2010 rx-8 r3
Old Apr 22, 2010 | 08:56 PM
Schlumph's Avatar
2010 rx-8 r3
I recently purchased the 2010 RX-8 R3 (sparkling black mica) model from our local Mazda dealer here in a place that is as far east as you can get in all of North America. As a result, there are only a handful of RX-8's here, and my 2010 so far is the only one of that model year in this Province. The dealer at most only gets one or two of these per year; That makes for a pretty unique ride on our local streets here in Newfoundland :D
The down side to this uniqueness became apparent to me when I had the first service check done by the dealership and they did not even have a filter for an RX-8 in stock! Custom order So, when I started to inquire about performance modifications, all the red flags (same ones I read about here regarding warranty) start to come up. I suspect however that some of those red flags are the result of their inexperience with the RX-8.
Anyway, the question I need some help with is with respect to the Mazdaspeed performance accessories. I know these are more expensive, but specifically, are the Mazdaspeed performance parts, such as the cold air intake and the dual muffler sport exhaust compatible with the 2010 model? The current version of the Mazdaspeed accessories brochure for the RX-8 confirms compatiblity with the 2009 (specific part numbers), but are these 2009 parts also compatible with the 2010?
Current version of the Mazdaspeed accessories brochure (recently updated):
http://www.mazdaspeeddevelopment.com/pdfs/msacc.pdf
Appreciate any input you can offer.
Old Apr 22, 2010 | 09:30 PM
Chad D.'s Avatar
Spinnnnnnnnnnn
I was told at the stealership on the weekend that even if it is mazdaspeed, if it has a yellow triangle sticker on it your warranty is void.
fthat. Just make sure you keep your stock stuff just case,
Old Apr 22, 2010 | 09:32 PM
REsuperD's Avatar
zoom zoom
yes
'09 and '10 cars are identical, except minor trim/equipment/available color differences, and the deletion of the "mazda" badge on the back (i think)
and congrats on your purchase!
Old Apr 23, 2010 | 12:56 AM
RX8pwnage's Avatar
RX8. Yeah, I get it.
i wasnt aware of a MS exhaust for series 2. Last i looked at their website all they had was the 04-08 catback.
Old Apr 23, 2010 | 12:58 AM
laythor's Avatar
I zoom therefore I am.
mazdaspeed parts warranty info
Mazdaspeed Warranty info
Search Category
Mazdaspeed "Blue" performance accessories must be installed by a MAZDASPEED Dealer on a US specification vehicle and be specifically approved by Mazda for the particular application. These parts are covered under the Mazda Replacement Parts and Accessories Limited Warranty and are warranted for the first 12 months/12,000 miles from the date of installation or the duration of the New Vehicle Limited Warranty, whichever is longer. Should the parts be purchased but not installed by a MAZDASPEED Dealer, they will be covered for the first 12 months/12,000 miles from the date of purchase, excluding labor charges. Parts or accessories replaced/installed under warranty are covered for the time remaining in the New Vehicle Limited Warranty.
MAZDASPEED "GREEN" Performance Accessories must be specifically approved by Mazda for their particular application. These parts are warranted for the first 12 months/12,000 miles from the date of purchase, excluding labor.
MAZDASPEED "Orange" Performance Accessories are sold "as is" without any warranty of any kind. All implied warranties, including all warranties of merchantability of fitness for a particular purpose, are excluded. Purchaser acknowledges that no representations have been made regarding these parts, including but not limited to any representations as to their quality of performance, and the purchaser shall be responsible for and bear all costs of repair of replacement to any defect in or failure of these parts or any damage to other components. Purchaser acknowledges that vehicles equipped with MAZDASPEED "Orange" Performance Accessories shall not be operated on public highways. MAZDASPEED "Orange" Performance Accessories are intended solely for the use on vehicles participating in race/off-road competition events. Purchaser acknowledges that all Mazda vehicle/parts/accessory warranties are voided if the vehicle is used in a competition event. Purchaser also acknowledges that there will be no warranty coverage for any part or accessory that fails as a result of the installation of a MAZDASPEED "Orange" performance part. Purchaser accepts all responsibility for all vehicle modifications and all potential risks. MAZDASPEED "Orange" Performance Accessories have been designed and are intended for race/off-road applications only. Federal and many state laws prohibit the removal, modification of, or rendering inoperative any part of vehicle system affecting emissions or safety.
What is not covered. Damage or corrosion due to accidents, misuse, or alterations. Damage or surface corrosion from the environment such as acid rain, airborne fallout (chemicals, tree sap), stones, salt road hazards, hail, wind storm, lightning, floods and other natural disasters. Normal wear, tear or deterioration such as discoloration, fading, deformation, blurring, ect. Replacement parts or accessories installed on any Mazda vehicle registered or normally operated outside of the United States, Canada, Puerto Rico, US Virgin Islands, Guam, Saipan or American Samoa. Replacement parts, or accessories installed on a Mazda vehicle in which the odometer has been altered, or on which the actual mileage cannot be readily determined. Replacement parts or accessories used in applications for which they are not designed. Replacement parts or accessories installed improperly by dealers, Importer/Distributor other than Mazda. Any replacement part or accessory without proof of purchase or replacement date. Non-Mazda replacement parts or accessories which Mazda Dealers may sell or install on your Mazda vehicle. If the vehicle has been classified a total loss and/or sold for salvage purposes or branded for any other reasons. Removal of the vehicle from the warranty covered market for which it was produced.
