep 13, 2015 11:19 AM
