Slight metallic sound at about 6000 rpm
Old Jul 12, 2004 | 10:25 AM
flatso's Avatar
I'm Tantalizing
I noticed when I had the stereo down that there is a very slight metallic sound each time I rev the car to about 6K rpm's. As I go past 6K the sound stops so I don't think it is pinging or anything like that. My car has about 3200 mile is this sound normal?
Old Jul 12, 2004 | 10:45 AM
mysql101's Avatar
mine does it too. it sounds like a metal whirrrrrrrrrrrrrring sound.
it does it on 87 and 91.
Old Jul 12, 2004 | 12:55 PM
Bet on Black's Avatar
Alopecian in a black 8
I asked about this same exact thing I believe and the answer I got is that the noise is another set of fuel injectors going. Sorry I can't get any more technical than that because I don't really know how it all works. Just good mazda engineering I guess.
Old Jul 12, 2004 | 03:02 PM
search my posts for theads titled S-DAIS your answer is in there
Old Jul 13, 2004 | 09:22 AM
Nemesis8's Avatar
Bigus Rotus
I searched and found several entries for S-DAIS. But none of them were conclusive enough to make me happy. Are you saying that the S-DAIS is the culprit for this popcorn machine under the hood??
Old Jul 15, 2004 | 01:03 PM
MadDog's Avatar
Consiglieri
I know EXACTLY what you are talking about! To me, it sounds like ~6k is the resonant frequency of some sheet metal part. When you hit 6k rpm, it resonates and makes that metalic rattling sound. Sheet metal parts have light damping and so the response is very narrow around 6k. You don't hear it much above or below that rpm. To me it sounds like a heat shield or something. I had the same problem on my old 240sx.
Old Jul 15, 2004 | 04:00 PM
at 6250 rpms the tertiary intake ports open. there are little barrels inside the trac which rotate to open the port. the sound you are describing at the rpm you are saying suggests that what you are hearing is the barrels rolling to open.
Old Jul 16, 2004 | 07:41 AM
MadDog's Avatar
Consiglieri
Actually, I hear the rattling sound at about 5500 rpm. -> not the ports...
Old Jul 16, 2004 | 08:13 AM
devilboy's Avatar
The day is mine, Trebek!
I have this noise as well. I am under the impression that the M-Flash will take care of this. I plan on getting the flash with my next oil change pretty soon.
Read more about it here.
http://www.finishlineperformance.com...01-022-04.html
Old Jul 16, 2004 | 12:08 PM
at 5500 the VFAD can open under certain loads/throttle positions.
Mane
Nov 20, 2015 12:16 PM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
DVerdeyen
Sep 13, 2015 11:19 AM
rxwilly8
Sep 2, 2015 02:42 PM
