jl 10w7 help
Old Jul 15, 2004 | 01:43 PM
rotary9k's Avatar
jl 10w7 help
i just bought a jl 10w7 and am now working on a box for it. my question is what size box would be optimal for the 10w7? i remember reading 1.5cubic ft is the optimal size, can anyone confirm this?
Old Jul 15, 2004 | 02:51 PM
rotary9k's Avatar
thanks that website helps
one more noob question, what is sealed and ported?
Old Jul 15, 2004 | 08:47 PM
rotary9k's Avatar
would i notice much of a quality decrease if i cut the depth of JL's recommended box size by 3 inches? i am looking for a clean install and getting as close to JL's enclosure recommendation as i can.
Old Jul 15, 2004 | 10:13 PM
Tigerfootball's Avatar
Clemson, NOT Auburn
I too just purchased a 10W7 and am building a custom box to fit in the trunk. i did what abbid suggested and viewed the website for specs. I did a lot of math and finally came to the right dimension to make it exactly 1.25 cuft. But mine is a sealed enclosure. When i get it built this weekend, i will try and post some pics.
Old Jul 16, 2004 | 04:25 AM
Dookie_Rx-8's Avatar
FourOneMuthaFcuknFive
well i got a jl10w0 in a wedge box its really small but sounds good to me, i dont know if its the same thing for a w7
Old Jul 16, 2004 | 09:26 AM
XeRo's Avatar
Normality is Obscene
it's not...the difference in those 2 subs is drastically different...power requirements as well as enclosure...
10W0 = 125W RMS
10W7 = 550W RMS
plus the technology and craftsmanship of the subs are way different as well...10W7's are in a lot of competition cars...
Old Jul 22, 2004 | 03:24 PM
bassoon811's Avatar
You probily(sp) would see a decrease in sound quality if you messed with the measurments, you are only cutting 3 inches but thats taking at least 100 cubic inches.
Old Jul 22, 2004 | 04:07 PM
Clemson, NOT Auburn
that is true. Just take some measurements and do some math. It may take a little bit of work but it will be worth it. just whatever you do, don't get lazy and settle for less. Good luck and let me know how it turns out.
Old Jul 22, 2004 | 10:17 PM
rotary9k's Avatar
i re-thought about it, and i have another question, are the recommended dimensions important? or is it the cubic ft. that's important? my question is basically how much of a difference would it make if i change the dimensions but still had 1.25 cu ft.
Old Jul 23, 2004 | 12:56 AM
RX82004's Avatar
I have a JL Audio 10w7 on a 500/1 in my trunk but the enclosure is ported. 1 cu. foot should be enough for sealed. My ported is 1.5 and it was done by the senior installer at Tweeters in addition to the False walls and bass ****. BTW This sub sounds superb in this vehicle and is very loud when you crank it.
Old Jul 23, 2004 | 01:35 AM
Clemson, NOT Auburn
I would definately go with what JL specifies for how much cubic feet. The dimensions themselves aren't as important, as long as you have about 1.25cu ft. Just make sure you have at least .75 inches behind the magnet and back wall. other than that, you should be set to go.
HyJynx V
Sep 21, 2012 04:55 PM
jpav123
9
May 27, 2010 12:10 AM
mpyfrom
Mar 28, 2008 11:39 AM
Herblenny
Oct 23, 2007 02:20 PM
