Where is Radio Antenna Filament?
Old Sep 18, 2004 | 07:04 PM
Thommino's Avatar
I'm looking for filament (near back windows) of the FM antenna. Is it different from GPS antenna or is integrated?
I see the manual Pag 86 but I don't understand where is the commector.
I must install an FM modulator. Where Can I connect it near rear windows?
Thnaks
Old Sep 19, 2004 | 09:23 AM
Charles R. Hill's Avatar
Owner of BHR
Take a look at the rear window defroster and see if the antenna wire is on the driver's side, near the middle of the defroster grid. You should then be able to follow the coax cable along the wheelwell and join your modulator there.
Charles
Old Sep 19, 2004 | 09:27 AM
Thommino's Avatar
Is on Driver Side?
I'm looking it to the other side.
Thnaks
Old Sep 19, 2004 | 05:36 PM
Genom's Avatar
Not so Super right now
Why does the FM modulator need to be in the rear? it's a lot easier to get it in the console.
Old Sep 19, 2004 | 06:06 PM
Thommino's Avatar
I don't want to remove the consolle. I have a switch with Fm-modulator integrated. I ounted it in the back of rear seat. So it's more easy to connect.
Old Sep 20, 2004 | 07:06 AM
Owner of BHR
I had some interference issues and I thought I noticed the antenna being located on the side I mentioned. I haven't really dug into it yet, though.
Charles
nadodave
Aug 28, 2019 05:55 AM
RX8mzda
Oct 1, 2015 10:17 PM
Learners_Permit
Sep 27, 2015 07:38 PM
CMRine04
Sep 23, 2015 09:31 AM
just1jack
Sep 9, 2015 04:45 PM
