Piggy back units ???????
Old Jan 22, 2004 | 10:10 PM
Lock & Load's Avatar
Is it possible that if a REVISED PiGGYBACK unit is placed on a stock ECU it takes time / extra kilometers to download all its revised information to the stock standard ECU ?????????????
Michael
Old Jan 22, 2004 | 10:45 PM
Z88M's Avatar
I don't believe so, it is just re-mapping the air/fuel ratio coming from the stock ECU. There is no download to the stock ECU. Because the install involves disconnecting the battery and an ECU reset the following is required (from Maurice):
"Drive for 5 minutes in normal manner to allow the ECU to re-learn sensor and driving conditions."
CZ1 issue? Switch turned to "on" position ;-)
Old Jan 23, 2004 | 12:45 AM
Hymee's Avatar
Race Steward
L&L,
There is no "download of information". The piggy back is intereting the MAF signal from the engine, and telling the computer something different is happening. That is how most piggy backs work. One of the earliest was to put a resistor on the MAF or the temp sensor. This tricked the computer to think the engine was at different conditions than it was, and put in more or less fuel, more or less timing. With a little bit of careful experimentation you could get more power under some circumstances.
Modern piggy backs are a little bit more advanced, allowing you to put different amounts of "trick" in at different points/conditions.
Ric Shaws piggy back does not trick the computer, from my understanding, but takes control of the fuel injector duty cycle, and ignition timing. I would be best to let Ric explain this himself.
Also, dont forget about Closed Loop and Open Loop. See https://www.rx8club.com/showthread.p...threadid=18833 if you want to have another read.
Cheers,
Hymee.
Old Jan 23, 2004 | 01:10 AM
jax8's Avatar
Do we dectect a twinge of absolute disappointment. L&L?
I fervently hope not. I took a wrx for a spin last night, after six weeks in the 8, and it illustrated just how much we need more grunt.
Are you there arn't a few un-connected wires from CZ's unit hanging out of the ECU box.? Or stuff you couldn't find a place for, so you chopped them off?
jack
Old Jan 23, 2004 | 02:10 AM
timbo's Avatar
rock-->o<--hard place
That's L&L and Hymee's conundrum, isn't it. By removing the earlier thread and locking down preliminary results, the obvious perception created is that CZ's unit does not meet expectations, at least in relation to Australian ECUs.
A classic information stand-off of the 'damned if you do (release the data) and damned if you don't'.
Despite being an early adopter in just about everything else, I am determined to sit back and wait in relation to performance mods. Hey, I can scare myself with what's underfoot right now :D
Old Jan 23, 2004 | 04:07 AM
rx8 - smooth!'s Avatar
aka Smoothy
Hi Guys,
WILL SOMEONE ACTUALLY SAY WHAT THE F*** IS GOING one WITH CANZOOMERS ECU PIGGYBACK.
This is meant to be a forum for the sharing of information. I for one really hope that this ECU upgrade works but if it doesn't it doesn't.
To quote someone else "Please explain"
Steve
Old Jan 23, 2004 | 07:16 AM
AMG's Avatar
AMG
trust me..this wont hurt
Basically...........CZ stage 1 works well on US cars.
Stay tuned.............
Old Jan 24, 2004 | 06:20 AM
Hymee's Avatar
Race Steward
That is absolutley correct. The results were published then removed, and can only cause -ve feelings. That is why I was against it, once the information was out. It is also why I published my findings, as emack had already posted his. In the end, it was an accidental deletion, and emack has appologised for that, and I hold no malice towards him. The problem was the embargo placed on re-publishing the information. I wonder if anyone has my extremely well written post still up, or in there browser cache
L&L, I am afraid you have probably already let the cat out of the bag (or the cat out of the can, or the zoom out of the can - hehehe). If you read between the lines of this, and the other related posts, it will become apparent.
