Amp Recommendation
Old May 25, 2004 | 11:51 PM
Dre2216's Avatar
Amp Recommendation
Im going to be installing a sound system sometime this weekend and was wondering what amp you guys would recommend. Im going to be using 2 10" Pyramid Phase II subs right now since they are free to me. They are rated at 200/400 RMS/Peak.. Thanks for any suggestions.
Old May 26, 2004 | 01:26 AM
Dre2216's Avatar
Would this work?
Alpine MRP-M350
Old May 26, 2004 | 02:25 AM
greenhornet923's Avatar
You should look for an amp thats around 400 to 500 watts rms/max..If you are looking for a cheap amp go with like a profile..They are good and cheap..For a good amp you pay about a dollar a watt..So for a cheaper amp (lets say Pyramid) you should look for about lets say a 1000 watts b/c you will get about 500 max or so out of it
Old May 26, 2004 | 04:53 PM
Dre2216's Avatar
Thanks for the respsonse greenhornet. How about this one Xplod
Old May 26, 2004 | 07:28 PM
That should do the trick..You will just have to run the amp at 2 ohm mono..Its a mono amp anyways so thats not a big deal..Even lets say thats its to much power for your subs now..Keep the gain low and when u plain on getting new subs thats all you will have to buy..Not an amp 2..
Old May 27, 2004 | 12:43 PM
XeRo's Avatar
Normality is Obscene
nah...Zapco, Crossfire, Soundstream, RF reference series, Alpine...
those will get you the punch and clarity your looking for...unless you are on a tight budget i wouldn't skimp on the amp...a good amp will last you years and give you plenty of superior sound..do it right from the start...
Old May 28, 2004 | 08:25 AM
RotorMotor04's Avatar
RX-8 "SE3P"
DONT USE THOSE SUBS!!!
Old May 28, 2004 | 04:50 PM
Dre2216's Avatar
the subs are just a temporary solution since i am going away for the summer and want to have subs in by the time i leave next weekend. They are free to me and thats why i am using them. After i get back in the fall I will be upgrading the subs, probably to JL Audio ones.
Old May 28, 2004 | 07:19 PM
Dre2216's Avatar
well finally got the amp.. got a good deal on a Rockford Fosgate Punch 600.2 which will let me run these subs for now on a lowel gain level and also work for when i upgrade later on. Thanks for help. Ill post pics when its all done
Old May 30, 2004 | 09:45 PM
jonnyb's Avatar
be easy on those subs. they are junk and dont handle power well.
Old May 30, 2004 | 10:34 PM
Dre2216's Avatar
yeah takin it easy on them.. gain is really low right now
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Michael Bryant
Oct 12, 2015 03:07 PM
Learners_Permit
Sep 27, 2015 07:38 PM
juicemantwon
Sep 26, 2015 12:30 PM
