RX-8 Brakes 101 Question
Old Mar 19, 2004 | 12:07 PM
Booster MPS's Avatar
Much has been discussed on these threads re: the brake dust that builds up on the front wheels. My question is the following: why does the vehicle use more front than rear brake? I am sure the answer is simple but I would love to know. Thanks !
Old Mar 19, 2004 | 12:46 PM
RotaryZZ's Avatar
Just simple law of physics, there is a weight transfer to the front whenever you apply the brake. The harder you step on the brake, the more is the weight transfer taking place.
On a side note, I've remembered Mario Andretti saying that if someone told him that the use of the brake is solely for stopping the car, then whoever said that can't be a good racer. Obviously, a good racer should know the intricacies of using the brake to balance the car as well as effecting a weight transfer to help him to gain that hundres of a second advantage over his competitors.
Old Mar 19, 2004 | 01:01 PM
wakeech's Avatar
mostly harmless
during deceleration, you need a lot of grip to continue to decelerate, and maintain grip on the road with your front wheels. to do this, the front wheels are enlisted to do most of the work braking, as doing so will shift the balance of the car (and thus the amount of weight) from the back to the front with the momentum of the car continuing forward. this will give you more grip on the front (more force down equals more force up on the tyres), for both harder braking and steering. it does lift some grip off of the rear wheels, though, but when stopping in a mostly straight line (and considering most passenger cars are heavier in the back than the front when loaded) it's a good comprimise.
also, from a performance standpoint, you can think of each wheel of having 100% of their grip (optimally). the rear wheels would be doing the accelerating and stabilizing (lots of cornering demand on the rears), while the fronts would do the braking and pointing... it makes sense from that perspective as well (spreading the work the tyres to around more evenly).
Old Mar 19, 2004 | 05:11 PM
VividRacing.com's Avatar
The same is true on all wheeled vehicles. 75-80% of stopping power is in the front. That's why front rotors are larger than rears. Between these two other replies they've got your answer covered. Good explenation guys.
Old Mar 19, 2004 | 06:38 PM
Reeko's Avatar
This is especially apparant if you ride motocross bikes.
I would guess that 90% of your braking power is in the front brake. When you grab it, lots of weight shifts forward and the front forks compress a lot. The rear brakes add little to the stopping , but are useful to slide the rear end around in a turn.
It is even a recomended rideing technique to drag the front brake in a rutted turn, this keeps weight shifted on the front end to keep you from falling out of the rut.
UHATEIT
Mar 31, 2019 05:31 PM
BigMikeATL
May 26, 2016 12:31 AM
Kahl
Aug 20, 2015 11:49 PM
EfrainOlivares
Aug 14, 2015 06:17 PM
thewatcher101
Jul 27, 2015 09:44 PM
