M-Flash is now a recall
Old Aug 6, 2004 | 04:38 PM
Maximus's Avatar
Sunlight GT
Hi, just wanted share this. I had my car in for oil change today and asked the service rep to have the PCM reflashed. I was told that the PCM reflash was now a "recall". I think this is good news for those having hard time getting the M flash
Old Aug 6, 2004 | 04:41 PM
NAVILESRX8's Avatar
FWD Hater
I'll believe it when I get the letter in the mail......
Old Aug 6, 2004 | 05:52 PM
Johnnyma45's Avatar
I just asked them a few weeks ago if they heard of the M-flash recall, and had it been done to my 8. He said no and cheerfully made an appointment. My problem with this is that after he did it I found no sticker anywhere on my car, and it doesn't feel any different. Mileage is approx. the same too. Is there any other way to tell that I can test myself?
Old Aug 6, 2004 | 06:20 PM
OH MY LORD!!!! IT IS NOT A RECALL!! it is MAZDA SPECIAL PROGRAM-MSP04. it was issued on 6/2/04 recalls are for safety issues and are mandated by the government. This is not. But it does show up as warrenty work that HAS to be done when they put your vin in the system when you go in for service. and they also have to do all dealer inventory. You will not get a letter.
read
also print oout and read the Bulletin here
i hate it when dealerships spread around false information because they are too lazy to take the time to understand what the hell they are talking about.
Old Aug 6, 2004 | 09:31 PM
SP767's Avatar
Green Hornet
Unhappy
I tried to get the M flash with my dealer on the 22nd of July. My work order shows MSPO4 completed. Does this mean I got the M flash?
I tried the oil pressure test check without success. Maybe i'm doing that wrong. Or, I did it right and the dealer is lying to me.
Steve
Old Aug 6, 2004 | 09:37 PM
RX-GR8's Avatar
Steve
if they said they completed it you got the M flash. as far as the test make sure you tap the pedal at least the minimum amount of times.
Old Aug 6, 2004 | 09:41 PM
SP767's Avatar
Green Hornet
I'm supposed to tap the brake pedal 20 times with ignition in the "on" position, correct?
And the oil pressure gauge does a sweep, yes?
steve
Old Aug 6, 2004 | 09:59 PM
PoLaK's Avatar
Son what is your Alibi?
My dealer had told me the same thing but i'll believe when i get a letter.
Old Aug 6, 2004 | 10:11 PM
Racer X-8's Avatar
Coming thru in waves...
I'm sure zoom44 is correct. A recall is for when safety concerns are compromised. Recalls are meant to get a problem fixed asap, using measures such as mailings and news media reporting to inform the public about the problem and how to get it corrected asap.
The m flash has zero safety concerns, so it need not be treated as a recall. They're gonna see that all rx-8's get it. There's just no urgency to it.
Old Aug 6, 2004 | 10:19 PM
RX-GR8's Avatar
steve
yep but i had to tap mine like 21 or 22 times.
Old Aug 7, 2004 | 02:50 AM
thew's Avatar
Thews8
if it does not work.. then your dealer did not do it.. Mine did the same thing.. had to take it back and did the break test infront of the service writer. My invoce said "recalibrated to "m" .
Old Aug 7, 2004 | 05:18 AM
DOMINION's Avatar
I don't buy Kool-Aid
OK if Mazda and/or your Mazda dealer is to send you a letter of recall. Then why did I not get one for my Airbags?... It was not till my engin light was on about the time of my first oil change that my Mazda dealer had all my recall work pulled on my 8.
Old Aug 8, 2004 | 02:45 AM
thew's Avatar
Thews8
they are not allowed to sell you that car if the Air bag recall was not done before you took it home.. IF they did do this then tell the Owner of the Lot that you are going to inform the D.A. .... MY 8 was recalled on the dock in Longbeach before any dealer even got it. IT was not allowed into the Country untill the recall had been done. YOu should see a Port of entry recall sticker under the hood.
Old Aug 8, 2004 | 03:22 AM
DOMINION's Avatar
Wow. I have the paper work with all the recall work on my 8. The lish of them is; air bag, MFLASH, Oil light and one more I cant think of.
Old Aug 8, 2004 | 07:33 AM
I, Claudius's Avatar
moved away
I never got any letters about the previous recalls, either. I got my touchup paint, though, so I know they have the right address.
Who's supposed to send recalls out? The dealer, or Mazda?
Old Aug 8, 2004 | 01:33 PM
thew's Avatar
Thews8
was it done after you took the car home ? or before they sold it to you ?
Old Aug 8, 2004 | 01:38 PM
thew's Avatar
Thews8
MAZDA USA will send you Recalls and such.. But there not going to because they think the cars are being fixed when the Dealer finds a buyer for them. The Dealers wont fix um until they have a Buyer to write the warranty work off on. That suxs but it the way it is..
Now the Air Bag stuff is supposed to be done before the Dealer can sell it.. By law. That's the only real safety recall . Besides the Dampener issue that also has to be done before the car can be sold. That is all assuming the dealer knew about the recalls before it was sold! So if you had one that was sold before Mazda released the recall, it is possible that you might be driving one around still...
