Cracked MS Wing
Old Apr 30, 2004 | 11:54 AM
Thrax's Avatar
Cracked MS Wing
Well I have had the MS wing for about a week. Last weekend I took the car out on the highway, 125KM's between exits.
It would seem that air got under the lip, on the drivers side of the lip spoiler, lifting up against the screw.
A defect, don't know. Installation was to the letter. Having ordered the Wing from the US, I don't have any warranty recourse. I'll likely be taking it into a body shop to have the lip spoiler molded into the trunk.
As the lip spoiler is only held on with 4 pieces of 2 face taped and the two screws its not a solid edge.
I haven't heard of anyone else experiencing a problem. Thought I would share my experience.
Old Apr 30, 2004 | 12:14 PM
leegina's Avatar
Is that screw a little off? It looks like it is not flush?
Old Apr 30, 2004 | 12:24 PM
AlexCisneros's Avatar
I actually replaced that screw with a hex head so I could really tighten the sides down to the car.
...but then I have the Rotary Extreme Carbon Fiber MS wing so perhaps it's a bit stronger.
Old Apr 30, 2004 | 12:26 PM
PUR NRG's Avatar
Bummer dude. But are you positive that's what happened? Could it be over-tightening the screw?
________
MEDICAL MARIJUANA PATIENTS
Old Apr 30, 2004 | 12:35 PM
Astor's Avatar
They Come At Night
Sorry to see that, but I agree, it most likely was caused by overtightening the screw with the other one you used, putting it under undue stress as it looks askew.
Old Apr 30, 2004 | 12:37 PM
Astor's Avatar
They Come At Night
Oh yeah, I put vinyl siding on as a teenager because it paid good and it was before the big computer revolution. If you over tightened the siding, or put nails or screws in wrong, as the temperature changes, the plastic expands and contracts. Probably your culprit.
Old Apr 30, 2004 | 01:20 PM
Thrax's Avatar
Not that it was in the instructions but a torque wrench was used 7 1/2' lbs torque
It sucks! Its going to cost more $'s but the body shop will take care of it.
I don't know anyone else personally with this wing but I am interested to know if others on the forum with this wing have a tight seal between the trunk and the lip spoiler?
Did owners leave it assembled as supplied or run silicon around the bottom edge?
The other screw is fine. Looking at the wing you can see where it lifted.
Old Apr 30, 2004 | 01:46 PM
PUR NRG's Avatar
What exactly will the body shop do? If you never plan to remove the part my advice would be remove the screw, squeeze some caulk into the area and refasten the screw. The black stuff they use to seal automotive windows is ideal. The crack itself is so small that I wouldn't bother, but you could apply touch-up paint to cover the seam and no one will ever notice.
________
Lovely Wendie
Old Apr 30, 2004 | 02:01 PM
Jeph's Avatar
if you have the bottom molded to the car, that would create even worse cracking i can imagine along the molding if the wind lifts it up or if it gets bumped around on opening and closing the trunk.
just my thinking...
Old Apr 30, 2004 | 02:19 PM
soundbombing's Avatar
hybrid-rx8 just got one and he is in canada. i don't know when he is going to install it but good luck on getting it fixed.
Old Apr 30, 2004 | 02:43 PM
I put more than 71/2 lbs of torque, but again... Mine is made of carbon fiber (I think Astor was confused) and has not cracked in any way. Rotary Extreme's wing is very well made.
To answer your other question
I used silicone around the bottom.
BTW: Pidge
I LOVE YOUR AVATAR :D
Old Apr 30, 2004 | 02:52 PM
Yeah, don't do that. The screw is bolted to a metal bracket and not to the trunk lid. I suggest you have a body shop apply a couple of small layers of fiberglass on the under side to strengthen the hole, then sand a bit to even it. Apply a bit to the outside if you'd like, but that will require a bit of sanding and painting to finish off. Then don't over tighten the screw. Chances are that when the double sided tape "popped" up the stress was placed on the two outside screws. If you choose to silicone like I did, it should help.
Old Apr 30, 2004 | 02:55 PM
Astor's Avatar
They Come At Night
You're right, I think I was confused, somewhat, but I didn't question the quality of the RE Spoiler, just questioned the screw.
yurcivicsux
192
Sep 12, 2017 10:54 PM
OnebaddRx8
Oct 17, 2015 10:05 PM
arexatemate
Oct 4, 2015 12:36 PM
GK1707
Sep 27, 2015 07:33 PM
coolcars44
Sep 24, 2015 05:47 PM
