Mazmart The leader in late model Mazda parts
Ceramic Seals at Discount
Old Nov 24, 2009 | 03:33 PM
Mazmart's Avatar
SOLD! Thanks.
I have one set of Iannetti Ceramic seals that I need to sell cheaper than normal. The retail price for Mazda Competition Parts is $2700. My cost is close to $2000.
These are the ULTIMATE seals for the renesis and I recommend them for anyone who wants to make the most power over the longest period. In street usage these should outlast the car or literally not wear out in decades. The beauty of these is that they do not cause the normal wear to the apex grooves of the rotor and are unusually easy on the rotor housing surface due to their inherent lubricity. This same lubricious nature allow these to be used with higher spring pressures permitting better sealing at high revs as well as improved torque in the mid range. They are resistant to warpage or deformation brought about by high temperatures or even great temperature variation.
Although these seals are much stronger than the stock steel seals I don't recommend them to people using forced induction unless they have mastered their tune. These are not for the experimenting crowd. These are the choice seal of racers in the Star Mazda series and the Koni Challenge especially since they can be used over and over and over again.
Iannetti is the ONLY brand that we have used since 1990 other than stock OEM.
They can be purchased here for $1975: http://www.mazmart.com/PartsList.aspx?id=29&n=NEW&m=6
Paul.
Attached Thumbnails Ceramic Seals at Discount-111609-018.jpg   Ceramic Seals at Discount-111609-019.jpg   Ceramic Seals at Discount-111609-021.jpg   Ceramic Seals at Discount-sdc10006.jpg   Ceramic Seals at Discount-sdc10005.jpg
Old Nov 24, 2009 | 03:34 PM
Bump for a good deal.
Old Nov 24, 2009 | 04:26 PM
Nemesis8's Avatar
Bigus Rotus
Good Lord - a piece of history for sale. I would just mount them behind glass and hang them in my bar I'm building next year.
Old Nov 24, 2009 | 04:57 PM
Rote8's Avatar
Got 3mm?
Old Nov 24, 2009 | 05:14 PM
Mazmart's Avatar
Originally Posted by Rote8
Got 3mm?
I can provide 3mm and we're working on some 2 mm deep groove (FD RX7 Dimension) non ceramics for the purpose of EXTREME boost.
Paul.
Old Nov 24, 2009 | 06:13 PM
JinDesu's Avatar
went back to srsly broke
WHY DO YOU SELL THESE NOW AND NOT IN A YEAR WHEN I HAVE MONEY!?
*sobs*
Old Nov 24, 2009 | 06:31 PM
mac11's Avatar
Rotary , eh?
Paul.
Paul
Not sure I would trust the Mazda cast to be deep enough in extreme load situations. There doesn't appear to be much extra material there after making the change in the machining. Of course, it's pretty hard to measure that area without having done a CMM. Just sayin'.
Old Nov 24, 2009 | 11:09 PM
it's already been done for years Mac, just sayin' ....
Old Nov 24, 2009 | 11:12 PM
If I recall the castings for the Renesis rotors are much thinner....
Heard rumors that there wasn't room for long 3mm seals
Old Nov 24, 2009 | 11:17 PM
mac11's Avatar
Rotary , eh?
Originally Posted by TeamRX8
it's already been done for years Mac, just sayin'...
I've heard of a few builds. Just saying I wouldn't do it on Mazda rotors.
It's the depth not the 3mm width that concerns me.
either way this is DEFF not the right place for this. Pm me if you care any further.
Old Nov 24, 2009 | 11:25 PM
I doubt Rick Engman will be PMing you for advice
Old Nov 25, 2009 | 12:09 AM
mac11's Avatar
Rotary , eh?
I usually deal with paul. *shrug*
Old Nov 25, 2009 | 08:49 AM
Mazmart's Avatar
Originally Posted by mac11
Paul
They're good for deep groove 2mm. 3 mm may be possible but like Dannobre said I wouldn't do it. We cut Renesis rotors apart 4 or 5 years ago to evaluate these things.
Paul.
Old Nov 25, 2009 | 09:53 AM
Kane's Avatar
When I was thinking about doing 3mm Ceramics myself; after talking to a bunch of folks it seemed that 1 out of 4 rotors would crack after warm up/break in due to material loss and the motor would have to be torn down and a new rotor installed....a 25% chance of failure-IMO not worth it.
However the FD sized seals seemed to work fine; just have a good shop machine them.
