dead battery
Old May 23, 2004 | 07:18 PM
thew's Avatar
Thews8
dead battery
ok . the 8 has been parked in my garage for 3 days. I hoped in it this morning to find the battery totally dead
I charged it back up and checked to see if i left on any doam lights or anything.. but know all the lights were off and all the doors were closed...
has anyone else been greated with a dead battery... WTF is draining my bat.. I have not added anything that draws power !!
Any ideas
Old May 23, 2004 | 07:25 PM
w2aew's Avatar
www.dorkage.com
That's odd! Put an ammeter on it to see what the current draw is when the car is off. I know that my car has sat for several days at time, and never had a problem.
You might want to have your dealer load-test the battery. If it is bad, they'll replace it.
Old May 23, 2004 | 07:28 PM
therm8's Avatar
Bummed, but bring on OU!
I had a dead battery about 3 months ago, but that was after the car sat for 2.5 months while I was on deployment. My guess was the car alarm drained the battery. Normally I disconnect it prior to leaving, but forgot this time. No idea what would cause the battery to drain over a couple of days, a short maybe?
Old May 23, 2004 | 08:04 PM
thew's Avatar
Thews8
well a short would make a fuse pop.. but yes the car keeps the alarm and the GPS system as well as the ECU energized ..
still i would expect a dead battery after 3 months.. not 2 days
I will keep an eye on it..
hope its no big deal .
Old May 23, 2004 | 09:16 PM
dcfc3s's Avatar
RX-7 Guru
Wasn't there something about early RX-8's not having very strong batteries?
Dale
Old May 23, 2004 | 09:43 PM
Spin9k's Avatar
Momentum Keeps Me Going
I've gone and found a dead battery three times, once I can't remember why, once I'd forgotten/left the map light on, once popped the trunk button by mistake. Your trip mielage goes byebye. You'd think a 194 bulb wouldn't drain a car battery easily, yes? Wrong. I think the oem battery is minimal amp/hr capacity for cost/weight . On my list for an upgrade.
Old May 23, 2004 | 11:14 PM
thew's Avatar
Thews8
Dale
humm.. whats a good replacment battery ?
mine is a early 8
Old May 23, 2004 | 11:19 PM
Kel Rx8's Avatar
if your not 1st your last
diehard thew
ive thought about it i know i paided for the car with a new battery
but i think the 8 battery is weak
Old May 24, 2004 | 09:27 AM
BoxerGT2.5's Avatar
I have the optima orange top (reverse pole) and works great. Easy start in the cold and have left the car for 2 wks and it started up like a champ.
Old May 24, 2004 | 10:31 AM
rx8cited's Avatar
Left my car for a bit over two weeks with the stock battery in it, and it started up just fine.
What prompted you to replace your stock battery?
Old May 24, 2004 | 10:43 AM
BoxerGT2.5's Avatar
1.) I'm not fond of maintenance batts. 2.) Winter in chicago can get rather cold. Wanted a more reliable batt due to reading posts like this. 3.) I have have used optima in the past for car and car stereo applications and love them.
I figured I'd swap it for what I know is a reliable battery before any probs occur. (Just to be safe)
Old May 24, 2004 | 03:02 PM
thew's Avatar
Thews8
how much did that batt cost ya.. ?
Old May 24, 2004 | 03:09 PM
BoxerGT2.5's Avatar
I bought it in Dec so I think it was 120 out the door?
Old May 24, 2004 | 03:12 PM
thew's Avatar
Thews8
ok.. Ill just buy a new one then.. Wounder if theres a good online source.
I spent so much money on extras and mods for the car.. !! i ll just buy a new good batt.
I will be installin my avelectronics NAv upgrade with review camera today/tommorw.. so Ill need a good batt..
CAn we get a higer amp batt than stock that fits in the whole.. Or is your Orange same crank/amp rating as stock ?