Old Apr 23, 2010 | 07:28 AM
REsuperD's Avatar
zoom zoom
the op said he/she saw some kind of cross-reference form them to '09 cars, but yeah i dunno about that; as far as i know the only exhaust for '09+ available comes from racing beat one
the mazdaspeed/aem cai works on '09+ tho
Old Apr 23, 2010 | 10:04 AM
Schlumph's Avatar
Ok, now this is weird. Yesterday I downloaded what appeared to be a brand new accessories brochure from the Mazdaspeed Motorsports Development website and today it has changed back to the old one. To prove it, here are a couple of pages right out of the new one. Note the different part number for the dual muffler exhaust for the 2009 RX-8.
Old Apr 23, 2010 | 10:33 AM
ccd's Avatar
ccd
I thought the R3 is only offerred in blue and red in 2010 and that black was only offerred in '09
Old Apr 23, 2010 | 10:43 AM
RIWWP's Avatar
R3 color options are HEAVILY based on where in the world you are. WWP R3s are available in Canada and UK, but not red I think. US is red and blue, I didn't know the black mica was an option for the US at all, but since he is saying he is in Canada, I assume WWP and Black Mica are their R3 options.
I wouldn't be shocked to hear that other color combinations are possible elsewhere in the world.
Gratz on the purchase!
That certainly looks like a green warranty notation, which means that the exhaust itself only has a 12m 12k warranty, but there is no mention that it voids any of the rest of the car's warranty.
Even the orange items appear to mean that they have no warranty at all, and if that part caused the failure (which they would have to prove) of an OEM part, then the OEM part loses it's warranty as well. The "void all warranties" is from participating in track events, which orange items should only be used in. They aren't directly saying that orange items voids all warranties, but it would probably require a lawyer to get them to cover oem parts with orange items on the car.
I still say you are safe getting the Mazdaspeed exhaust, though make sure your dealer agrees with you before you purchase and install
Old Apr 23, 2010 | 11:25 AM
REsuperD's Avatar
zoom zoom
that is correct for the us. in '09 r3 was available in vr, aurora blue, and bb. bb was dropped in '10. in japan, r3 (or type rs) is also available in wwp and sparkling black mica, maybe even other colors. in the uk, wwp is also available. i dunno why they're so varied, but given so few r3s are sold here, it probably doesn't really matter anyway
and it does look like from that catalog that mazdaspeed has an exhaust for '09 cars
Old Apr 23, 2010 | 11:32 AM
RIWWP's Avatar
I'd trade in for a WWP R3 if they were sold here. Seriously.
Old Apr 23, 2010 | 12:03 PM
neofreak's Avatar
I gave up and sold my white 05 GT for a white 09 GT, I figure I can swap the bumpers later and well, the seats don't matter *that* much.
Old Apr 24, 2010 | 12:53 PM
minhty's Avatar
He is right.
Old Apr 27, 2010 | 11:09 PM
smog-guy707's Avatar
ohhhh nice car, one of my neighbors has one
Old May 1, 2010 | 09:04 AM
Schlumph's Avatar
Appreciate the feedback from everyone, and as a result am in the process of ordering the following Mazdaspeed parts for my 2010 RX-8 R3:
  • Cold Air Intake: GRMS-8M-K50
  • Sport Dual Muffler: GRMS-8M-K11
These are the 2009 part numbers and understand these are compatible with the 2010. I'll report back here the results of the order and install. Given the cost of the Mazdaspeed parts, I think that's about all my wife is going to let me do for this year :D
Old May 1, 2010 | 03:14 PM
kenpo1441's Avatar
Just buy a white one and make it into an R3...there really isn't that much difference. Plus since they sell a white one in Japan you can get all the parts pre-painted.
Old May 1, 2010 | 04:14 PM
Chad D.'s Avatar
Spinnnnnnnnnnn
They also sell white r3's in Canada
Old Oct 8, 2010 | 11:40 AM
jrx13's Avatar
Did you ever get these part numbers to work?
-Jack
Old Nov 6, 2010 | 02:07 PM
speedy36's Avatar
Also here in the uk Crystal white R3's
Not that common over here thank goodness........I like being stared at
Old Dec 22, 2010 | 04:05 PM
Twisted_grip's Avatar
Love the white color!
Old Jun 1, 2014 | 05:33 PM
Hartness5265's Avatar
How did those parts install and work??
Curious to if you liked your choices and if the install was compatible with the 10'
Old Jun 1, 2014 | 05:59 PM
Gravey's Avatar
Unruly Newb
Good rez! this was 4 years ago, chances are that they are no longer around.
Old Jun 2, 2014 | 10:19 AM
09rx's Avatar
Part numbers are no longer good.
BillBertelli
NE For Sale/Wanted
Mar 19, 2016 03:01 PM
Brokegang
Jan 3, 2016 12:45 PM
9krpmrx8
Oct 13, 2015 01:36 PM
Chapsy
Sep 22, 2015 09:57 AM
Tsurugi
Sep 7, 2015 08:27 PM
