Oil Drain Plug
Old May 24, 2004 | 07:10 AM
80CuIn's Avatar
Oil Drain Plug
Performed a search with no luck. Does anyone know what the torque spec is for the oil drain plug?
Also, remember seeing a memeber mention that he or she uses a Mobile One oil filter, part # M1-110. Can someone confirm this? Does it fit our 8?
Al
Old May 24, 2004 | 10:07 AM
dcfc3s's Avatar
RX-7 Guru
Torque on the drain plug is typically just good and snug. As tight as you can easily make it with a standard 3/8" drive socket wrench is my normal tightening.
There was a thread on oil filters recently - I think all the various part numbers were listed. The Mobil 1 filter is IMHO overpriced for what you get - I'd go with a Purolator Pure ONE filter.
Dale
Old May 24, 2004 | 11:14 AM
80CuIn's Avatar
Thanks Dale. I just thought there may be a torque spec for it. Guess I'm being ****.
Yes PureOne is quite good. Just curious about Mobile 1. My personal choice will be between the two when my Mazda filters run out (2 more left).
I'll do a search on oil filters again.
Al
Old May 25, 2004 | 06:41 AM
rx8cited's Avatar
Originally posted by 80CuIn
...I just thought there may be a torque spec for it....
You are correct ....... here is the torque spec. for the oil pan drain plug:
29.4-39.2 N-m (21.7-28.9 ft-lbf)
Old May 25, 2004 | 06:51 AM
80CuIn's Avatar
Thanks Rx8cited.
Al
drebbrnator
Dec 27, 2018 07:02 PM
uZu
Dec 30, 2015 12:35 PM
Sifu
Aug 30, 2015 10:51 PM
reni04
Aug 21, 2015 01:33 PM
Obivious
Jul 29, 2015 05:57 PM