Why would you be worried that "all the information" had not been downloaded to the PCM if your car now took off like a rocket (like mine does :p) Would it make any sense to withhold +ve info from the "public"?
I would recommend you ask CZ for his "permission" for me to openly publish my report ASAP. I am sure he will be very quick to answer in an appropriate and mature manner.
And since Australia is only a rounding error of a rounding error in terms of the world economy it is possible that it might not be worth the investment in an "Aussy Cal". But that is his decision, and rightly his perogative.
Cheers,
Hymee.
Old Jan 24, 2004 | 06:33 AM
AMG's Avatar
AMG
And I though modern democratic societies upheld the concept of freedom of speech.
Old Jan 24, 2004 | 07:15 AM
Hymee's Avatar
Race Steward
OK - To wet some peoples appetites, and to keep some people intrigued, here is a measured performance graph showing measured acceleration, and derived power. (Remember that power, acceleration, force, torque, time, mass and distance are all inextricably related to each other by the laws of physics)
Before you look at the graphs, This is NOT a test of the CanZoomer Mod other than the fact it is in the "OFF" position.
The data has been measured by an accelerometer and logging device. This is what the V8 Supercar teams use to great effect when doing real in-vehicle testing of the cars. You can get a Motec dash unit that has one in it. Mine is a MR Dyno
The data was recorded on the same day, on the same road, with averages shown. Runs done in both directions of the road. The test is performed by first getting the vechicle stable at 35km/hr in 2nd gear. Cruise control is great for this. The "test" is commenced, and the throttle is opened up fully. The data is recorded as soon as the vehicle reaches 40km/h, and continues logging 100 samples / second. Each sample has a 16 bit resolution (0.00025 Gs).
No launch variables or gear change variables come into the equation.
The "Hymee" vehicle is totally stock, including the "Stage 0 Hymee Tune" (sorry I couldn't resist that one).
The "L&L" vehicle is totally stock except, for all intents and purposes, as the Canzoomer Stage 1 box was "OFF".
The power plotted is dependant on the vehicle weight being accuratey entered into the device. I had mine weighed on a scale a few days before, and I can make an allowance for how much fuel there is. If you work it out, each 1/4 tank is about 10kg. L&L's car is the Leather Pack, so it already has a 30kg penalty over the Hymee Poverty Pack.
However, the G-forces observed are the actual readings.
The actual times for the runs are almost a full second different.
So I hear y'all ask "Why is Hymee's car quicker than L&L's". That is a good question. Here are some plausible explanations:
[list=1][*]Hymee's car is lighter[*]Hymee car was running BP Ultimate, L&L's was running Shell Optimax.[*]The cars might get driven differently - so they may have learned different fuel trims.[*]The Hymee Tune - Stage 0 is working well. Sorry - only joking again.[/list=1]
Anyway, something for you all to ponder while we wait for the OK from Mr Canzoomer.
Cheers,
Hymee.
Old Jan 24, 2004 | 04:31 PM
AMG's Avatar
AMG
Hymee, what about the frictional variabilities of yellow versus red duco's Doesn't red provide a better drag coefficient, hence red cars go faster.
Old Jan 24, 2004 | 05:22 PM
timbo's Avatar
Interesting. I reckon there's more in the "fuel trim" explanation than anything else, but it's beyond my expertise...!
Old Jan 24, 2004 | 06:47 PM
Kev's Avatar
Kev
[rapidus octus]
What about total milage, state of air cleaner, type of oil in engine???
If you have a dirty air cleaner, lower quaity oil, a lesser fuel...
Plus you need to reset the ecu on each car and carry out identical preliminary driving...
apples and apples guys!!
Plus there's the tyres (weight, tread and pressure) and not least the weight of the car.
My car has more sparkle with ultimate than any other fuel - that's just one thing. Add a different visc oil and two identical cars can suddenly be very different.
PS Was L&L's boot full of interesting bits?
