help....spring install
Old Jun 5, 2004 | 12:33 PM
bossnikon23's Avatar
hey all...
heres the deal,, i just got my tanabe's and just started installing them but i have a problem,,,were the shock bolts to the bottem A arm, i pushed it off were it bolts onto and it moved forward into that little dip right behind the rotor....since that i cannot take the shock out or return it to the top of the mounting spot?? any ideas?!??! thanks in advance for any replies.......btw ive installed springs on a few cars already and never had this problem....
Old Jun 5, 2004 | 12:40 PM
greene76's Avatar
Disconnect the a-arm, the whole setup will drop. By the way, be careful when you dismantle the front shock from the spring, more pressure than the back, mine went flying.
Old Jun 5, 2004 | 12:51 PM
first off thanks greene for the reply, second, should i dismantle the top A arm or Bottem or both? thanks soooooooooooooooooooooooooo much .....
Old Jun 5, 2004 | 01:25 PM
greene76's Avatar
Both, its good to have someone to help hold the setup. You can move it around, but beware of the line that is attached, I stretched mine pretty good before I saw it (not sure what the line is, but I'm sure its not good to tear it!)
Old Jun 5, 2004 | 01:27 PM
PUR NRG's Avatar
Read swankmonkey's coilover install instructions. They give good detail on how to remove the stock shocks.
________
THE CIGAR BOSS
greene76's Avatar
BTW, are you replacing just the springs? I did springs only, 3 or 4 weeks ago, and I just ordered my shocks because the ride has gotten HARSH.
Old Jun 5, 2004 | 03:06 PM
punishr's Avatar
R u ready 2 get PUNISHED?
I have had my tein s-tech springs on now for about two months and no ride quality is lost, the car rides excellent. What kind of driving do you do? How many miles do you have on your car? I have 11,000 on mine.
Old Jun 5, 2004 | 06:43 PM
hey all ....well i just wanted to tell everyone thanks for all of your help!!! im done with 3 springs and starting the last one in about 10 min......(dinner time) so thanks again....
punishr.......i have 6000 on my car and really just use it to go to and from work and go to my friends house.......i really dont push the car all that much ......im more a person that likes how the cars looks rather than how it performs...that is why i bought the springs instead of the intake.......
thanks again all!!!
Old Jun 6, 2004 | 12:58 AM
Kel Rx8's Avatar
if your not 1st your last
same here
but i have 4k
Old Jun 6, 2004 | 09:29 AM
punishr's Avatar
Let us know how you like them.
Old Jun 6, 2004 | 11:52 AM
syntrix's Avatar
I like cheese!
Thanks for the props.
For reference, the install is here:
http://rx8.swankmonkey.com/suspension/coilovers/
Old Jun 8, 2004 | 04:32 PM
upgradesRX's Avatar
you can get around removing both a arms up front but the back youll need to remove both ball joints... i had my stechs on in about 35mins and have had no ride quality problems yet..so far rides as good as factory but i only have 890 miles on mine so i guess ill find out
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Zube6115
Sep 30, 2015 12:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
