opening airbox
Old Feb 18, 2004 | 11:15 PM
Rx8luv's Avatar
Exclamation opening airbox
does anyone have any suggestions for opening the airbox? opening the two clips on the front only allows the box to be opened like 1/2". After loosening the intake hose, the box tilted back a bit more, but appears to run into some electronics on the battery. Is it hinged at the bottom or just hooked?
Old Feb 19, 2004 | 12:51 AM
Omicron's Avatar
It pretty much has to be removed. Check the tech section for several threads about this. It's pretty easy to do once you know how, and once you've got it out, it opens without problems.
cliffkemp
Dec 24, 2024 10:48 AM
Evan Gray
Nov 24, 2015 01:00 AM
Danield97
Sep 30, 2015 05:59 PM
GK1707
Sep 27, 2015 07:33 PM
