Low idle noise
Old May 16, 2004 | 03:00 AM
seventhree's Avatar
candlewax eating chimp
Low idle noise
I have an A/T and the noise occurs when the vehicle is not in motion and and at low RPM's (less than 2000). The noise resembles a bad A/C belt "chirping", but is only heard when next to the front fenders. I only have about 4800 miles on the car so far, and hopefully, it isn't the A/C belts.
Any thoughts? Comments?
Old May 16, 2004 | 06:20 AM
Mr M's Avatar
Evolution of REvolution
Could be a vacuum leak, open the hood and listen again. It could also be a belt noise, which you should also be able to detect from under the hood.
There is a distinctive chirpy sound to the rotary engine from stock though. It shouldn't be too loud, but when you depress the accelerator quickly you may sometimes hear it. It is normal, and is the sound of the distinctive and violent combustion of the rotary engine. The combustion chamber is very long, and consequently has differing pressures in it as the rotor moves from one end to the other. As you ignite the mixture the different pressures expand at different rates, causing the noise.
I can't diagnose your vehicle over the internet though. Have a dealer listen to it for you, or compare it another car.
Old May 20, 2004 | 01:30 AM
Edmonton s/silv's Avatar
Edmonton, Silver GT
i have it too.....and a rattle in the back exhaust as well
Old May 20, 2004 | 07:36 PM
mikeb's Avatar
100% Italian
I have that noise in my AT
and I heard somewhere on this board it is normal and it is the car leaning out or mixing or something
RevMeHarder
Jun 1, 2026 02:30 PM
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
TJSiegrist
Sep 10, 2015 09:29 AM
