DIY: Removing the gauge cluster
Old Oct 16, 2004 | 04:00 PM
magixpuma's Avatar
DIY: Removing the gauge cluster and fixing the squeek
Ok guys, I fixed my 1 qaulm with the car the infamous squeeky gauge cluster.
Its that noise you hear when your on bumpy roads it sound like squeek squeek.
Well some jerk asembaly line dude obvously overlooked some thing and now it sqeeks cuz it loose. so what does 1 do pay 400 bux in labor at a Stealer ship? NO!
**** ALWAYS DISCONNECT THE BATTERY BEFORE YOU DO THIS PROsses
It will reset your clock trip miles and radio settings but the results are way worth it.****
Can a admin put this in the do it your self section sorry,
do it your self.
Heres the tools you need 2 hands 2 arms 1 philips head screw driver. and a bit of common sence. and 3 decent size o rings. after you do it youll know what size you need.
First you remove the lower panel under the steering wheel
Attached Thumbnails DIY: Removing the gauge cluster-1093.jpg
Old Oct 16, 2004 | 04:11 PM
magixpuma's Avatar
then follow these steps.
Attached Thumbnails DIY: Removing the gauge cluster-10983.jpg
Old Oct 16, 2004 | 04:20 PM
magixpuma's Avatar
now do this step
Attached Thumbnails DIY: Removing the gauge cluster-1mond.jpg
Old Oct 16, 2004 | 04:26 PM
magixpuma's Avatar
now heres the big step
Attached Thumbnails DIY: Removing the gauge cluster-oooops.jpg
Old Oct 16, 2004 | 04:29 PM
magixpuma's Avatar
heres the last step then you just reverse everything an d put it back to gether.
Attached Thumbnails DIY: Removing the gauge cluster-aaaawwww.jpg
Old Oct 16, 2004 | 09:01 PM
RXE16T's Avatar
'RX-EIGHT'
Comprehensive instructions to say the least.
Old Oct 17, 2004 | 01:17 AM
Omicron's Avatar
Very nice DIY, magixpuma... Well done! I've replaced your .bmp files with .jpg's so people can see them, and retitled your thread - but other than that, perfect! :D
And why wasn't it moved sooner? Well, sometimes it takes us a few minutes to get these things done... you can thank Elara for getting it moved. But in the future, why not just post it in the correct forum in the first place?
Old Oct 17, 2004 | 01:59 AM
truemagellen's Avatar
Attracts tree branches
wow great job...anyone want to add to this DIY on disabling the TPMS light
Old Oct 17, 2004 | 06:13 PM
magixpuma's Avatar
A. thanks for converting the files..
B. thanks for retitleing the thread.
C. I already thanked elara.
d Im a friggen moron and cant put a thread in the right place hopefully this will help some ppl and if it does tell me so i feal good. cuz im needy like that........
Also i was driving today and its still very stable and no new sqeeks so proud.
Old Oct 22, 2004 | 01:13 PM
Nubo's Avatar
Lubricious
Nice job
Old Oct 22, 2004 | 06:24 PM
magixpuma's Avatar
thanks
Old Jul 19, 2006 | 10:11 PM
irfan's Avatar
ElusiveSasquatch
gonna try this tomorrow to see if i canget the lens off to 1- polish it, and 2- cover the blue LEDs in it.
But imjust replying to point out the the manual DOES mention 2 screws... if you look just above the W in SCREW on the diagram you will see a vertical line indicating the other screw.
Thought Id mention that for those that are reading similar diagrams... you have to follow all the lines pretty carefully since they didnt put a screw icon for each screw in most of the manual.
Old Jul 19, 2006 | 10:35 PM
Student Driver
Back from the dead!
Thanks irfan!
I was looking for this DIY a while back.
Please post pix when you're done.
I want to connect an LED to the "Beep" buzzer . Sometimes I can't hear the beep
if the radio is up very high. A little visual aid...
