No tire pressure listed on the decal
Old Jun 13, 2004 | 04:51 PM
gusmahler's Avatar
Just got my 8 this weekend. I found my tire pressure gauge and decided to check the pressure. I open the driver side door to check the recommended pressure. It was blank. The decal is there. But the info regarding the correct tire pressure is not filled in.
EDIT--from elsewhere on this site, I found out that the correct pressure is 32psi. But has anyone else had a blank tire pressure decal?
Old Jun 13, 2004 | 04:56 PM
brothervoodoo's Avatar
RainMan is Back
Should be something like 32...
Old Jun 13, 2004 | 05:06 PM
Rx-Appreci-8's Avatar
Mine's blank too.
Old Jun 13, 2004 | 05:48 PM
JSE RX-8's Avatar
32 for front and back..just checked
Old Jun 13, 2004 | 05:51 PM
was blank too
Old Jun 13, 2004 | 07:14 PM
northern-8's Avatar
Yup, mine's blank too.
I guess it was too expensive for mazda to use actual ink to fill out the labels.
Old Jun 13, 2004 | 08:25 PM
w2aew's Avatar
www.dorkage.com
32 psi for the 18" wheels / Potenza tires. 34 psi for the 17" wheels (on the base AT model). Same for the front and rear.
FWIW - my sticker isn't blank... it shows 32 psi ...
Old Jun 13, 2004 | 08:42 PM
TheDosDog's Avatar
Recovered Modaholic
There is another sticker is on the door edge (not jam) that lists tire pressure.
Old Jun 13, 2004 | 08:47 PM
RenoIV's Avatar
Rotary powered since 1988
Mine has two stickers one on the door frame and one on the door that has the pressure on it. see page 8-26 in the manual
Old Jun 13, 2004 | 11:15 PM
gusmahler's Avatar
Ah, found it. The pressure is listed on the door. The one on the jam has a space to put in the pressure, but the space is blank.
Old Jun 14, 2004 | 06:49 AM
Charles R. Hill's Avatar
Owner of BHR
After trying different pressures, I have decided that 32 psi works for comfortable daily driving and 40 psi for firmer driving.
Charles
Old Jun 14, 2004 | 07:29 AM
Phlash's Avatar
Go Speed Racer, Go!
It's on the inside edge of the drivers door, not the label on the freestyle door.....
Old Jun 14, 2004 | 07:52 AM
DOMINION's Avatar
I don't buy Kool-Aid
LOL!!! that a good one... Yea me too. its blank
Old Jun 14, 2004 | 08:03 AM
MTLbroker's Avatar
Mine's labelled at 32 psi front and back. Altho on tire sidewall, shows a much higher max pressure limit. Would a higher tire pressure be detrimental to other components of the car, especially suspension, electronics? And is there an advantage to overpressurizing above the recommended 32 psi?
The car weighs only 3000 lbs or so, wouldn't overpressurizing cause uneven treadwear?
Old Jun 14, 2004 | 08:05 AM
DOMINION's Avatar
Oh dam!!! you got to be kiddong me LOL!!!...
Old Jun 14, 2004 | 08:06 AM
DOMINION's Avatar
MTLbroker, Yes overpressurizing can cause uneven treadwear and not be safe. If you do put to much air the Tire/Air sensor should light up.
Old Jun 14, 2004 | 09:53 AM
northern-8's Avatar
Yup, it's on the door. Boy do I feel stupid about the Mazda being cheap crack. They actually gave 2 labels, that's why the car costs a much as it does!
Old Jun 14, 2004 | 12:32 PM
Katchoo's Avatar
LOL....the decal-thing fooled me too. Whe delivered to me it had 45PSI in each tire...what a ride home that was!
N-E-ways, took me 2 days to figure out the right pressures (it was New Year's weekend and everything was closed).
Old Jun 14, 2004 | 01:14 PM
Phlash's Avatar
Go Speed Racer, Go!
Yeah, it got me too.......then i actually rtfm.....TADA!!!! there it was.......just as it stated......
RevMeHarder
Jun 1, 2026 02:30 PM
gwailo
May 14, 2024 06:57 AM
fireishot34
Sep 5, 2015 06:45 PM
