Winter Storage
Old Sep 20, 2004 | 07:17 AM
MyRxBad's Avatar
Fb's rock!
Post Winter Storage
I know some of you are planning on storing your 8 for the winter and I'm going to be doing the same. Do any of you know of a good place in Oshawa/Toronto area that has indoor car storage? Preferable no access storage. If you do, please let me know.
TIA!
Old Sep 20, 2004 | 04:05 PM
cubakid's Avatar
Speaking of storage, what needs to be done pre and post storage so that it starts up OK next spring?
AJ
Old Sep 21, 2004 | 05:23 AM
Mistersql's Avatar
GT Lightning Moon
I stored mine outside last year. All I did was add Stabil, removed the battery and put on a breathable car cover.
I spent the rest of the winter praying for an early spring
Old Sep 30, 2004 | 11:07 PM
MadJoker's Avatar
Mine slept in my garage, didn't do a thing to it exept roll it a couple of time during winter so tires didn't get a flat spot, When spring arrived , opened garage door turn key , AND ZOOM ZOOM...
Old Oct 13, 2004 | 07:41 PM
Amur_'s Avatar
Always 5, Acting as 1
Essential Speed in Cambridge (about 30 minutes west of Mississauga) offers no-access storage during the winter.
They do not have info about it on there site, but they will tell you all about it (and if there are any spaces still available) if you call them:
http://www.essentialspeed.com/ess/contact.html
Old Oct 14, 2004 | 10:23 AM
MyRxBad's Avatar
Fb's rock!
Thanks Amur. Unfortuneately I can' t afford a beater car this year, so the 8's gonna stay home and go to sleep. I'll definately keep them in mind for next year or if anyone asks.
Old Oct 18, 2004 | 08:54 PM
1st-car's Avatar
IMHO storing your car for the winter can cause more problems than its worth (if done wrong). You have to drain the fuilds, add fuel preservatives, put it on blocks to preserve the suspention...etc.
My suggestion will be to get it rust-proofed and leave it in a garage or covered. Than take it for a 15 minute (or longer) drive at least once a week on a day with no snow. Remeber the salt alone doesn't cause rust, its moisture and salt. So try to keep it dry and when you get it washed in the winter dry it well.
Old Oct 19, 2004 | 07:27 AM
SilverBullitt's Avatar
When are you storing your 8?
Myself. I'm storing it at the end of this month. Now I only take it when it's sunny outside to keep the 8 clean.... I'm going to miss it, how much for therapy ;-)
SB
Old Oct 19, 2004 | 10:14 AM
MyRxBad's Avatar
Fb's rock!
SB
Mine is going away at the end of the month too. Then it goes inside the garage and will get detailed (from top to bottom) and then covered.
The weather looks like it's going to hold off until then. This year I'm taking the battery out and putting it inside the house (off the ground). If I feel energetic, I'm probably going to paint the calipers/rotor hubs black as a preventative thing, but we'll see.
Old Oct 19, 2004 | 12:52 PM
Enzolor's Avatar
Pardon my ignorance, but isn't it bad for the engine to have it sit without use for such a long time?
Old Oct 20, 2004 | 08:58 AM
MyRxBad's Avatar
Fb's rock!
No, it won't hurt it as long as the car is stored properly. Contrary to popular belief starting the engine up every week or so isn't good for the car either as all the oil fully drains to the pan and takes longer to pump it up and into the engine. Also starting it up and letting it run only heats up the engine/exhaust components. This isn't good as the transmission and driveline are cold and the engine is hot. So they are expanding/contracting at different rates.
Old Oct 21, 2004 | 11:01 AM
Wing's Avatar
Why store now, I don't store anything until late november, there will still be some 10+ degree days at the end of Nov. When the salt hits the car goes away.
New_Mazda_Guy
NW RX-8 Forum
Sep 19, 2019 11:20 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
RX-8 Racing
20
May 14, 2016 06:25 PM
OnebaddRx8
Oct 17, 2015 10:05 PM
Snrub
Sep 21, 2015 06:54 PM