Old Jan 24, 2004 | 07:26 PM
As far as i am concerned there are too many variables in different cars to start guesstimating Why one car may be 1 second quicker than another , over a 40- 100km range .
My cut out switch seems to have come in 10km earlier than HYMEES , for some reason .
My car is going to be looked at by a Mazda dealer this friday and i will see what they will say and do some test maybe my car needs to be tuned ???
Anyway if it improves Hymees SELF STEEEM / EGO and makes him feel better about himself .
At having his RED car beat my YELLOW car , i dont mind GOD knows i have AMPLE self steem / ego to go around .ha ha ha.
and after all hes a great bloke .
HYMEE you are a LEGEND ALL BE IT in your (own lunchtime ).HE .HE .HE..
Anyhow happy to give away 1 second on my car as i have the pleasure of starring all day and re reading the "WHEELS MAGAZINE" featuring the best colour for the RX8 LIGHTINING YELLOW BOTH ON THE FEATURE FRONT PAGE (WHICH I AM HAVING FRAMED ) AND 13 other glorious photoes of a yellow rx8.
HA .HA. HA .HE, HE. HE. WHOOPY. HOORAY.
Lets not mention all the extra goodies i have in my car as opposed to Hymees poverty pack red rx8 .(Hymee you have learnt to give it so you should learn to take it ) ment in the nicest possible way .
CHEERS
MICHAEL
Old Jan 24, 2004 | 09:04 PM
Hymee's Avatar
Race Steward
You might notice this was my first foray into the "yellow" versus "red" debate. It was all tounge in cheeck. It is just funny how some people react when the "truth" is told. People ask for "documented evidence". I gave what is as near the best as to what we can achieve with what we have, but it still is not good enough to some... It is almost impossible to compare 2 exactly the same apples.
Maybe I forget to mention the speed at redline issue between the cars. I performed a number of tests earlier when I went from 40 to 110. I just hit the cutout as 110 was reached.
In L&L's car it did't register 110 by the time the cutout happened. We tried at 105 with mixed success, so I just bit the bullet and went to 100. We missed out on the top few hundred RPM.
No - I did not do an ECU reset. No we didn't test the L&L cars before we disconnected and put the ECU in. But how many hours in the day? Not enough, but it aint like I don't give much of my time to this place. Perhaps we should have tried the ECU in my car as well...
Anyway, L&L's car is being Dynoed next week. Perhaps we can dyno mine as well as a comparison.
Cheers,
Hymee.
Old Jan 24, 2004 | 09:47 PM
timbo's Avatar
Originally posted by Hymee
… It was all tounge in cheeck.
Hymee, I think you should be WARY aBOUT spendING SO much time WITH LoKC & LOda. We're all WORRIED Yyooll end UP with HUGE SELF STEEEM! :o :o :D :D
Sorry -- cheap but fun shot there :p
Yes, there are a lot of variables and, as was stated in another thread, this forum is like a networked computer (actually it IS a real neural network) through which facts, observations and other pieces of evidence are shared, theses formed, tested and so-on.
I reckon the comparison between the two cars is fascinating. Anyone else have similar? Perhaps we can put a sticky on the forum, and share this type of data in one spot. I'd certainly be interested in seeing more data.
Old Jan 24, 2004 | 11:46 PM
Talking
Hymee
"How many hours in a Day"???????
I feel that you may have come to the same realization as Emack and i that for some forum members what you do for the forum is clearly not appreciated / not enough.
After all you are our Australian moderator , you have designed and built the famous Hymee Grill that protects our RX8 s from being damaged .
You have spent counless hours effort in designing and having the Hymee exhaust built for the rx8 ,
You are working on your own ECU modification , with Rick , helping each other to try and achieve a better result for our RX8S
You have spent lot of your time in testing Canzoomers STAGE 1 KIT and wrritting a report .etc
Not to mention the cost of the equipment you personally had brought over from overseas to be able to conduct these tests .
The time you spend on the forum educating us on the rx8s ins and outs .
