Power loss
Old Mar 19, 2010 | 12:14 PM
xtremetreadwear's Avatar
Power loss
Last year I had a condition with my engine where one of the rotors would intermittently stop producing power completely. It would only happen at high RPMs under heavy load. After changing the ignition coils, wires and plugs it went away and I concluded that was the problem. Its been in storage all winter and now the problem is back again. However it is significantly less often and seems to only happen when the engine is below normal operating temp..
I'm about to go and clean off my plugs and fiddle around with the MAF, see if I can find an obvious problem. Anyone have any ideas on what else I could check?
Only performance (or should i say acoustic ) upgrade is a K&N filter, so there shouldn't be a mod interfering.
Old Mar 19, 2010 | 12:30 PM
Silverisk8's Avatar
There are plenty of threads allready with the same issues, search a bit more you'll find the answer
Old Mar 19, 2010 | 12:36 PM
Ok I'll do that quick
Old Mar 19, 2010 | 01:29 PM
After searching, looks like people don't have the same problem that I do. Many come close. I'm thinking this could be my cat going. Off to the vendor forums I go!
Old Mar 19, 2010 | 02:12 PM
Silverisk8's Avatar
Bingo !!!!!
RevMeHarder
Jun 1, 2026 02:30 PM
gwailo
May 14, 2024 06:57 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Trekk
12
Sep 25, 2015 03:08 PM
Draken
Sep 21, 2015 06:14 PM
