Is there a dyno sheet on the K&N intake??
Old Mar 2, 2004 | 07:26 PM
my10ae's Avatar
Moderator
Troy:
Does that dyno graph show the power gains with an auto? If so, then we don't lose much HP if in fact the auto is rated at 197HP and you are getting 187.3 without the intake. Let me know if this is true.
Thanks...
Old Mar 2, 2004 | 10:10 PM
Gord96BRG's Avatar
Originally posted by JeupRX-8
Okay... This is only my speculation, but here it goes.
There's a couple of problems with that theory:
- The port configuration and intake manifolds are very different between the 4 port low-power engine and the 6 port high power engine. It is NOT a valid assumption that the two engines make the same power at 7500 rpm.
- It's not just a different between auto and manual - Mazda sells the low-power engine with a 5 speed manual transmission in markets outside North America as the Base model. The simpler engine and 5 speed transmission are less expensive to manufacture.
In other words - by all means dyno your car, but don't get your hopes up!
Regards,
Gordon
Old Mar 7, 2004 | 12:31 AM
zerobanger's Avatar
adkdai8e dkadloi98
I love when these companies post dyno sheets of their own product and you guys get woodies. Until I see an independent dyno I call BS on all of them. We have one vendor that claims 9 HP from a freaking pulley.
on a sidenote I have dynoed my rx-7 at ATP they are a cool shop.
Old Mar 7, 2004 | 01:07 AM
rotarygod's Avatar
The gains that the K&N system show seem to be in a very usable range for the standard. If a car makes peak power at a certain spot why would anyone want more power here? It may look nice on paper but it is irrelevant. If the biggest power gain is over a range it makes much more sense to put the gain where it is most usable. This seems like a very usable range. If we get all of our gain above 8000 rpm but shift at 9000 rpm then that wasn't very much usable extra power. If we shift at 9000 but need power after 6000 rpm then having a range that is focused towards the middles of the range seems like a far better deal. Peak power sells product and looks good on paper for advertising reasons. Average power through the usable powerband is what makes you noticably faster.
As already stated here and I've said in the past, the 4 port engine is in no way comparable to the 6 port engine. that is like comparing a Ford 4.6 to a Chevy LS1 on the grounds they are both V-8's. The gains that are made on the 6 port will not necessarily give any gains on the 4 port engine. They may give less. They may give more. Whatever the outcome you can't base gains off of one style engine and automatically assume it will be the same on another. Even if there were huge gains in the 7300-7500 rpm range on the auto, where will the torque converter keep the engine at most of the time? Even if this were on a standard equipped engine the power gain is worthless since you are going to shift at 7500 rpm anyways. In this case you would want to gains centered in the mid 6000 range somewhere for best average usable power.
Old Mar 7, 2004 | 10:05 AM
pp13bnos's Avatar
Pineapple Racer
Have any outside sources finished a back to back dyno, comparing the stock vs. K&N/RE? I have'nt seen one as of yet....but If I'm wrong please provide a link for me. :D CJ
Sato Tatsuya
Oct 5, 2015 03:09 PM
Zube6115
Sep 30, 2015 12:57 PM
XianUnix
Sep 29, 2015 03:48 PM
Jb4ker96
Sep 27, 2015 10:06 PM
