labor charge for installing new springs?
Old May 25, 2004 | 12:15 PM
surinda1's Avatar
How much should I expect to pay to have new springs installed on my 2004 rx8?
Old May 25, 2004 | 01:43 PM
Broke_Apex_Seal's Avatar
I charge 175 for an RX-8!
Old May 25, 2004 | 01:56 PM
mikeb's Avatar
100% Italian
I paid 100 at mazdatrix in signal hill
Old May 25, 2004 | 03:50 PM
dcfc3s's Avatar
RX-7 Guru
Drive up to Pensacola and I'll do it for $100. Should only take an hour or two, tops.
Dale
Old May 25, 2004 | 11:35 PM
Kel Rx8's Avatar
if your not 1st your last
which springs you going with ?
Old May 26, 2004 | 05:03 AM
WTF no turbo's Avatar
easy to install but can you rent a spring compressor?
Old May 26, 2004 | 05:45 AM
PJ-'s Avatar
PJ-
Spring Compressor? Real men just squeeze REALLLLLLLY hard.
Old May 26, 2004 | 04:50 PM
mikeb's Avatar
100% Italian
Originally posted by God of Thunder
Do you always do an alignment when you install new springs?
I believe you should
I did
Old May 27, 2004 | 09:50 AM
dcfc3s's Avatar
RX-7 Guru
You DEFINITELY need an alignment after installing springs. If not, you're gonna wear the crap out of the tires.
Spring compressors are only like $30, BTW. Worth owning. Typically you only need them to remove the stock springs - aftermarket springs are barely compressed when you put the assembly together.
Dale
Old May 27, 2004 | 12:00 PM
XeRo's Avatar
Normality is Obscene
AutoZone and Advance Auto stores rent those out for free...
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
Sakebomb Garage
Sakebomb Garage
Sep 6, 2015 03:29 PM
