Custom 2 way speaker install, pics
Old Jul 6, 2004 | 07:47 PM
dodo_croatia's Avatar
jump...
If someone wuz intersted of making a custom install, this wuz the way i did it.
I used a DSL 2-way system (tweeters and mid-bass speakers) with crossovers.
It SOUNDS BEUTIFULL !
1. First take this out of your car and cut the plastic box out
Old Jul 6, 2004 | 07:48 PM
jump...
2. Make a paper model of the box
Old Jul 6, 2004 | 07:49 PM
jump...
3. Cut the wood
Old Jul 6, 2004 | 07:51 PM
jump...
4. Put the panels together
Old Jul 6, 2004 | 07:52 PM
jump...
5. Try to see does box fits into the plastic
Old Jul 6, 2004 | 07:53 PM
jump...
6. Fill the edges of the box so air does not leak
Old Jul 6, 2004 | 07:54 PM
jump...
7. Try to make the box to fits better to the plastic (remove the edges)
Old Jul 6, 2004 | 07:55 PM
jump...
8. Make the holes on the plastic
Old Jul 6, 2004 | 07:56 PM
jump...
9. Make the holes on the box
Old Jul 6, 2004 | 07:57 PM
jump...
10. Fit the box with the plastic and glue it
jump...
11. Fill the empty space between the box and the plastic with hard foam, i used metapur foam (dont know how is it called on english, its the blue stuff on the pisture)
Old Jul 6, 2004 | 07:58 PM
jump...
12. Finished enclosure
Old Jul 6, 2004 | 07:59 PM
jump...
13. Enclosure fitted in the car
Old Jul 6, 2004 | 08:00 PM
jump...
14. Tweeters behind the back seats
Old Jul 6, 2004 | 08:01 PM
jump...
15. Trunk space with amp and crossovers. Wires will be fitted later on,i didnt have time.
Old Jul 6, 2004 | 08:02 PM
jump...
16. Special thanx to my mum, she helped me a lot
Old Jul 6, 2004 | 08:13 PM
Omicron's Avatar
That's pretty slick, dodo_croatia. Well done! :D
I'd like to move this to the DIY (Do It Yourself) forum, but doing so will break all your picture links, so I'll have to tackle it when I have more time.
Old Jul 6, 2004 | 09:29 PM
liqiud's Avatar
Damn...between this thread, and the other thread about putting the speakers there, i am doing it...probably next weekend...
Old Jul 6, 2004 | 09:45 PM
Omicron's Avatar
Yeah, me too. Funny thing is, using wood never occured to me. D'oh!
Old Jul 7, 2004 | 06:19 AM
cockerchumps's Avatar
Wiring for the above
How would you wire the speakers in the custom set-up? Could you just power them from the existing amp under the rear deck? Sorry if this question is a bit lame.
C
Old Jul 7, 2004 | 06:29 AM
jump...
I think that bose amp is not enough powerfull to handle the custom system, but it is possible. I have conected them to bose amp to see if they even work before putting my amp, sound wuz not good.
Old Jul 7, 2004 | 08:06 AM
rot8ryx's Avatar
Are those two 6" subs???? and if so why is one of them reversed????
newbie question :p heheheh
Old Jul 7, 2004 | 10:15 AM
jump...
It cant fit in the box othey way... hehe
I will build a new box to fix this problem.
Just switch - with + on the crossover and it sound the same.
Old Jul 7, 2004 | 12:19 PM
rot8ryx's Avatar
What size subs are they? 6 or 8"???
Old Jul 7, 2004 | 02:15 PM
jump...
16 cm --> around 6"
