Recommended Stage-X canzoomer install mod
Old Mar 12, 2004 | 11:13 PM
amartin's Avatar
After installing, I was uneasy about the 2 pieces of "ECU" laying ontop of each other, unmounted, and potential vibrating.
My mod:
1/4" Foam and 1'2" foam obtainable from any hobby shop which is used to insulate batterys for model airplains/helicopters.. (Basically white dense foam).
between the 2 ECU's, 1/4" foam, 1/2" foam on the top Ecu (canzoomer mod), 2 large rubber bands to 'tie' then togeather.
Close the box and drive.
To me, this will prevent vibration damage to the electronics and/or metal-to-metal rubbing of the units.
-- Aaron
Old Mar 13, 2004 | 12:18 AM
Omicron's Avatar
Not a bad idea.
Old Mar 13, 2004 | 01:45 AM
brothervoodoo's Avatar
RainMan is Back
When I hear the word foam, dissipating heat does not come to mind. Can't tell from your description whether the foam woud trap heat or block air flow?
Old Mar 13, 2004 | 01:55 AM
neit_jnf's Avatar
Be carefull with heat! The PCM needs proper air cooling, the foam acts as an insulator, it may be bad for the heat dissipation of the electronics.
Old Mar 13, 2004 | 03:28 AM
emailists's Avatar
I think it is a great idea to shock mount in between the ecu's- - however just using 4 small squares of foam in the corners will shock mount and allow air to flow. I think I'll try that once my CZ unit comes in in the next few weeks.
Old Mar 13, 2004 | 05:49 AM
RX-8 friend's Avatar
If you look critically at the stock "cooling system" in the PCM box, I think you will agree "cooling" is not an applicable description. They rely on air to air heat transmission through plastic. Plastic is not known as a great conductor of heat.
In our experience the PCM gets "warm", not hot. I doubt there will be a problem.
Old Mar 13, 2004 | 01:13 PM
Genom's Avatar
Not so Super right now
ALso, personally I prefer the 4 small adhesive rubber feet to separate them and allow airflow vs foam.
But it is something I thought about and tried to prevent :D
Old Mar 13, 2004 | 02:28 PM
Omicron's Avatar
I used an old Krispy Creme donut in mine.
:D
Old Mar 13, 2004 | 03:53 PM
emailists's Avatar
Omicron, what kind of donut did you use? I am thinking of using whole wheat since is is denser than a traditional flour unit. I also believe the center hole will provide the necessary airflow, and Canzoomer should update his install directions to include this mod.
Old Mar 13, 2004 | 04:17 PM
Omicron's Avatar
Of course, I used whole wheat. Actually, glazed whole wheat, as I found the glazing anchored it well to the ECU and CanZoomer unit.
:D
Old Mar 14, 2004 | 11:52 AM
islandsoon's Avatar
I used a 3" long pc of adhesive one side weather stripping foam, running front to back, between the two units to absorb some of the vibration. This stuff is about 1/2" thick, uncompressed.
Old Mar 15, 2004 | 04:04 PM
CanZoomer JR's Avatar
We did not think of this because we have no krispy creme's in Edmonton. You must send us a box so as we can test this mod. perferablly fed ex over night in an air tight container.
Old Mar 15, 2004 | 06:59 PM
Racer X-8's Avatar
Coming thru in waves...
I plan on using two -uh- feminin napkins, one on top, one underneath the mod.
With wings, of course.
Old Mar 15, 2004 | 10:02 PM
Omicron's Avatar
buuuuHAHAHAHAHAHHA!!!!!!!!!!!!!!!! :D :D :D
Old Mar 16, 2004 | 10:53 AM
You'll want the extra leak protection of course.
Old Mar 16, 2004 | 11:02 AM
shebam's Avatar
Bebop driver
Er, I seem to recall my unit already having some small rubber feet that should cushion shock and allow air in between the boxes. But it's home on my dining room table at the moment (not re Krispy Kreme). Do I recall right or am I Just Whistling Dixie?
Old Mar 16, 2004 | 01:43 PM
moRotorMotor's Avatar
Rotary eXperimental-8
I think Tim Hortons' Tim Bits would work great on each corner of the ECU, since we don't have Krispy Creme here in Canada. :D
Tip: Don't use the jelly filled Tim Bits.
Old Mar 16, 2004 | 02:47 PM
You are right there are rubber feet.
Old Apr 17, 2004 | 10:51 AM
Roadrunner's Avatar
Received my Stage 1.1 on Friday, was ordered on January 14. I have an appointment for PCM Flash on Tuesday so I will wait until then to install.
FYI....My unit did not have rubber feet on the bottom. I will purchase locally. I informed the Canzoomer crew.
gwailo
May 14, 2024 06:57 AM
mariohardleft
Feb 6, 2016 12:59 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
chris424
Sep 2, 2015 10:18 AM
