Header / Midpipe Gasket Question
Old Mar 29, 2010 | 08:58 PM
learycd's Avatar
Hold DSC for 7 Sec
so definitely have a leak between my midpipe and header. I reused the crush gasket (it look like it was in good shape). My question is, has anyone tried using a 3 bolt crush gasket like this one instead?
http://raceroots.com/index.php/produ...et-3-bolt.html
or the remflex product
http://catalog.remflex.com/FORD_Head...p/pt55-002.htm
they look kinda similar?
so i guess the question is, do they work better?
thanks guys
Old Mar 30, 2010 | 09:01 AM
learycd's Avatar
Hold DSC for 7 Sec
no one has used this type of gasket??
Old Mar 31, 2010 | 03:46 PM
learycd's Avatar
Hold DSC for 7 Sec
anyone with ANY insight? i really dont wanna waste 30 bucks for no reason
Old Mar 31, 2010 | 09:49 PM
The only gasket thats re-usable is the Engine to Header Gasket, and of course it has to be in good shape.
All other gaskets should be replaced
Old Mar 31, 2010 | 10:17 PM
quazmosis's Avatar
Chode
I'll second that.
Old Mar 31, 2010 | 10:22 PM
The Reverend's Avatar
That's a lie
I just picked up the gasket from Race Roots for this exact reason. I'll let you know on Friday how it works
Old Mar 31, 2010 | 10:26 PM
Jon316G's Avatar
Grasshopper
Me and another local use that gasket.
It was supplied with our MazSport midpipe.
Works great and never had a problem reusing it.
I keep the OEM gaskets on my cat for when I need to swap it for e-check.
Old Apr 1, 2010 | 09:30 AM
olddragger's Avatar
you can reuse it but be very careful---the carbon becomes fragile after being crushed
it works but i still have to retighen my collector bolts from time to time.
Damn that Ford gasket looks just like it!
Old Apr 1, 2010 | 11:57 AM
I dont understand ...
people can afford mid pipes and other crap. but they just being cheap on buying a new gasket ?
I dont understand the logic behind this ... seriously ...
Old Apr 8, 2010 | 10:18 PM
learycd's Avatar
Hold DSC for 7 Sec
just as an update, i got my old cat out and measured the bolt pattern, this gasket from remflex WILL FIT the rx8 flange
http://catalog.remflex.com/COLLECTOR...t_p/rf8046.htm
...and being cheap and throwing money away are two different things!
Old Apr 8, 2010 | 10:20 PM
learycd's Avatar
Hold DSC for 7 Sec
i just ordered mine from remflex, its the same one. would love to hear how it works
Old Apr 14, 2010 | 04:15 PM
silverbullet05's Avatar
just ordered the same remflex gasket for an exoticspeed cat. hopefully if fits!
Old Apr 14, 2010 | 05:16 PM
learycd's Avatar
Hold DSC for 7 Sec
it should fit, if not u can easily use a drill bit to open the hole 1/16 of an inch or so!
Old Apr 15, 2010 | 10:16 AM
great to hear. did you happen to use any other gaskets from them for the rest of the exhaust?
Old May 3, 2010 | 09:45 AM
got the remflex 3 bolt gasket installed. fit like a glove and since it came as a 2 pack i have a spare if i ever need it =)
Thanks again learycd
Old May 3, 2010 | 10:16 AM
learycd's Avatar
Hold DSC for 7 Sec
no problem, def seems like the better deal out of the two, especially with the two pack
all my suby buddies swear by these the brand too, fixed all their leaks (turbo, cat, exhaust)
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
jorx7
Sep 29, 2015 04:54 AM
DVerdeyen
Sep 13, 2015 11:19 AM
Rupanrx
Sep 4, 2015 06:44 AM
