Airbag Recall Fix
Old Feb 25, 2004 | 03:00 AM
MrDave's Avatar
Airbag Recall Fix
Just thought I'd let everyone know what to expect with regards to the airbag replacement. Seems they just needed to replace a faulty cable on my 8. The dealership originally thought it would take 3/4's of the day (being this was the first one they had done) but it ended up only taking about 90-120 minutes. And yes, I did get a free rental out of it as well.
Old Feb 25, 2004 | 03:07 AM
93rdcurrent's Avatar
The Stickinator
I think my dealer only took like 20 minutes. They billed it on the invoice at .20 hours. It could be that it took less than 15 min. now that I am looking at it? Who knows. I dropped it off at 9:30 am and it was done at lunch time. Good enough for me.
Old Feb 25, 2004 | 09:42 AM
RX-GR8's Avatar
did you guys get the recall for the heat shield done too?
Old Feb 25, 2004 | 09:57 AM
Shocka's Avatar
WHAT.... YEAH... OK!
they refuse to take me in until i get a letter from mazda.
Old Feb 25, 2004 | 10:03 AM
RX-GR8's Avatar
i bet thats what my dealer will say too. thats why im not calling until i get the letter.
Old Feb 25, 2004 | 10:10 AM
G8rboy's Avatar
Mmmmm... Rotary Donut
I'm scheduled for this Monday- they said to expect about 30 minutes or so. They had no problem doing once they had all the ones on the lot taken care of first, which they were doing this week.
BTW, if you haven't already- sign up for "MyMazda" at Mazdausa.com... you put in your VIN# and it keeps you updated on when you need to do maintenance, if there are any TSB's or recalls associated with your RX8. They had the airbag recall listed for my car the day the news broke last week- before most of the dealers knew. All you should need to do is print that out and walk into your dealer...
Old Feb 25, 2004 | 10:14 AM
Shocka's Avatar
thanks i will def do that tonite when i get home. too bad i dont carry my vin number around with me. (the car is not here at work with me so dont say get it off the car)
Old Feb 25, 2004 | 10:15 AM
winter's Avatar
They've kept mine overnight to do the TSBs, as well as reflash the ECU and replace a leaky taillight.
Old Feb 28, 2004 | 01:27 PM
Katchoo's Avatar
I brought mine in for the first oil change and mentioned the air bag thingee to them. They did the whole job (oil and air bag wiring) in 30 minutes.
The dealer said it takes about 10 min to do the wiring.
And yes...they DID use 5-20 oil and DID replace the engine cover (made sure of that before I left the lot).
Old Feb 28, 2004 | 01:52 PM
Doctorr's Avatar
Ricer is Nicer.....
Cool Air bag fix.....
The actual fix for the air bag recall is tiny....
They drop the glovebox, undo a wiring connector, then put in a short extension piece between the two ends, and clip it back in place.
Ten minutes, tops.
doc
Old Feb 28, 2004 | 01:53 PM
Oranje's Avatar
JM1FE
In on Thursday night to drop off the 8 and pickup free loaner.
Service guy asked if I received the letter/s. No letters here ... and no problem. They completed both the airbag and damper work and had it ready for a rental/8 swap at lunch on Friday.
Oranje
Old Feb 28, 2004 | 03:06 PM
cruzdreamer's Avatar
ok...I have not even heard of a recall for anything.....guess I have not read all the threads lately. Nothing in mail for me yet. Are all the Rx 8's on the list or just a certain batch? Pardon my ignorance.
theblinkof
Oct 4, 2023 05:24 PM
Danield97
Sep 30, 2015 05:59 PM
DeltaJ802
Sep 29, 2015 01:20 PM
drlubell
Sep 26, 2015 11:58 PM
