How do you polish plastic??
Old Sep 14, 2004 | 01:20 PM
tokenbrit's Avatar
6Spd Blue 230
I was wondering about what was the best way to polish plastic?
What products do you need to use, and how do you go about it??
Some of the body kits out there retain the OEM rear end with the plastic polished, and I was curious about how I should go about it??
Thanks.
Old Sep 15, 2004 | 06:31 AM
derwankel's Avatar
You're talking about the lower black "diffuser" and exhaust shrouds right?
Polishing that would first require that the texture be sanded out smooth, which would be an awful lot of work and would take quite a bit of patience to get just right. Then you'd need some polish:
http://www.caswellplating.com/buffs/compound4.html
... specifically formulated for plastic ... and some very soft buffs with lots of strands to keep the temperature down:
http://www.caswellplating.com/buffs/stringbuffs.html
After all that you're still going to have a black diffuser and shrouds ... just shiny.
I wouldn't consider all that work, particularly in the "mesh" areas. That would get insane. A better solution would be to build up the surface on these areas with a flexible, high-build automotive primer and sand that till smooth. essentially filling the texture. Then paint to match. A bodyshop will be "happy" to take your money to do this.
Old Sep 15, 2004 | 06:55 AM
tokenbrit's Avatar
6Spd Blue 230
Your right, polishing the plastic seems like lots of work. Still, I might cosider doing the exhaust shrouds and back diffuser as I would want it black anyway. The mesh, I would leave, or replace with a metal substitute (maybe). I think I could live with a little texture as long as it's shiny, and it matches my bodykit.
Thanks for your advice and the links. I'll let you know what I decide to do...
Old Sep 16, 2004 | 11:20 AM
epitrochoid's Avatar
Riot Controller
spray it black and clear coat it...
arexatemate
Oct 28, 2019 08:16 AM
yurcivicsux
192
Sep 12, 2017 10:54 PM
RAVSPEC
Vendor Classifieds
Oct 1, 2015 01:59 PM
XianUnix
Sep 29, 2015 03:48 PM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
