single rotor renesis
Old Apr 24, 2004 | 02:05 AM
shawnio's Avatar
I know I've seen single rotor renesis engines somewhere on the web but can't find any specs. I was daydreaming the other day about their potential and wondered if they would be feasible as a motorcycle engine. Seems like they'd be a whole lot smoother than 2 piston engine. Probably wouldn't eclipse any superbikes, actually I know very little about motorcycle tech.
anyhow, thoughts?
Old Apr 24, 2004 | 02:45 AM
Mr M's Avatar
Evolution of REvolution
I think the renesis is too big for a bike. Cut down the external dimensions by q third, mount it sideways in the frame, make some custom housings to mount a slot-in gear box (like on race bikes) and your away!
The biggest problem would be mounting the gearbox and cooling. And intake! You could never use the standard manifold, and whatever manifold you used it would be sticking out the side of the engine! Yuk!
Worth dreaming about though, someone will do it,,,
Old Apr 24, 2004 | 08:04 AM
PaulieWalnuts's Avatar
Hmmmm. Mazda rotary motorcycle? Why not. Honda, BMW, and Suzuki make both cars and bikes.
Old Apr 24, 2004 | 01:18 PM
GiN's Avatar
GiN
ロンリードライバー
There used to be a company called Eco-Max that made single-rotor engines running on Liquid Propane Gas. Supposedly generated 125hp from those motors.
In regards to rotary motorcycles - it's been done before.
Here's a page that has rotary motorcycle information:
http://www.monito.com/wankel/motorcycles.html
Old Apr 24, 2004 | 06:58 PM
B-Nez's Avatar
Re: single rotor renesis
anyhow, thoughts?
Did you really see single-rotor Renesis', or single-rotor rotaries? There are a few companies that make the latter. I'd be more interested in using one to swap the Briggs on my lawn mower. Now, that would be sweet - especially if it was a riding mower.
I think Rotax makes a small rotary for go-karts, and I believe someone even makes a complete turn-key kart with that motor.
Old Apr 24, 2004 | 07:20 PM
Yep, I know. I meant that a Mazda rotary bike would be interesting. I'm planning on buying a Suzuki RE-5 after I get an 8.
Old Apr 24, 2004 | 07:55 PM
kristopher_d's Avatar
Drive Master
I've got an old 13B in my parents garage. Since they've cut the outer dimensions down on the renesis already, I expect it should be possible to build a frame around the entire 2 rotor engine. Damn, that'd be sweet.
Old Apr 24, 2004 | 10:59 PM
kbull's Avatar
Senior Jackass
A 2-rotor motorcycle? Deathmobile, I say.
Old Apr 25, 2004 | 01:05 AM
GiN's Avatar
GiN
ロンリードライバー
Well it's not all that bad. The Suzuki Hayabusa, which is not at all uncommon nor unobtainable, has a 1300cc motor. Granted, that thing is considered a deathmobile by most as well. :D
Old Apr 26, 2004 | 06:45 PM
Need For Speed's Avatar
SPEED-8
a pix of hercules wankel bike.
a link.
http://www.millville.org/Workshops_f...torcycles.html
Old Apr 28, 2004 | 07:50 AM
Psylence's Avatar
Back in the family
Norton used to race a Wnkel powered bike in several race series in Europe. It was by far the best and sportiest of the rotary powered bikes.. it actually looked like a modern sportbike.
However, it was eventually banned from competition because it was obnoxiously loud, smoky, and they just couldn't figure out what class to put it in displacement-wise.
I'd be all over a new rotary powered sportbike, since I'm a 2stroke junkie who is rather unsatisfied with all current motorcycles...
Old Apr 29, 2004 | 03:16 PM
Psylence's Avatar
Back in the family
Behold the Norton F1 Rotary racebike.
Old Apr 30, 2004 | 11:38 AM
TRZ750's Avatar
One of the big issues on the Suzuki re-5 was fuel range. Since the bike was too heavy for anything except a street cruiser the fact that it could only go ~100 miles on a tank full became a real problem.
Hunterkelley24
Jun 14, 2022 08:32 AM
jamespond24
Dec 1, 2015 11:11 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
pjwermuth
Sep 28, 2015 11:36 PM