Old Aug 8, 2004 | 04:01 PM
beachdog's Avatar
steve
It's not really "taps". It's more like pump the brakes 20+ times. The pedal gets pretty hard after the first few presses so you have to be very deliberate and be prepared to press hard. If you don't press hard enough it won't register. That's why it can take more than 20 times.
Old Aug 8, 2004 | 04:10 PM
beachdog's Avatar
I, Claudius - I like the King Crimson references. Now I have to fire up the turntable and play some vintage vinyl.
Old Aug 8, 2004 | 08:25 PM
thew's Avatar
Thews8
hehehhe
Old Aug 8, 2004 | 09:04 PM
Mogi's Avatar
I live in FL where I bought my RX-8 new July of 2004. Naturally after buying the car I researched online to see what others were paying for the car, I guess to rid myself of buyer's remorse (but driving the car actually did that for me). That is how I found this great site and found out about the M flash. A week later I went back to have analignment done. I asked my service mgr about the flash. He then showed me the service history (since they've had the car since Sept 2003) which the M Flash was done June 2004.
So I guess voluntary flash updates vary from dealer to dealer.
Old Aug 8, 2004 | 11:12 PM
Racer X-8's Avatar
This message is intended for the Court of the Crimson King: ()
I have recieved the letter of recall for:
2004 RX-8 Passenger's Front Air Bag Recall 1604B-b
and also,
2004 RX-8 with Manual Transmission Dynamic Damper Recall 1704B
which were both sent-out March '04.
Those are the only official recalls to-date. The oil pan issue and others are merely TSB's.
I also recieved the book, the mug & thermos & the sweet little 1:24 scale model RX-8.
I did NOT however recieve the touch-up paint, which I think is actually an optional thing that the dealers are doing. (and mine didn't )
Make sure you're in the Mazda system by emailing rx8orders [rx8orders@mazdausa.com].
Hmmm... I think I still have that album too, lemme go see...
Old Aug 9, 2004 | 01:54 AM
DOMINION's Avatar
Like a month after I took my 8 home?...
Old Aug 9, 2004 | 07:11 PM
RX-MEN-8's Avatar
I just took in my 8 for the oil change.. My service adviser told me.."We will also do the M reflash as per mazda". I do not think it is a bonified "recall" BUT they want to upgrade older 8.. ( I have had mine since August of 03. ) It was done w/ out a hassle. I had never had problems, but I figure it might help in some way. The A/C part is on backorder, but I still love my 8.
Old Aug 9, 2004 | 07:29 PM
PoLaK's Avatar
I did a little sloothing M flash is a offical TSB.
01-022/04 MAZDA SPECIAL PROGRAM (MSP04) - 2004 RX-8 - ENGINE NO START, LACK OF POWER, DTCS P2107, P2108, P2402 OR P0420 - POWERTRAIN CONTROL MODULE (PCM) REFLASH
APPLICABLE MODEL(S)/VINS
2004 RX-8 vehicles built prior to March 12, 2004
  • VIN Range: JM1FE17**40100001 - 40135536
DESCRIPTION
Some vehicles may experience the following concerns:
  • Engine fails to start (cranks but no start) at cold engine temperature. This is caused by flooded spark plugs due to slightly rich air/fuel ratio for cold starting.
  • Engine is hard to start after short distance drive without engine reaching normal operating temperature at cold ambient temperature. This is caused by lower engine compression due to seals icing by moisture inside engine.
  • Engine has lack of acceleration power and / or knocking when driving at more than approx. 6000 RPM or at high altitudes. This is caused by poor combustion gas sealing due to the lack of amount of oil supplied from the metering oil pump.
  • MIL illuminates with DTC P2107/2108 stored in memory. This is caused by sub CPU - main CPU communication error after jump-starting the engine due to dead battery.
  • MIL illuminates with DTC P2402 stored in memory. This is caused by improper threshold setting for DMTL motor electric current tolerance.
  • MIL illuminates with DTC P0420 stored in memory. This is caused by improper threshold setting for rear O2 sensor output tolerance. NOTE:
    • UNDER THE MAZDA SPECIAL PROGRAM (MSP04), ALL CURRENT DEALER INVENTORY AND RETAILED VEHICLES FOUND TO BE WITHIN THE ABOVE VIN RANGES, AND PRODUCED PRIOR TO MARCH 12, 2004, MUST BE INSPECTED AND REPAIRED ACCORDING TO THE INSTRUCTIONS CONTAINED IN THIS SERVICE BULLETIN. THIS INCLUDES CUSTOMERS WHO HAVE BROUGHT THEIR VEHICLE IN FOR NORMAL SCHEDULED MAINTENANCE AND/OR RECALL REPAIRS THAT MAY NOT BE RELATED TO THE CONCERNS OUTLINED IN THIS BULLETIN.
    • BEFORE PERFORMING ANY REPAIR, VALIDATE THAT THE VEHICLE IS APPLICABLE TO THIS PROGRAM BY PERFORMING AN "eMDCS WARRANTY VEHICLE INQUIRY" AND VERIFYING THE VEHICLE DISPLAYS CAMPAIGN "MSP04". SEE "VEHICLE INSPECTION PROCEDURE" BELOW.
