Cool New Toy from Escort,the G-Timer
Old Jun 4, 2004 | 11:05 PM
Preacher's Avatar
No Freaking Pistons
Whaddaya' think?
http://www.escortradar.com/gtimer.htm
Old Jun 5, 2004 | 12:13 AM
Omicron's Avatar
These are cool, but have been around a while. It's Escort's answer to the GTech Pro you may have heard about. They definitely have their uses...
Old Jun 5, 2004 | 07:37 AM
Preacher's Avatar
No Freaking Pistons
Dammit,and I thought I kept up with these things :D
I like the GTech Pro Competition,it seems to flog the Escort in $ value-wise in features....am likely gonna' go with the GT Pro C and give 'er a rip.
**Btw,the Original GTech's only $139,but imo doesn't compare to the newer unit.
Old Jun 5, 2004 | 09:40 AM
Genom's Avatar
Not so Super right now
You can get original G-techs on E-bay for 50 bucks.
Old Jun 5, 2004 | 03:10 PM
MrWigggles's Avatar
For the original, I would say that is overpriced.
-Mr. Wigggles
Old Jun 5, 2004 | 09:05 PM
Genom's Avatar
True. But it's better than 139 :D
Old Jun 5, 2004 | 09:32 PM
smrx8's Avatar
i was about to buy the gtech pro ,is it really worth it how accurate is that?
Old Jun 7, 2004 | 05:10 PM
Preacher's Avatar
No Freaking Pistons
There are gonna' be a LOT of calibrations....go to GTech's website and read the tech manual,it's about a 40-step setup process,and you need,for best results,to know the EXACT weight of your car (and many,many other things) as well as test on dead-FLAT ground....seems like a bit of hassle for reg. road f'ing around....
In short,it's prolly' accurate if you autocross at level air force base lots or wal-mart parking lots,but with normal driving conditions some of its' readings won't be spot-on.....that's what I was able to discern....and I don't,at the moment,autocross....
I'll likely get one at some point,but the units'll be available much cheaper later in the year,so will likely wait....after reading the fine print I'm not as enthusiastic as I initially was....
mdl0209
May 23, 2019 05:46 PM
Draken
Sep 21, 2015 06:14 PM
carid
Vendor Classifieds
Sep 10, 2015 09:26 AM
