Are my spark plugs OK, (PIC)
Old Nov 18, 2009 | 10:37 PM
Vikingdiesel's Avatar
I took one plug to see if its bad or no, doesnt look bad, right?
Old Nov 18, 2009 | 11:38 PM
Old Rotor's Avatar
It looks way rich did you just start and let it idle for a few minutes? Please give us the history on your car, miles, service, parts replaced, type of driving it gets?
Old Nov 19, 2009 | 12:12 AM
04 RX8, 91k miles, been sitting, has a hard time re-starting , now its clearing up and able to e-start back you. Dont know much on history
Old Nov 19, 2009 | 12:35 AM
Old Rotor's Avatar
It might need a new air filter. So I'm not sure if you meant it is running fine now? Where you said "able to e-start back you" please explain.
Old Nov 19, 2009 | 12:39 AM
its gotta a pretty clean K&N filter. It used to NOT be able to re-start right away after turning it off, now its getting better, i believe it was flooded
Old Nov 19, 2009 | 12:49 AM
Old Rotor's Avatar
I got you now. You might get some benefit from a good de-carbon cleaning. Also do you have the new style starter motor.
Old Nov 19, 2009 | 12:56 AM
not sure, how would I go about to found out?
Old Nov 19, 2009 | 04:09 AM
c41250n's Avatar
so what fixes the hard start?
Old Nov 19, 2009 | 08:39 AM
always.anthony's Avatar
is looking for his torque
if its never been done before, im sure it will help alot, and i'm talking about seafoaming you're car.
theres a diy somewhere around here and its really easy to do. you might need a friend though. i put a wooden block on the gas pedal when no one was around.
you can find seafoam at walmart or any auto store (autozone, oreillys)
Old Nov 19, 2009 | 10:20 AM
will seafoam clean up the plugs? would I still need new plugs?
Old Nov 19, 2009 | 12:51 PM
04RX8man's Avatar
Rotary Powered Countryboy
put new plugs and coils in the thing
Old Nov 19, 2009 | 02:22 PM
Old Rotor's Avatar
It will clean them up some.....but spark plugs wear out and you don't want it to break off and scar up your engine. Replace them, coils and wires it's called preventive maintenance.
Old Nov 20, 2009 | 06:10 PM
hkspoweredrx8's Avatar
Rotarys Own My Life
Get a whole new set of plugs, see how that goes. Cause if 1 looks like that, most likly their all burnt and fouled out looking.
Old Nov 20, 2009 | 06:37 PM
better safe than sorry, good luck with everything!
Old Nov 20, 2009 | 08:43 PM
thanks guys, installing new plugs next week
Old Nov 24, 2009 | 02:11 PM
Spirograph's Avatar
My 8 has always taken a few cranks to startup (up to 7 or 8 sometimes), even after installing a new yellow top battery. I haven't yet done the decarb or swapped the coils, plugs, and wires, but a couple of days ago, I filled up with half a tank of premium (which I always run), and added 3/4 a can of seafoam w/o premix. I started it up and let it idle - it was smoking out the tailpipes and dripping carbon cleaned from the tailpipe even, for a few minutes. I ran that for 1/4 tank, then ran the last 1/4 tank with 4 oz. of MMO added to help protect and also clean. Then at next fillup I did 8 oz. Idemitsu and 4oz MMO to get the protection back in action. It now starts on the first crank, and it also has higher torque response at high rpms.
Old Nov 24, 2009 | 04:17 PM
kersh4w's Avatar
Hit & Run Magnet
did you just stick the seafoam into the tank of gas?
Old Nov 24, 2009 | 07:38 PM
g0rdhan's Avatar
sorry guys, but what does the seafoam supposed to do??
Old Nov 24, 2009 | 09:20 PM
i thought you dump the whole seafoam in a 1/2 tank of gas, it has to be a full tank?
Old Nov 24, 2009 | 09:51 PM
Old Rotor's Avatar
That is the simplest way(best results half or quarter tank) but the best is add it directly to the engine threw the manifold. I've done both....
RevMeHarder
Jun 1, 2026 02:30 PM
TeslaMSI
Dec 10, 2015 01:10 AM
Brooklynite
NE For Sale/Wanted
Nov 10, 2015 06:42 PM
DVerdeyen
Sep 13, 2015 11:19 AM