The precious time that you are not with Hymett and the 2 little hymites .
The number of times you are interrupted on the phone by forum members , he he .
Hymee a lot of us really do appreciate what you do for us and the forum , but unfortunately there are those that selfishly take it all for granted.
cheers
michael
PS :
Maybe the problem is that you have never shouted a Free Meal and drinks all round at the FAMOUS Hymee Bar and Grill .
HA.HA.HA
Old Jan 24, 2004 | 11:55 PM
Hymee's Avatar
Race Steward
L&L,
Thanks for the kind words.
Just a slight clarification before anyone gets confused - I have had no input into Ric's ECU. It is his baby. I have talked to him a lot about it though, and would like the opportunity to get him some independant verification. I do think it sounds like a good way to go.
Cheers,
Hymee.
Old Jan 25, 2004 | 12:00 AM
Hymee's Avatar
Race Steward
Thanks Timbo,
I did it for it's interest, not for points scoring. In fact, my car was making better "G's" that day than it was the first night I started doing 40-110km/h runs. And L&L was not in the car that night so we weighed 90kg less.
Cheers,
Hymee.
Old Jan 26, 2004 | 04:11 PM
rpm_pwr's Avatar
Would either of you feel like sharing your 40-100 times?
-pete
Old Jan 26, 2004 | 05:27 PM
Hymee's Avatar
Race Steward
40 - 100 km/h times
Pete,
Sorry, I should have posted that!
L&L's car
Average all 6 runs with CZ Off = 6.24s
Best of all 6 runs with CZ Off = 5.79s
My car
Average of 3 runs = 5.19s
Best of 3 runs = 5.14s
Posted for informational purposes, not "bragging".
Cheers,
Hymee.
Old Jan 27, 2004 | 11:45 PM
canzoomer's Avatar
Forum Vendor
OK, time for me to pitch in and get this started officially..
The standard setup in our Stage1 does not work well on Australian RX-8's NOW.
The purpose on sending the units down to a couple of testers was to get feedback, so we may do a map as needed to suit the cars.
We will continue to work on this to produce the desired results.
It simply will take a bit longer for this to be nailed down properly for your cars down under.
I started a thread on the Canzoomer Forum on this topic here:
https://www.rx8club.com/showthread.p...threadid=19542
I invite Hymee, LockandLoad, and others to pitch in on this as they feel is suitable.
Over the next little while we will be working together to gather data, and we will then produce a new map for testing by them.
Info to follow as it develops.
Old Jan 27, 2004 | 11:48 PM
AMG's Avatar
AMG
canzoomer, thanks for your post, and all the work you've done and your commitment.
Old Jan 27, 2004 | 11:53 PM
canzoomer's Avatar
Forum Vendor
You are most welcome.
It is fascinating to see that Australia is the only place where we have NOT done well so far.
I have landed units in 3 Euro/UK locations, N. America, and one in S. America, and all have done well.
I suspect now that the Aus/Asia region have different maps entirely.
As you can see with the huge differences between Hymee and LockAndLoads cars in STOCK trim, there is a lot to the testing that needs to be done.
I need to get accurate and similarly tested fuel/air mesaurements on BOTH of those cars, and I amhoping they can get in some dyno runs somewhere so we can see the details of what actually is happening on these cars.
Hymee has a method that works for him for Fuel/Air measurements, but we see that we need to use the same instrumentation as I used here so we can properly compare.
We have some work cut out for us, but I feel confident that we can do it with the assistance of these gentlemen and their skills.
Old Jan 27, 2004 | 11:57 PM
canzoomer's Avatar
Forum Vendor
Originally posted by rx8 - smooth!
Hi Guys,
Steve
We are explaining now.
Read, digest, but most importantly:
RELAX!
No conspiracies here, just some honest work and testing to be done.
Neither Rome nor Brisbane were bult in a day.
It doesn't work properly NOW.
It is my intention to rectify that.
Cool?