Old May 24, 2004 | 03:17 PM
BoxerGT2.5's Avatar
The Orange top is more than Stock I think...750cca and 980ca. I don't remember what the stock batt is. I know the orange can be hard to find. I fould mine at a local interstate battery store.
Old May 24, 2004 | 03:33 PM
thew's Avatar
Thews8
ok ill start with a interstate dealer here..
thanks
Old May 24, 2004 | 03:51 PM
w2aew's Avatar
www.dorkage.com
thanks
You should still check to see if you have an abnormally high current draw while the car is off. A flat battery after only a few days is very unusual. It should be able to sit for a couple of weeks with no difficulty. If your car has a problem with the current draw when off, a new battery isn't going to fix it.
Old May 24, 2004 | 03:57 PM
thew's Avatar
Thews8
yes.. i realize that..
However,, M charging system per the Nav unit is putting out between 13.7 to 13.2 volts with everything off and or on.. The Alt seams to be responding to the load correctly. I am still not certian that i did not leave a map light on ..
However I will still get the new batt..
Old May 24, 2004 | 05:07 PM
rxeightr's Avatar
M0D Squad -charter member
I have heard from my dealership that they have had reports of dead batteries.
After significant searching, they found the trunk switch was not activating, and the trunk light was staying on after the trunk door was latched.
You may be experiencing the same problem. You could easily confirm this by removing your pass-thru door from inside the cabin & seeing if the light is still on.
Old May 24, 2004 | 05:10 PM
BoxerGT2.5's Avatar
Honestly, I'd replace the batt anyway, but still check to make sure there isn't a prob like rxeightr said. Mazda put a cheap batt in the car and for those of us in colder climates; it made starting the car that much harder.
Old May 24, 2004 | 05:37 PM
thew's Avatar
Thews8
good idea ill look
Old May 25, 2004 | 05:58 AM
rx8cited's Avatar
When you said maintenance battery, that reminded me that I've never looked at my battery in the almost 8k I've had the car.
I took the cover off last night, not expecting the battery to be covered with sand and dust considering that it has a cover. Have you folks found yours to be covered with dust and sand too?
Anyway, I proceeded to vacuum the top of the battery so I could take the caps off and check the electrolyte level.
What a PITA - the cap tops are flush with the battery top when installed allowing sand to get wedged in the gap between the cap edges and the battery case. Also there was sand wedge into the grooves in the top of each cap.
I took the first cap off after cleaning around it as well as I could, but some sand and a bit of debris still fell into the hole. The electrolyte level looked fine. It started getting dark, so I did not get to check the other five cells.
I don't recall seeing in the Owner's Manual that we have a maintenance battery (removable tops). The fluid level in it should be checked periodically, correct?.
There's a Battery Maintenance section on page 8-22 which mentioned nothing about checking the battery fluid level.
My other vehicles that came with removable tops always contained instructions in the Owner's Manual on checking the battery level.
My stock battery held up fine this past winter - but that's nothing like a winter in Chicago :D. I'll definitely consider replacing it with an Optima if it shows signs of trouble.
Old May 25, 2004 | 11:01 AM
thew's Avatar
Thews8
no they just expect you to replace it whne it wears out..
Old May 27, 2004 | 05:36 PM
Nubo's Avatar
Lubricious
Do you have the part number? How much room was left?
Did the stock cables fit the orange-top without modification?
Old Nov 22, 2005 | 05:21 AM
GrRx8MaZdA's Avatar
90% Carbon-100% Power
Hey guys i am fi and having problem with my setup with battery!!
I think i found the ****@ng problem.....UR Pulleys!!!!I have the battery relocated to the trunk and ur pulleys and greddy turbo and i have new gel type battery 95a...I have no leak when i measure,it says a very very very small number and then again after 3-4days its empty again...The problem is the ******* pulleys...These can empty faster your battery and especially in fi situation...
I am going to install my stock again soon or try to learn the ecu the new sizes...F@@@ing tuning!!I am pissed
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Evan Gray
Sep 26, 2015 12:30 PM
