cold car 2nd gear clunks, warm and its fine
Old Nov 18, 2009 | 06:26 PM
FazdaRX_8's Avatar
when the car is still cold and the engine is farly warm, second gear clucks or grinds as it goes in. after the car is been driving and everything is nice and warm 2nd gear works just fine
is the tranny fluid too low, or does it need changed, or is this a sign of a more serious problem?
Old Nov 20, 2009 | 02:34 PM
corners's Avatar
An RX ate my baby
Change your oil. It should help to go to a good synthetic. Transmission oil loses its cold viscosity first when it starts to go.
Old Nov 20, 2009 | 03:31 PM
silverbullet05's Avatar
hmm.... i have the same problem. 2nd gear clunks/grinds cold.
it's even hard to get into even when warmed up sometimes. time to order some mt-90!
Old Nov 20, 2009 | 04:10 PM
SARRAS's Avatar
Sydney, Australia
AND ask them to bleed the clutch as well - its hydraulic on these cars and needs a bleed every year or so....
Old Nov 20, 2009 | 06:38 PM
FazdaRX_8's Avatar
thanks guys
Old Nov 20, 2009 | 07:09 PM
04RX8man's Avatar
Rotary Powered Countryboy
Mine did it...trans rebuild and still does it...i've just taken it as something that happens....I just hold the clutch in for an extra 1/2 second and it's find...but mine stops after shifting into 2nd like twice....
Old Nov 23, 2009 | 02:28 PM
L337fpc's Avatar
ლ(ಠ益ಠლ)
I have the same symptoms...and i swapped my oil with redline mt-90. No dice...
Old Nov 23, 2009 | 03:01 PM
TX
so you swapped in redline oil and it didn't improve at all? i was looking forward to a slight improvement at least.... bummer
Old Nov 23, 2009 | 03:15 PM
epikeddie's Avatar
It's from sychro wear. It's a common issue on this car and our transmissions are known to be weak.
Look at how many transmissions TeamRX8 went through. Any type of abusive, hard-shifting.....and this transmission just goes bad. The Aisin transmission is probably one of the weaker links in this car - especially if you ever want to see some REAL track action.
MT90 is heavier than the MTL fluid from Redline's catalog. Many owners here have mixed both in a 50/50 formulation. However, TeamRX8 uses straight MT90 in his.
MTL - smooth shifting, but very thin for aggressive shifting applications
MTL/MT90 mix - Compromise, but still thin for really aggressive shifting applications i.e. competitive autocross where you have to bang on the gates more often than on a track.
MT90 - notchy shifting, but superior protection for the synchros and gears.
Again, if you're already experiecing grinding, your sychros are more than likely shot. It will require a replacement or rebuild of your transmission.
Old Nov 23, 2009 | 03:53 PM
L337fpc's Avatar
ლ(ಠ益ಠლ)
Yea i know my 2nd gear syncro is going, but swapping fluid is getting me by until i can afford a rebuild.
But all other gears feel awesome with MT90.
Old Nov 24, 2009 | 11:53 AM
EC8's Avatar
EC8
'09 Sport Newbie
My car has a slight clunk going into 2nd when it is cold as well, never grinds. Have an '09 with about 850 miles on it, but fluid in there is over a year old (sat at lot for a long time). Going to replace with MT-90 around 2k and hoping it helps a little. Warmed up it is fine though. 1st gear always has a very slight clunk as well, but sounds normal for 8's
Old Nov 27, 2009 | 09:19 PM
ASH8's Avatar
Super Moderator
My 09 was clunky when cold into 2nd gear, changed to MT90 and was beautiful for a while..
As AusZoom said and I agree, even with Redline, that is supposed to be good for 200,000 miles, you need to change the Tranny oil every 10,000 miles or so if you want that Ultra Smooth change..
But yeah, IMO if you track your car often and used the Gearbox like a racer then it won't last, IMO it is not designed for constant High RPM changes and High load..
Just think, how many times do you think real Racing or Touring Cars replace their gearboxes...the answer is "very" often.
As good as the RX-8 is, it is made to a price, you don't have "Holinger" Quality or Reliability.
http://www.holinger.com.au/
madrotor
Jul 26, 2015 12:06 PM
Bamaham
Jul 23, 2015 08:08 AM
RotaryRider
Jul 20, 2015 07:05 AM
vssystemluba
Jul 19, 2015 04:16 PM
Belalnabi
Jul 17, 2015 07:48 PM
