Do 255/35x18 on 8.5x18's work?
Old Sep 7, 2004 | 01:22 PM
mlx8's Avatar
Is anyone running 255/35's on 18 inch wheels? If so, do you know what offset the wheels are, and have, or do you know if there are any (a) rubbing, or (b) alignment issues?
I'm considering a set of 4 Dunlop "SuperSport" track tires, UTOGA @ 60 AAA, street/track tires for driver ed events mounted on a set of BBS RGR 18" x 8.5" wheels. TireRack online ordering system seems to imply that the BBS wheels would come in a 49mm offsett for the Rx8. OTOH, the Tirerack data says the rims are pretty light, at @ 18.8lbs per wheel.
Wouldn't an offset -10mm, or @ 40mm put the center line of the tire/wheel combo closer to the stock configuration?
I'm worried about rubbing / clearance issues, front and rear, with the additional +2cm (@ +3/4trs") width per tire.
mike
Old Sep 7, 2004 | 03:32 PM
connor@tirerack's Avatar
Forum Vendor
i show that a 255/35/18 will fit with no problems as long as you are using at least an 8.5" wide wheel. the offset would need to have between a 38 and 49mm offset depending on the shape of the spokes. i have several wheels that will fit in these fitment ranges with out any modifications.
TeslaMSI
Dec 10, 2015 01:10 AM
GARCIAC951
Sep 10, 2015 07:17 PM
ed0128
Sep 9, 2015 04:50 PM
mattymack
Sep 6, 2015 10:33 PM
ion_four
Jul 30, 2015 09:48 PM
