Odd brake wear
Old Apr 23, 2011 | 06:43 PM
skc's Avatar
skc
rev it up
Odd brake wear
I just got all my brake pads replaced and I noticed that the rears had greater wear than the fronts.
The front rotors are slotted project mu and rear was factory. The pads where project mu HC+.
Normally, the front brakes do most of the work so you would expect more front pad wear. You would also expect more wear on the front due to the slotted rotors. I have just replaced my rear factory discs to slotted as well and now I am worried that the rear wear will accelerate.
Does anyone have any thoughts on this puzzle.
I track my car around 6 times a year and use the car on the street approximately once a week. I also run tein monoflex coil over suspension.
Old Apr 23, 2011 | 07:15 PM
majjic's Avatar
Hand brake ajustment would be my first check.
Cheers
Old Apr 24, 2011 | 02:28 AM
skc's Avatar
skc
rev it up
Hand brake adjustment should be ok. I change my tyres often due to track work and the wheels and hub seem to spin freely without any rubbing sound.
Old Apr 24, 2011 | 05:14 AM
Cromax's Avatar
Buzz Buzz Buzz
When you use your brakes with the traction control & edc programs completely off, do you find the car a bit tail happy?
(If you haven't done this before, hold the edc button down for over 10 seconds)
Old Apr 24, 2011 | 09:19 AM
The question is are the Project Mu pads same compound front and rear....or are the rears potentially a different slightly softer compound??
I find on track that the fronts wear faster than the rears in about a 2-1 ratio with the same compound front and rear
Old Apr 25, 2011 | 01:39 AM
Cromax's Avatar
Buzz Buzz Buzz
He's told us that his fronts are project mu and rears are stock ...
Old Apr 25, 2011 | 02:32 AM
skc's Avatar
skc
rev it up
The pads are project mu HC+ front and rear and the rotors where project mu front and stock at the rear.
Old Apr 25, 2011 | 02:39 AM
skc's Avatar
skc
rev it up
I usually leave my traction control on as Lakeside raceway is not very forgiving if you come off.
However, I think by leaving it on I think it causes the brakes to activate and it could be the cause of the extra wear in the rear. I can feel it coming on on the undulating back straight.
I may have to lessen the damping force at the rear suspension even more to allow better traction.
skc
Old Apr 25, 2011 | 07:23 AM
MACCAA's Avatar
Just double check that they're the same compound front and rear.
We've found that the alternate project mu pad wears a LOT more than the harder compound.
Having said that,as the RX8 is 50-50 weight distribution,the rears do more work than on most cars,but not enough to show the sort of wear that you're encountering.
Be interested to see the difference in wear with a change of disc.
Some aftermarket pads exhibit rapid wear on some sorts of discs for no apparent reason.
And yes,soften the rear suspesion a tad to improve traction-you may need this soon......
Cheers
Len
Old Apr 25, 2011 | 06:38 PM
skc's Avatar
skc
rev it up
I had ordered everything from Rick Shaw and I am sure they where all HC+ all around.
The front spring are 10kg which means less dive. This may mean the rear brakes will have to work a bit more than usual. By the way, excessive wear was not that pronounced between front and rear. The differance was that the rear was metal to metal and the front had about 2mm left on the pads.
So, you could say they nearly wore out evenly. However, you would normally expect more wear to the front due to weight transfer and the slotted rotors.
skc
Old Apr 25, 2011 | 10:43 PM
t99's Avatar
t99
Sounds fairly normal. You may find that as the rears are a fair bit smaller, there is a bit more heat there seeing you are running aftermarket suspension and more importantly, R-spec tyres. Your suspension will probably give the car a bit less dive (as you suggested) and so you can get more braking effort in before one end locks up, or even under ABS.
hufflepuff
May 30, 2016 10:45 AM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
