Finally Australia Has A Urbo For The Rennie
Old Jun 9, 2004 | 03:18 AM
kimba2's Avatar
WE ARE NOW ON OUR WAY TO ROTARY HEAVEN
Old Jun 9, 2004 | 03:19 AM
kimba2's Avatar
Sorry there was a miss print i meant TURBO
Old Jun 9, 2004 | 12:16 PM
Xyntax's Avatar
THREAD KILLER
Hahah! I thought your Urbo was for real and was something I've never heard of before.
So how about some details on this Aussie quest?
Old Jun 11, 2004 | 05:52 AM
Yanje's Avatar
yeh u could at least provide some sort of details or where u found the info :p
Old Jun 13, 2004 | 12:37 AM
kimba2's Avatar
Urbo my NEW word for the Turbo cause that what the car makes an urrrr noise not a turrr noise
The Turbo is a Garret T28 that is tucked away near the steering shaft.
The urbo spools at 2000rpm at 7psi but drops back to 4psi after 8000 to minimise rev stress.
A TSI piggy is used with this apli
not much gain is gained only 11% at the wheel but hey, We now have 55% TORQUE at 5500rpm
Stage 2 coming soon i cant wait for that one with approx 20% more power.
Price some say it tooooo dear at $7900 aussie dollars
Some say it's cheap compared to other turbo urbo kits
Old Jun 13, 2004 | 12:38 AM
kimba2's Avatar
The R Master could well and truly be the master of Rotaries in oz
Old Jun 13, 2004 | 12:40 AM
kimba2's Avatar
Keep the performance reving our way Master R
Old Jun 13, 2004 | 01:53 PM
Dookie_Rx-8's Avatar
FourOneMuthaFcuknFive
so any pictures?
Old Jun 13, 2004 | 04:26 PM
Omicron's Avatar
You'd have a little more credibility if you provided manufacturer name, pictures, etc... or at least typed you sentances in proper english. Right now you sound like a teenage kid blowing smoke.
Old Jun 14, 2004 | 12:15 AM
takahashi's Avatar
Taka san to the resicue
I save the world as usual
No worries. Taka san is here! :D
Old Jun 14, 2004 | 12:22 AM
takahashi's Avatar
A rough mod if you ask me.
They kept the stock ECu and exhaust and tell you not to push over 7000rpm. They means .... BS
taka
Old Jun 14, 2004 | 02:15 AM
Yanje's Avatar
hmmm, not neccesary. stock ecu does not need to be changed... but most often, it usually is for a turbo. but at least we're getting somewhere, lets hope stageII is more impressive and more economical and i might give it a try
Old Jun 14, 2004 | 02:33 AM
GiN's Avatar
GiN
ロンリードライバー
Where did you get this article, and what is that dyno referring to? 189hp at the wheels is just about nothing more than stock...
Old Jun 14, 2004 | 05:59 AM
takahashi's Avatar
The article is from the Motor Magazine in Australia. 189 hp at the wheel cf 140hp at the wheel in the same condition is ok.
Have you seen we cannot do a perfect dyno run to get to the Mazda stated power yet? Get real man!
bottom line Stage II is Stage I is Japan. Rotor Master stage 1 is stage 0 in Japan
Old Jun 15, 2004 | 01:37 AM
kimba2's Avatar
thanks Taka for the pics.
i think i need to invest in a scanner
Omicron I did give you the manufacturers name. If you Knew how to abbreviate in Rotary lingue the R means Rotary and Master means Master and in english lingue if you put them together they spell Rotary Master
dezau
RX-8 Racing
10
Mar 9, 2016 09:50 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Racingjunkie
Sep 29, 2015 05:05 PM
pjwermuth
Sep 28, 2015 11:36 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
