New Car Has Wrong Stereo @_@
Old Oct 6, 2004 | 05:59 PM
Evangelion's Avatar
Psycho Ferret
Hi guys, I just purchased a 04 Rx-8 (Touring Ed. which includes the Bose Audio packag). at the beginning of Sept and have been reading the board since.
Checking out the Audio forum made me realize my RX-8 does not have the Bose head unit because when i push Options i get ALC, treble, mid, and high which are suppose to be on the Standard Head unit. No AudioPLT option anywhere, I assume the speakers are Bose because they have the little bose logo on them, and the amp says Bose also... Im figureing it was just a head unit mixup... I called Mazda NA before i called the Dealer.. Just to verify im not insane and really had the Bose head unit. Well they told me to take it to the Dealer, which i am doing tommarow.
Reading the posts people seem to prefer the Basic Stereo to the Bose Stereo... Now im confusing which one to keep... I havnt heard both to compare and if the Bose head unit sucks i dont want to go from Good to Worse... The bose is 200 more watts then the Basic Stereo Right?
Any advice would be great >_< I only have til tommarow lunch time before i head up there
Old Oct 6, 2004 | 06:13 PM
mikeb's Avatar
100% Italian
I have the bose
I would ask for bose if you paid for it
Old Oct 6, 2004 | 06:16 PM
RedRenisis's Avatar
I have the BOSE audio, I like it, bass could be better though, as far as the deck I believe they all have the same head unit with all the same buttons, except certain options might not be included, for a while I thought I had the six disc, but I dont, you should have a button for MiniDisc even if you dont have the MiniDisc option, but nowhere on the head unit does it say Bose, just on the tweeters
Old Oct 6, 2004 | 06:25 PM
Evangelion's Avatar
Psycho Ferret
If all of them use the same Head unit, Why does my Car give me Standard Options, and not the Bose Stereo options?
On page 6-19 of the RX-8 manual they kind of make it out like Standard and BOSE are 2 Different stereo Decks.
Old Oct 6, 2004 | 07:19 PM
Evangelion's Avatar
Psycho Ferret
Ok so they are 2 different Decks...
Now the question is will the bose sound better then what I have :D
I guess ill find out tommarow if they have a bose deck in the shop and swap it same day.
Old Oct 6, 2004 | 07:29 PM
mazradiodoc's Avatar
The internals of the radio's are different (non Bose - internal amps) If your HU is non Bose, at full volume it should try to over drive the speakers as you are injecting a high level audio signal into a amp that needs a low level signal. This is not the first time I have heard of a non Bose HU in a Bose system, most dont complain because you can gain more bass injecting the higher sound level.
Old Oct 6, 2004 | 07:55 PM
RedRenisis's Avatar
So what you see on the screen is different, but the face plates are identical, please correct me if im wrong, if im wrong, thats one more thing I need to bring up, I do however have the AudioPilot option
Old Oct 6, 2004 | 08:01 PM
Evangelion's Avatar
Psycho Ferret
Hmm... So by the car having the standard deck with the Internal Amp, and the amp in the trunk... uh do i have 2 now or what ? Is it just redundant? Im all for more bass.
I dont like losing the MID option on the stereo deck, It just seems wrong to not have it on the Bose Deck.
Right now it sounds fine to me, It does what i want it to do, By taking it up there and swapping decks (in theory) i am expecting better sound, clarity and bass ( in theory) and by not reaching that I would be pissed.
In reality I know thats unlikely to happen.
Any Suggestions?
Old Oct 6, 2004 | 08:43 PM
The internal amp is just a few IC's.
Im not sure the sound "quality" will increase and the sound output for sure will not.
I don't know the long term effect of inputting high level sound into Bose amp (ie. damaged amp or HU).
Again the HU's are the same - made by the same company, same everything but non-Bose has internal amp IC's to drive sound 12w per channel (4).
Old Oct 6, 2004 | 09:30 PM
RedRenisis's Avatar
Also the BOSE door subs make your door handle rattle
Old Oct 6, 2004 | 09:56 PM
Evangelion's Avatar
Psycho Ferret
Well hell.. made by the same company.
What is the REAL difference between Head unit Standard.. and head unit Bose?
ALC and AudioPLT are the same thing just different wording.
No power difference, prolly little to 0 sound difference.
Meh...
Old Oct 7, 2004 | 07:22 AM
czr's Avatar
czr
RX8 RX8!
Not only your door handle but your whole door. I wonder why they didn't do anything about this during the testing phase like put some sort of cheap dampner similar to dynamat in the doors. Unless they didn't turn on any music with decent bass. It is so annoying. I'd complain to the dealer but I think I'd get laughed at. I can't get the volume above 9 without it making noise.
And I think the Bose system is missing mids but has decent plenty of highs and lows. Like you said, there are subs (ok ones) in the door.
Old Oct 7, 2004 | 11:29 PM
David Wiggins's Avatar
AudioPilot (in the Bose system) has a mic which samples cabin noise levels and adjusts the volume. ALC getins input from somewhere else and just guesses what the volume of the stereo at speed should be.
At least, that's what i got from reading the schematics. The bose headunit drawings all show a mic in them.
Old Oct 8, 2004 | 01:38 AM
thew's Avatar
Thews8
i would keep what you have.
Old Oct 8, 2004 | 09:00 AM
jtimbck2's Avatar
I would too. Audiopilot sucks donkey *****.
michaelsk8er
Nov 9, 2015 07:06 AM
MolecularConcept
Aug 5, 2015 04:43 PM
marc2820
Jul 26, 2015 10:47 PM
yapakanichi
Jul 21, 2015 08:43 PM
Majictoast
Jul 18, 2015 06:45 PM
