corner weights!
Old May 1, 2004 | 04:06 PM
zojas's Avatar
corner weights!
just got my touring model on the corner weights this morning.
full details here:
weight
bottom line: with the gas needle at two ticks over half, it weighs 2969lbs. but more importantly, the front half weighs 1563, the back half weighs 1407, only 160 lbs less! next saturday (first autocross) seems so far away...
Old May 21, 2004 | 02:33 PM
Lucino's Avatar
Thanks for the info....
Does the weight include the baby in the back?
Old May 21, 2004 | 03:07 PM
mysql101's Avatar
is that with you inside? if not, the driver would add even more weight to the front
Old May 21, 2004 | 05:17 PM
GeorgeH's Avatar
Cross weights are within 20 lbs of one another (with driver) - very nice.
Old May 21, 2004 | 05:31 PM
zojas's Avatar
I posted the weights both with me in the car and without me in the car. I left my son & his car seat at home.
Old May 21, 2004 | 05:33 PM
dknv's Avatar
Thanks for sharing that.
So, does cross weights mean, that with the driver in the car, the weight is distributed somewhat to the other corners of the car?
Old May 24, 2004 | 08:46 PM
RotorManiac's Avatar
Absolute Rotary Madness
That's wrong. A magazine hear in Greece did the same thing with the 8 with 3/4 of gas. The distribusion was 51.9% front and 48.1 rear when empty (1380kg). Then up to four people they measured:
51.75%-48.25% front-rear with driver
51.68%-48.32% front-rear with driver and passanger
49%-51% front-rear with four passangers
If you want I can post more detailed figures of the measurement. I think in the front seats the weight is equally distributed, slightly more to the rear...
Old May 24, 2004 | 10:45 PM
murix's Avatar
Excellent info. I would like to find some corner scales here in the bay area and see what my base model weighs.
Old May 24, 2004 | 11:53 PM
NewRXr's Avatar
Interesting info, may I ask a silly question? Where's the battery located in these models? ( I don't yet own an eight, sorry.)
If it's in the same place as my 7's (LF corner) then it would seem a battery relocation to the RR would be very beneficial.
Vernon
Old May 25, 2004 | 12:09 AM
murix's Avatar
The battery is located in the front left middle next to the intake so it is not detrimental to corner weights that much. It does add weight in the front but there is so little there anyway as everything else is mostly behind the front wheels.
Old May 25, 2004 | 01:10 AM
GeorgeH's Avatar
Cross weights are an important measure. Ideally, the sum of the LF and the RR would equal the sum of the RF and the LR. As the car's cross weights start to diverge, it's handling balance (understeer vs. oversteer) will start to diverge, based on corner direction. For example, if the corner weights do not match, the car will understeer more strongly in right hand turns vs. left hand turns (or vice versa).
To put this in perspective, one of the objectives of corner-weighting a car with height adjustable coilovers is to make the cross weights equal. It looks like Mazda has done a great job on this right out of the box, re-iterating how well this car is setup from the factory. Pretty impressive - I wonder how many other cars have such well matched cross weights right from the factory? I suspect not many.
Jst4fun
Apr 17, 2021 07:43 AM
New_Mazda_Guy
NW RX-8 Forum
Sep 19, 2019 11:20 AM
duworm
Oct 1, 2015 04:57 PM
Stubbs
Sep 27, 2015 04:06 PM
