Big Brake Kit
Old May 28, 2004 | 10:35 PM
jaehyun127's Avatar
Big Brake Kit
hi, i was curious about which big brake kit to get on the rx8. I want the brembo front set, but i do not know the appropriate size... Can anyone tell me the size/model of the brembo, or stoptech big brake FRONT kit...?
Can i put any brake calipers on the 8... as long as i have a spacer? Help!
Old May 28, 2004 | 10:52 PM
neit_jnf's Avatar
Stoptech
Old May 29, 2004 | 08:05 AM
shawrf1's Avatar
RX8-less
You cannot fit any calipers onto your car. Some calipers will fit with your stock wheels, while others will require larger wheel sizes and/or special caliper clearances/special offset wheels. Also, there is no appropriate size for brake kits... qualities differ and so do clamping properties... this thread may help to explain more: https://www.rx8club.com/showthread.p...light=stoptech
Brembo:
http://www.brembo.com
12.9" 4-pots ~$2400
red
Template:
http://www.zeckhausen.com/Brembo/whe...t_template.htm
Stoptech:
http://www.stoptech.com
12.9" 4-pots, ~$1700
14" 4-pots, ~$2500
red/black/silver
Template:
http://www.stoptech.com/wheelfitchart/mazda.htm
Rotora:
http://www.rotora.com
13.2" 6-pots, ~$2500
metallic blue/red
Press Release:
http://www.rotora.com/press%20release/rx8.pdf
Project Mu:
http://www.project-mu.co.jp
13.6" 4 & 6-pots, $???
aqua
GREX:
www.greddy.com
13" 6-pots, $???
polished/gold
Old May 29, 2004 | 08:43 AM
M-ster's Avatar
GREAT INFO! Thanks shawrf1, I'm thinking of big-break kit as well. The GREX kit looks fantastic!
Old May 29, 2004 | 10:25 AM
rotarynews.com's Avatar
Check out Mazdatrix: Big Break page.
Old May 29, 2004 | 11:15 AM
epitrochoid's Avatar
Riot Controller
holy sheep dip!
those Grex brakes are sweet!
Old May 29, 2004 | 12:24 PM
neit_jnf's Avatar
With the great B-R-A-K-E performance of the RX-8 and repeated reviews stating they don't fade under hard use... Why upgrade? Why not just upgrade the tires which are the limiting factor and change the brake fluid to a higher temp one if it makes you feel better? Bling? Money to burn?
Old May 29, 2004 | 03:19 PM
rlfletch's Avatar
Moderate jerk
I can tell you that out on the track the pedal is just too soft. I didn't experience any fade but after driving an EVO with it's factory Brembo's, brakes are at the top of my list for replacement. Of course for street driving the stock brakes are perfectly fine. Now if one of these companies make a kit that fits with the stock wheels I'll write a check today.
Old May 31, 2004 | 02:44 PM
Jay Goldfarb's Avatar
Try running Sebring with a stock brake with Porterfield R4 pads. Cooked the living hell out of them. Upgrading to slotted and drilled Rotora and Hawk blue pads. Also going one step higher to AP600 fluid from the ATE that went in by mistake. I think the stock calipers will do fine with the heat dispersion of the drilled and slotted rotors. Its a compromise, but a money saving one.
Old May 31, 2004 | 03:42 PM
neit_jnf's Avatar
Drilled rotors create less heat capacity and hot spots where they tend to crack, they're for looks only (IMO)
Old Jun 1, 2004 | 09:41 AM
PUR NRG's Avatar
I highly recommend StopTech for any car you care to put them on. Good design, good customer support. They are very honest and will tell you upgrading the rear brakes would be for cosmetics only. Most people who upgrade the fronts are doing it for cosmetics too but that's another story. (I installed StopTechs in my BMW after doing a couple track events but have yet to get back on a track with the car. So until then I fall into the latter category as well. )
________
Wellbutrin Lawsuites
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
airlive
Sep 7, 2015 08:32 PM
wayloco
Sep 1, 2015 09:03 PM