DEALER INVENTORY:
Inspect and repair all current dealer inventory according to the procedures contained in this service bulletin.
RETAIL VEHICLES:
When a retail vehicle is brought into the dealer for any type of repair or scheduled maintenance, inspect and repair the vehicle according to the procedures contained in this service bulletin.
  1. Verify the vehicle is within the following VIN range, AND built prior to March 12, 2004:
      • If the vehicle is within the above VIN range, AND built prior to March 12, 2004, proceed to Step 1.
      • If the vehicle is not within the above VIN range, return the vehicle to the customer or inventory.
  2. Perform a Vehicle Status Inquiry using your eMDCS System and inspect the vehicle for an Authorized Modification Label MSP04 attached to the vehicle's hood. NOTE: Verify the campaign number as the vehicle may have multiple labels.
    eMDCS System - Vehicle Status Inquiry Results
    If eMDCS displays:
    Compaign Label is:
    Action Required:
    "Campaign: MSP04 Open"
    Present
    Contact the Mazda Corporate Dealer Assistance Group at (877) 727-6626 to update vehicle history
    Not present
    Proceed to "REPAIR PROCEDURE"
    "Campaign: MSP04 Closed"
    Present
    Return vehicle to inventory or customer
    Not present
    Complete a label and apply it to vehicle's hood
    "Campaign: MSP04 Open" or "Closed" is not displayed
    Does not apply
    Campaign does not apply to this vehicle. Return the vehicle to inventory or customer
REPAIR PROCEDURE
  1. Verify vehicle is within VIN range and has not been previously reprogrammed to the "M" calibration level. NOTE: Current calibration level can be checked using WDS. After identifying vehicle, select "Log Viewer" icon (center icon) at the lower left section of the screen. Scroll down on WDS screen and locate "Filename:". The last digit of the "Filename" is the current calibration identifier. For example: SW-N3H4EK. Vehicles that are not at the "M" calibration (Examples: J, K, L) or later need to be programmed using this repair procedure.
  2. Using WDS B30.6 or later software, reprogram the PCM to the latest calibration (refer to "Calibration Information" table) by following the "Module Reprogramming" procedure. NOTE:
    • Always update the WDS PTU first, then install the needed calibration file that WDS shows during PCM reprogramming. Go to "WDS Calibration" on ESI and download the "update" file. If the PTU is not updated to the latest WDS calibration level, the calibration file will not install into the PTU.
    • It is not necessary to remove any fuses or relays during PCM reprogramming when the WDS screen prompts you to do so. You may accidentally stop power to one of the PCM terminals and cause the PCM to be blanked, or you may receive error messages during the WDS reprogramming procedure.
    • WDS shows the calibration part numbers after programming the PCM.
    • Please be aware that PCM calibration part numbers and file names listed in any Service Bulletin may change due to future releases of WDS software, and additional revisions made to those calibrations for service related concerns.
    • When reprogramming a PCM, WDS will always display the "latest" calibration P/N available for that vehicle. If any calibration has been revised/updated to contain new information for a new service concern/issue, it will also contain all previously released calibrations.
    • When performing this procedure, if the WDS PTU is not docked and connected to 115V-120V, we recommend that a battery charger be installed on the vehicle battery and turned ON to a maximum charge of no more than 20 AMPS to keep the vehicle battery up to capacity. If you exceed 20 AMPS, it will damage the WDS PTU.
  3. After performing the PCM reprogramming procedure, verify the repair by starting the engine and making sure there are no MIL illumination or abnormal warning lights present. NOTE: After PCM reprogramming, it is no longer necessary to road test the vehicle to "relearn" KAM (Keep Alive Memory).
  4. Place an "Authorized Modification" label (P/N 9999-95-AMDC-97) with the new calibration information on the drivers side "A" pillar, near the door hinges.
  5. Verify repair.
  6. Complete the blue "Authorized Modification" label (9999-95-065A-00) with the Campaign number "MSP04" written on the sticker and affix it to the vehicle's hood.
  7. Return the vehicle to the customer.
CALIBRATION INFORMATION
Transmission
New PCM Calibration Part Number
File Name
A/T
N3H4-18-881A
SW-N3H4EM000
M/T
N3H6-18-881A
SW-N3H6EM000
NOTE: The PCM Calibration Part Numbers listed above are provided for PCM reprogramming purposes only. These are not necessarily the same Mazda part numbers used to order an actual PCM through the Mazda Parts System. It is not necessary to order a PCM as part of this repair procedure.
WARRANTY INFORMATION
NOTE:
  • This warranty information applies only to verified customer complaints on vehicles eligible for warranty repair. Refer to the SRT microfiche for warranty term information.
  • Additional diagnostic time cannot be claimed for this repair.
Warranty Type
A
Symptom Code
99
Damage Code
99
Process Number
A4432H
Part Number Main Cause
N3H4-18-881A - A/T
N3H6-18-881A - M/T
Quantity
Operation Number / Labor Hours
XX682XRX / 0.3 Hrs.
