Coolant light when revving to redline at a stand still.
Old Nov 20, 2009 | 09:11 PM
SayNoToPistons's Avatar
Wheels, not rims!!
Car is a 2004 GT MT with 47k miles, stock.
I let the car sit for almost two weeks and decided to take it around the neighborhood tonight. After a 15 minute drive, I revved to ~8000-8800 RPM a few times at a redlight just for the hell of it. I noticed the last 2 times I blipped the throttle, the coolant light level light came on when I was nearing redline and turned off once I was out of the 8000+ range. My coolant is full also, the temperature is around 50 degrees tonight and I was driving conservatively throughout the 15 minute drive shifting ~4k rpm with medium throttle.
What could be the issue if there is an issue?
Old Nov 20, 2009 | 09:14 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
You're kidding right?
Well.....in case you aren't.......look at the bottom of this page, but I'll go ahead and tell you that it is most likely your sensor going out.
You could add a little coolant and see if it helps, but probably won't.............and it get will worse.
See this for even more info............... https://www.rx8club.com/series-i-trouble-shooting-95/coolant-bottle-greatest-secrets-revealed-182793/
Old Nov 20, 2009 | 09:20 PM
xun4gvn4everx's Avatar
True love is blue x2
wait.... you are kidding right???? :
Old Nov 20, 2009 | 09:29 PM
iLikeEatPoo's Avatar
The Great Dick
Add/top off the coolant again. Don't forget to burp the air out.
Old Nov 20, 2009 | 09:40 PM
And remember, after three shakes, you are playing with it!
Old Nov 20, 2009 | 10:37 PM
I8U's Avatar
I8U
WOW...a question like this from someone with 3400 posts!? I should be use to it by now, nothing surprises me anymore...
Old Nov 20, 2009 | 10:38 PM
^ Except the surprise sprinkles!!!!
Old Nov 20, 2009 | 10:43 PM
Wheels, not rims!!
Score!
Old Nov 20, 2009 | 10:47 PM
Old Nov 21, 2009 | 09:49 AM
Mazurfer's Avatar
Originally Posted by SayNoToPistons
Score!
Figured so.
Filed away for future use!
WranglerFan
May 31, 2022 07:51 AM
Azki23
Jun 27, 2018 03:48 PM
WranglerFan
Nov 5, 2017 09:35 AM
TeslaMSI
Dec 10, 2015 01:10 AM