Old Nov 25, 2009 | 10:17 AM
Mazmart's Avatar
Yes. We use deep groove renesis rotors in a lot of competition motors that we run. It is VERY important to ensure that whoever is machining the grooves knows what they're doing as many a motor has been ruined due to lack of proper knowledge and experience in this area.
Paul.
Old Nov 25, 2009 | 10:20 AM
Kane's Avatar
Yup; I had Speedsource do mine; and even then I was nervous about them...
PS - I wanted to thank you guys for hooking me and Ray up so quickly on the seal and o-ring kits.
Old Nov 25, 2009 | 10:35 AM
mac11's Avatar
Rotary , eh?
Paul.
Us too.
BTW, wanted to thank you guys again for balancing that rotating assembly with our rotors.
Old Nov 25, 2009 | 10:39 AM
Mazmart's Avatar
It's an honor to serve sir. I'm also privileged to have Sheldon here who is generally quick to get the parts out.
Paul.
Old Nov 25, 2009 | 10:47 AM
blackenedwings's Avatar
Life begins @ 30 psi
Paul, I'm curious what your thoughts are as to the best option for seals for a boosted Renny motor. I've got a motor being worked on by Brian at BDC, but I'm a bit stumped on ideas for the seals. Suggestions? I ask here because I notice that both you and Racing Beat do not recommend ceramic seals for boosted motors and I'm curious why not?
Old Nov 25, 2009 | 10:50 AM
Mazmart's Avatar
Us too.
I'm glad to have been involved in the process. Speaking of which, I will PM you soon. I need to discuss a thing or two with you.
Paul.
Old Nov 25, 2009 | 10:58 AM
tubingchamp's Avatar
What mawd bug?
From what I've seen and through my limited knowledge I'd say:
1)They're hella expensive.
2)Though, they are more resistant to detonation, they are not invincible.
3)Get your tune right BEFORE you buy them, because if you don't, it's an expensive mistake.
4)They'll last nearly forever on a renesis with a perfect tune due to great lubricative nature and lack of wear + they will not damage other engine components, so its a great choice for a stable engine. Newly FI'ed engine with a less than perfect tune is NOT stable enough to stay detonation free.
Anyone correct me if I'm wrong- Don't claim to be an expert
Old Nov 25, 2009 | 11:11 AM
Mazmart's Avatar
Ceramics of the correct dimensions and properly clearanced are the best for NA and FI if the tuner is totally confident. There are people running 40 plus PSI with humungous turbos on alcohol making 1000 hp to the wheels with ceramics. A motor at this level of tune can only last X runs of the quarter no matter waht seals you use. There are people using steel seals making less than 300hp breaking seals (With poor tune). There are several variables including fuel octane, intake air temps, ignition timing, air/fuel ratios etc that always need to be considered. The approach of some seal manufacturers has been to make seals that will bend and distort greatly when faced with great pressures and temperatures but of course they will kill power when this occurs. My opinion is: Don't create the environment where seal breakage could occur in the first place. When ceramics break they can do more damage than a steel seal generally speaking. In a renesis it's worse than the older peripheral exhaust motors because material can't escape as easily. The strong ceramic fibers can do a number on the internal parts when catastrophic falure takes place.
I'll try to PM you what approach I recommend in better detail.
Paul.
Old Nov 25, 2009 | 11:15 AM
Mazmart's Avatar
You are correct. These seals I'm selling are not intended for an FI renesis and will be EXTEMELY long lasting with NA environments. For someone who can afford these they would have many benefits longterm. 200k miles with great compression and power on the street would be a walk in the park.
Paul.
Old Nov 25, 2009 | 11:20 AM
Kane's Avatar
What I find interesting is that - everyone agree's they are at LEAST as detonation resistant as a metal seal; so why are they are not recommended for FI?
If cost is the issue - then simply say that they are expensive.... but a renesis seal failing can cause plenty of extra damage all on it's own...
Old Nov 25, 2009 | 11:55 AM
olddragger's Avatar
i would say that Paul is referring to a cost benefit type of thing? Boosted renasis engine have a way of not lasting 100K. Probaly because we mostly are idiots just having fun--self being a one of the 1st club members.
I wish they had ceramic side seals.
Oh by the way Paul just spoke with S --in need for a trans and to make sure I was one of the 1st on the list for the oil bypass mod.
Have you seen the results coming from converting our cars to a single oil cooler? Nice results --you should look. I see an entire kit???
OD
