DIY: Heat / Air Conditioning Quick Fix
Old Apr 30, 2011 | 10:20 AM
FungsterRacing's Avatar
Hibernating -.-
Lightbulb DIY: Heat / Air Conditioning Quick Fix
OK, so many of us have had the problems with either the heat not working, or the cold / air conditioning not working. There are a LOT of great DIY's on how to fix these problems, but I thought I would post my "Quick Fix" for how I am currently changing from cold to hot when the car decides not to on its own.
It's very simple - If its blowing cold and you want hot, turn it to hot, and hold it on hot as far as you can (Put pressure in that direction to where you cannot spin anymore, it will actually be able to go slightly more than if you were just putting it to full hot). If you hold it like this for a few seconds, it will start blowing hot. Letting go right away will not solve the problem though, you will have to keep holding the **** turned to the max for a period of time - I have had to hold it for sometimes 10 seconds, sometimes a little longer.
To do the exact opposite for temps, follow the exact same directions.
Basically, when you put it to hot/cold and the temp doesn't go there, you can turn the **** manually just a slight bit more, but the **** will not hold itself there, which is why you have to hold it. This little trick has been working for me since I bought the car.
Hopefully this isn't a re-post, but, to be perfectly honest, I never read through ever single thread on this issue to see if the OP used the same method or not. Hopefully this works for you though! Good luck!
EDIT: I will be posting a video here within a day showing how I do it. Obviously you wont be able to (Hopefully not) feel the heat / cold, but it will give you a better idea of how its working for me.
Old Apr 30, 2011 | 10:36 AM
BoosTED's Avatar
In addition to this there is climate control operating instructions in the RX-8 owner's manual. See index for page.
Old Sep 9, 2011 | 02:05 PM
theDmister's Avatar
Are you guna eventually flush the heater core? I am having the no heat problem in my 8 too im guna try the quick fix you posted but i also wana fix the problem the right way. Also i am guna make sure the temp gauge isnt broke because thats like a 10 dollar fix. Problem is i dont know where that is located in the 8. Any ideas?
Old Sep 9, 2011 | 04:41 PM
Bullitt's Avatar
In the pipe five by five.
This will work for a while, but eventually, I think you're going to have to resolder it.
Billy Marcial
Mar 1, 2018 06:50 AM
akagc
Aug 11, 2015 07:07 PM
dbarber
Jul 25, 2015 01:34 PM
Ryosuke-
12
Jul 24, 2015 12:51 PM
AussieGray
Jul 16, 2015 03:58 AM
