check engine light/oil light
Old Jan 23, 2004 | 12:47 PM
blt's Avatar
blt
Angry check engine light/oil light
i have had three occasions now of my check engine light coming on, two of which have also come with the oil light flashing on as well. already had the oil pan replacement done on the first flash. the dealer told me when they were updating the program this time i was down a quart and a half of oil. i have read about the ce light coming on in other posts but are any of you having the oil problems i seem to be having or am i alone on this one?
Old Jan 23, 2004 | 06:24 PM
breezy_rx8's Avatar
I have had mine pop on and off on a few different occasions. As long as its off, I'm not too worried about it. I regularly check the oil and if anything did go wrong, we got warranty
Old Jan 24, 2004 | 02:19 PM
Speedofheat's Avatar
Mine was doing the same thing so I contacted my dealer who was well aware of the problem. Though my "three" day fix is now pushing a week.........
Old Jan 25, 2004 | 10:44 AM
KRZY1's Avatar
I talked to the service manager at a Mazda dealer and he told me that every 1,500 miles, you have to add a quart of oil to your vehicle.
Old Jan 25, 2004 | 04:15 PM
RX-jimenez's Avatar
mine came on yesterday, when i hit the 1100 miles, ????? it comes on and when i rev itup it goes off, what the hell is this i check my oil and it full...........??????
Old Jan 25, 2004 | 08:31 PM
RX-jimenez's Avatar
i am looking to my sticker price, and i found that mine was one of the first in the dealership, it still say 247hp..... and i don't know if they replace the pan oil, i will find out monday for sure, but my oil light comes on too......
Old Jan 25, 2004 | 09:31 PM
winter's Avatar
Had a similar incident just now. Was getting on it (about 7k rpm) and the check engine light started to flash. After about 5 seconds, it stopped flashing and stayed off. Oil level is fine, car seems okay. Suppose I'll get the dealership to pull the code when I go in for the free oil change.
Old Jan 26, 2004 | 09:16 PM
dunsfoda's Avatar
my oil light has come on and has not turned off ...ever!! I had mazda tow it away 2day to check out the problem......plenty of oil in it.
Old Jan 26, 2004 | 09:44 PM
RogueRX8's Avatar
I am not looking forward to having to pay for oil on top of preium gas.
Old Jan 27, 2004 | 09:49 AM
Elara's Avatar
Since it costs all of $2 a quart, I don't think that's going to be much of an issue for you :p. I'm at 9k miles and I've added all of 2 quarts (if you don't include the oil change) to my car.
Old Jan 27, 2004 | 10:20 AM
o_town_racer's Avatar
If you can afford the car, the gas, and the insurance, I'm sure you can afford a quart of oil every 3K miles.....
Old Jan 27, 2004 | 10:24 AM
Sea Ray's Avatar
You guys need to go to the Tech forum and read up on the TSB where it will tell you about the oil pan replacement and other notices.
As for adding a quart every 1500 miles, learn to read your dipstick! It's doubtful you will need that much but checking your oil ever other fillup is not a bad habit to get into, regardless of what kind of car it is. If you just add a quart at 1500, chances are you will over fill it which is as bad as being under.
Old Jan 27, 2004 | 10:29 AM
umpuck's Avatar
The only light that occasionally comes on is the engine coolant light. it comes on when i start the car up in the morning. and the weather is cold btw. It'll come on and go away when the engine has been running for a few minutes
Old Jan 27, 2004 | 09:18 PM
red_rx8_red_int's Avatar
My coolant low light came on for the first time tonight at start up in my work's garage. It was about 20 degrees F. Ihad never seen this light before, but it went out within seconds and I looked it up in the manual when I got home. I was way short of the L mark. Added about 1 quart of antifreeze. My heater has always been lackluster so I hope this improves heater performance. I'll find out tomorrow.
Old Jan 28, 2004 | 03:05 PM
Just run 87 octane.
vapor2
Nov 3, 2020 03:38 PM
Skyl3r
Dec 2, 2019 04:51 PM
akagc
Aug 11, 2015 07:07 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