Old Jul 19, 2006 | 11:20 PM
renesis_power's Avatar
modification
btw can the car dealer modify the mileage meter reading?
because i am planing to buy a rx8 but i am affraid of the mileage meter is too low to be true.
cheers
Old Jul 20, 2006 | 05:08 PM
Student Driver
cheers
I'm sure it "could be" changed but most dealers aren't going to do
it because of the stiff fines... Key word = "most"
Old Jul 21, 2006 | 07:27 AM
Asmoran's Avatar
While it can be done, it's extremely hard to do. Both the guage cluster and the PCM would have to be reset to the same number. This would involve hacking the PCM, since the WDS has no functions to alter the mileage.
Old Jul 22, 2006 | 08:28 AM
olddragger's Avatar
didnt know the gauge cluster was that easy to remove! Now i am thinking about ditching the factory oil pressure gauge(and maybe cooolant one also) and mounting a "real" gauge in the factory housing.
thoughts ---and sorry I am off thread here.
olddragger
Old Jul 28, 2007 | 05:39 PM
MPG > HP's Avatar
Gauge Cluster Mods While You Have It Out
Originally Posted by olddragger
...Now i am thinking about ditching the factory oil pressure gauge(and maybe coolant one also) and mounting a "real" gauge in the factory housing...
olddragger
olddragger, Please start a new thread for this and link to it, from here. I'd like to see the analog gauges using the stock needles along with stock font-like decals showing the degree markings. Should have 20, 40, 60, 80, 100 for oil PSI and 140, 160, 180, 200, 220, 240 for degrees F (My '8 got up to 248F running at MazFest in 109F ambient and that with the heater & AC on full, before it shut down to sub 3k rpm engine save mode). Seems like there may be room on the lower part of the cluster for oil temp and volt meter.
Old Oct 22, 2007 | 06:26 PM
Zephyrzone's Avatar
HIDs back in business!
Exclamation NOT working for me
Reviving this one.
I have the gauge cluster rattle in my 07 GT Manual. I followed these instructions perfectly and got to the "scary" part where I'm supposed to pull the gauge cluster out by hand...
NOT happening. I pulled with every ounce of strength I have, and I'm probably of above average strength, and it would not budge. That cluster was not coming out. Something else has to be holding it in. Maybe the changed it for the 07's? I removed the panel, the 3 screws and the 2 screws under the wheel holding the cluster in place. I could get it to move up and down vertically and become very loose, but there was no way in the world it was coming out.
Anyone know what was holding it it? I threw some O-rings in the bottom area since I had access to that, but couldn't get behind it where I think it really needs one.
Old Oct 27, 2007 | 10:27 PM
Zephyrzone's Avatar
BUMP
Come on, somebody out there has had this problem too...
Old Mar 22, 2008 | 11:48 AM
cmr333's Avatar
SR Dubbed Rx8
those clips in the back are stubborn as hell man jus be gentle but firm and pull stright back....i know that sounds weird lol but it works.
Old Apr 3, 2008 | 11:21 PM
eddybear's Avatar
Gotta revive this because I too am frustrated with having a lame *** oil pressure gauge there when all that real estate could be used by functional gauges.
Has anyone contemplated doing this?
Thoughts?
Old Apr 4, 2008 | 08:09 AM
cmr333's Avatar
SR Dubbed Rx8
ive done it...well alomost done with it. i am working on completeing an sr20 swap into my 8 and i have had to do away with all my stock gauges. I made some smc filler plates and molded them into my stock cluster housing and have holes cut out for all my new autometer ultralite gauges..i will post up pics of the halfway done part if you like.
Old May 20, 2008 | 06:06 PM
jessedrifter's Avatar
so cal
what happans if u dont disconnet the battery?
Old Jun 18, 2009 | 04:23 PM
Zelse's Avatar
悪魔のR
Reviving this from the dead. Dealer recommended to me to pull out my cluster and then just pull out the bulb for the TPMS light. Anyone done this or is this easy to get to the bulb or what? Just wanted to check in. Thanks guys. BTW
04 RX8 Mt if that means anything about changes in clusters or something. Thanks!
